Reevaluating the Big Bang Theory: Challenging the 13.7 Billion Light Year Limit
  • Thread starter shashankac655
  • Tags
    Big bang
In summary, the conversation discusses whether finding a galaxy more than 13.7 billion light years away would disprove the big bang theory. It is noted that Hubble has already found a galaxy 13.2 billion light years away, suggesting that the universe is significantly larger than 13.7 billion light years in radius and that universal expansion is not limited to the speed of light. The speaker also mentions that relativity allows for distances to change at rates exceeding the speed of light and that this is supported by realistic solutions of the 1915 equation. There is also mention of the Wright balloon model, which demonstrates how distances between galaxies can increase over time. Finally, the conversation touches on a previous claim
shashankac655
If we can find a galaxy(or anything at all) that is more than 13.7 billion light years away can we say that the big bang theory is wrong? Hubble has already found a galaxy that is 13.2 billion light years away.http://www.spacetelescope.org/news/heic1103
Space news on Phys.org
Hubble has already found a galaxy that is 13.2 billion light years away.[http://www.spacetelescope.org/news/heic1103/]UDFj-39546284
[/URL]
The universe is significantly larger than 13.7 billion light years in radius.
Universal expansion is not limited to the speed of light.
Absolutely unbelievable, isn't it?
Yeah, but that's not what that 13.2 billion figure in the article referenced OP was about. In fact, the article referenced by the OP never once used the term "light year".
Last point first: Hubble discovered a galaxy whose light took 13.2 billion years to reach us.
Note that the article never said anything about light years. While it is valid to equate (for example) the 4.3 years it takes light emitted by a nearby star to reach us with a distance of 4.3 light years, this concept loses validity when time spans are long. The use of velocity*time=distance in that calculation ignores the expansion of the universe.
13.2 billion years ago, when that galaxy emitted that light that we are seeing just now, the distance between that galaxy and ours was much less than 13.2 billion light years. Moreover, that galaxy is "now" much further than 13.2 billion light years away from us.
So what would falsify the big bang? Seeing stars with high metallicity in those very remote galaxies, for one.
Hardly :biggrin:
Would you care to explain why you think it is "absolutely unbelievable"?
Relativity (the 1915 theory of gravity, by now extremely well-tested) tells us in our type of universe to expect large enough distances to be increasing at rates greater than c.
And there is nothing in relativity that says they can't.
In another type of universe---modeled by a different solution to the Einstein equation---large enough distances might be decreasing at rates greater than c.
Again this is not against the rules, it is just a different case of the same thing. A lot of people seem to think that relativity forbids distances to change at rates exceeding c. It certainly does not! They are just confused by what they were told about motion in a local frame of reference. With that conventional idea, motion in a local frame, somebody gets somewhere. Some point of reference, like a destination, is approached.
In a pattern of uniform longrange distance increase nobody goes anywhere. In the absence of a gravitation bond holding stuff together, distances simply increase by some small fraction of a percent every million years or so. No destination is approached. Nature does as she pleases with geometry. The current rate that is observed at present is an increase of 1/140 of one percent per million years. It seems very slow, if you try to picture it. But for very large distances it can amount to a rate of increase which is > c.
This is required by realistic solutions of the 1915 equation. And that relativity equation is our law of gravity---no one has been able to find a better, simpler, or more accurate one. The 1915 equation has been checked repeatedly for 90 some years in every way people have been able to think of, and is still being checked.
So I would say, just get over it. You have no scientific reason to object to distances increasing in that way. You have only a confused prejudice based on hearsay, or perhaps on misunderstanding something told you that was actually correct.
It is admittedly quite curious! Geometry can be dynamic, rather than static. From the standpoint of us primates living on a small rock----with our experience of geometry being mainly static and anchored to that rock---it is unintuitive that over very large distances goemetry might not be static. Spatial relationships might change---might have curvature too---three angles might not add up "right". But we just have to accept Nature on her own terms, let her be what she wants to be instead of what seems intuitive to us monkeys :biggrin:
Suggestion: google "wright balloon model" and watch the animation for a few minutes. The galaxies stay at the same place (same lat. and long.) but the distances between them increase. For larger distances the rate of increase is greater than the speed the little wiggler photons are traveling.
Finding a galaxy behind the surface of last scattering would, to put it mildly, be unexpected and play havoc with BBT. Years ago it was claimed that some stars appear older than the putative age of the universe. Of course we knew our stellar evolution models were imperfect, and the age of the universe was not known with much precision. Most scientists took a wait and see attitude. This is usually the smart thing to do when you have observations that conflict with a mainstream model. If the model is defective, there will inevitably be other corroborating observations. The temptation to pull a 'chicken little' is certainly there in such cases. But, you don't get do overs in science when you champion a startling new 'discovery' that turns out badly. Think of the recent uproar created by the OPERA group, for example. If wrong, these poor guys will be forever remembered for this one colossal blunder, regardless of whatever other great work they may have done, or do.
As has already been pointed out, the article you referenced never used the term "light year". When using terms in physics, one of the things I came to realize early on is that sloppiness in terminology leads to and/or is a reflection of sloppiness in thinking. Just getting a handle on what basic terms MEAN takes you a long way towards understanding a lot of physics.
So, i can easily understand how you read "13.2 billion years" and just slipped in the "light", especially since I've done the same thing when not paying attention, but I'd suggest that you pay careful attention to terminology and fundamental units.
If I'm preaching to the choir on this and this was just a one-time slip-up, then ignore me. :smile:
I think D H got it right about what was wrong in my OP ,we can measure distances between nearby stars and slip the word "light" in between "million... years" without going wrong but if are talking about ancient galaxies we can't do that because the universal expansion will become very significant.
sorry if i have used the term "light year" carelessly, actually i was not talking about size of the universe being equal to or greater than 13.7 billion light years ,what i meant was that if we can spot a galaxy that is more than 13.7 billion light years away ,that means ,the very fact that we are able to see it proves that the galaxy existed more than 13.7 billion years ago because even if the galaxy is not there in the same position now ,it has taken more than 13.7 billion years for the light from it to reach us but that's not possible because when the universe itself is thought to be 13.7 billion years old.Hence ...
If the BBT is true we should never be able to see a galaxy which so far away ,right?
You need to read up more on the history of the universe. You misunderstand the situation completely. The object which we see NOW emitted its light 13+billion years ago BUT IT WAS NOT AT THAT TIME 13+billion light years away. It was much closer, so there is no contradiction at all.
It has taken 13+billion years for the light to REACH us, not because it was emitted that far away but because the photons have been getting dragged away from us by the expansion of the space between us and the point of emission. That's why it is red-shifted.
phinds said:
... You misunderstand the situation completely...
Shashanka with all due respect I think Phinds is right. You do sound confused. One thing that might help is to get used to using one of the simple cosmology distance calculators.
One I like is called "cosmos calculator". I have the link in my signature, it is the "morgan" link---Professor Morgan put it on line. Or you can just google "cosmos calculator" and you will get it.
To start a session you type these 3 numbers into the boxes over on the left labeled Omega, Lambda, Hubble.
.27 for Omega
.73 for Lambda
71 for Hubble parameter
then you put in any redshift that might be observed for some galaxy or quasar, and it will tell you the distance now---and the distance back then when the thing emitted the light.
You can keep putting in different observed redshifts and recalculating. for each new redshift you put in you get some new distances. It also tells recession speeds.
If you try it, and have any trouble, please let us know. I or someone will help. It is pretty easy. You probably won't have any trouble.
It also tells you what the Hubble expansion rate was back then when the light was emitted, which is kind of interesting. The 71 is just the value at present, it has been changing in the course of the universe's history. The calculator implements the standard model of the universe used in cosmology. So it is a hands-on way to become familiar with the standard model cosmos. Verbal descriptions can actually interfere with understanding.
Good luck, if you try it!
marcus said:
Hardly :biggrin:
I apologise. :)
I did not think the statement "absolutely unbelievable" required an explanation; the fact that there is a universe in existence rather than nothing at all, and that there are galaxies receding away from us at faster than c, which at some point, they will disappear from us forever. I am sorry that you don't find it as astonishing as I do... :p
ealia said:
I apologise. :)
Do not apologize. The universe is indeed a wondrous place, full of all manner of miracles and delights.
DaveC426913 said:
...The universe is indeed a wondrous place, full of all manner of miracles and delights.
Wondrous indeed! That is well put. And full of all manner of miracles and delights.
I like that turn of phrase and am apt to borrow it in future. But also, I find, quite believable (which makes it all the more wonderful.)
Ealia, there is a neat trick whereby light emitted from a galaxy receding at rate > c can still reach us. You may know of it, and understand how it works already---I don't know how much cosmology you have read.
If you aren't familiar with this you might like to pursue it by asking Dave or any of us questions. It's pretty simple, once explained. But also kind of wonderful.
It's something you find out when you play around with that online "cosmos calculator" that I suggested Shashanka google and try.
Most of the galaxies we know about and can observe with a telescope have recession rates greater than c.
This is because the great majority we can see have redshifts > 1.7. Indeed 1.7 is not an especially big redshift for a galaxy to have.
But using the calculator you find that something whose light comes into us with redshift z = 1.7 was already receding > c when it emitted the light and today is receding even faster.
All the more so for any galaxy whose redshift is greater than 1.7. Try plugging in 2, or 3, or 4
For people who are not put off by simple online calculators, here is the recipe:
Go to http://www.uni.edu/morgans/ajjar/Cosmology/cosmos.html
On the left you see four boxes
Matter density
Cosmological constant
Hubble rate
Redshift
At the start of every session you have to load the first three and then you can put in whatever redshift and press the "calculate" button. You put .27, .73, and 71 in the first three boxes. These are the parameters of the best-fit standard cosmo model.
Matter density .27
Cosmological constant .73
Hubble rate 71
Redshift 1.7
Then press "calculate".
You'll see the recession rate was a bit more than c. Anyone who is curious how the light could have gotten here (it would obviously at first have been swept back) can basically ask anybody who has been around this forum for a while, Dave, Brian Powell, Chalnoth and many more.
It's neat how it happens.
Matter density
Hubble rate
Redshift
Matter density .27
Hubble rate 71
Redshift 1.7
That is very interesting marcus. If you could please, I would very much like to hear how that occurs - I have not heard of it before. Thanks. :)
I wrote some stuff about this.
George Jones said:
I know this is very counter-intuitive, but I really did mean what I wrote in posts #52 and #55. :biggrin:
Thanks for pushing me for further explanation, as this has forced me to think more conceptually about what happens.
This can happen because the Hubble constant decreases with time (more on this near the end of this post) in the standard cosmological model for our universe. Consider the following diagram:
Code:
O                                B        A        C
O                    B     A     C
The bottom row of asterisks represents the positions in space (proper distances) of us (O) and galaxies B, A, and C, all at the same instant of cosmic time, [itex]t_e[/itex]. The top row of asterisks represents the positions in space of us (O) and galaxies B, A, and C, all at some later instant of cosmic time, [itex]t[/itex]. Notice that space has "expanded" between times [itex]t_e[/itex] and [itex]t[/itex].
Suppose that at time [itex]t_e[/itex]: 1) galaxy A has recession speed (from us) greater than c; 2) galaxy A fires a laser pulse directed at us. Also suppose that at time [itex]t[/itex], galaxy B receives this laser pulse. In other words, the pulse was emitted from A in the bottom row and received by B in the top row. Because A's recession speed at time [itex]t_e[/itex] is greater than c, the pulse fired towards us has actually moved away from us between times [itex]t_e[/itex] and [itex]t[/itex].
Now, suppose that the distance from us to galaxy B at time [itex]t[/itex] is the same as the distance to galaxy C at time [itex]t_e[/itex]. Even though the distances are the same, the recession speed of B at time [itex]t[/itex] is less than than the recession speed of C at time [itex]t_e[/itex] because:
1) recession speed equals the Hubble constant multiplied by distance;
2) the value of the Hubble constant decreases between times [itex]t_e[/itex] and [itex]t[/itex].
Since A's recession speed at time [itex]t_e[/itex] is greater than c, and galaxy C is farther than A, galaxy C's recession speed at time [itex]t_e[/itex] also is greater than c. If, however, the Hubble constant decreases enough between times [itex]t_e[/itex] and [itex]t[/itex], then B's recession speed at time [itex]t[/itex] can be less than c. If this is the case, then at time [itex]t[/itex] (and spatial position B), the pulse is moving towards us, i.e., the pulse "turned around" at some time between times [itex]t_e[/itex] and [itex]t[/itex].
If the value of the Hubble constant changes with time, what does the "constant" part of "Hubble constant" mean? It means constant in space. At time [itex]t_e[/itex], galaxies O, B, A, and C all perceive the same value for the Hubble constant. At time [itex]t[/itex], galaxies O, B, A, and C all perceive the same value for the Hubble constant. But these two values are different.
Probably some of my explanation is unclear. If so, please ask more questions.
Maybe you already know this: cosmo is a math science. Everything we say is about a model. The model is very simple and is built into calculators.
With purely verbal explanation there is little gain in understanding. To learn you need hands-on experience with the calculator (or the Friedman equation that it is based on.)
I don't know you. You may be smart on a math level (as well as on verbal level). You may have already tried Siobhan Morgan's calculator, that I was urging in post #11 and again in post #15.
If not, my verbal explanation might not help. But if you listen and ALSO play with the calculator it might work.
The Friedman eqn governs H(t) and you can see that H must always decrease.
But if you played with the calculator you would have ALREADY SEEN that H decreases over time. As you plug in higher and higher redshift the age of the universe goes down and down and the calculator TELLS YOU what H is at each age of the U. H goes up as you go back in time.
Take a pencil and make a table showing how as the age increases---1 billion 2 billion 3 billion...---the Hubble rate is decreasing. Quite sharply at first!
Now there is some algebra which a 14 year old can do.
The key equation is v = HD. What distance corresponds to v = c?
That is the distance that is growing at exactly rate c. Larger distances grow faster. Smaller ones no so fast.
The 14 year old child tells you the critical distance is c/H.
If the photon aimed at us can ever get to within distance c/H of is, it will make it!
But I told you H was decreasing. You can and should check it with the calculator.
Therefore the critical distance is INCREASING.
All the photon has to do is hang in there and stay roughly the same distance from us (or even be swept back a iittle), for long enough, and the critical distance will REACH OUT TO IT. And then it is safe. It will be within the sphere of distances that are NOT increasing faster than c. And it will begin to make real progress and reduce the distance it needs to go and actually gain ground.
So say the distance to the galaxy is increasing at 1.1 c and it emits a photon in our direction. The distance to the photon will then be only be growing at 0.1 c
It has a fighting chance. It keeps on struggling towards us and only gets swept back slowly, at 0.1 c.
Now the critical distance c/H is reaching out very fast because (as you can see by experimenting with the calculator) the denominator H is decreasing rapidly. After a while if the photon keeps trying, it will be within the magic circle. So even though it has to fight the expanson of distances, the photon will eventually get to us.
The whole thing depends on H decreasing and now it is decreasing much more slowly than it did earlier when expansion was only a few billion years old. So this opportunity is shrinking. Eventually the trick will not work or will do so only in a very marginal way. Too bad. But that is still far in the future.
Our sky is still full of galaxies that emitted light to us when they were receding >c and the light is still getting to us.
The time will come when there are not so many galaxies visible in the sky. But it is far in the future so not to worry.
You should be able to calculate the critical distance c/H.
c is 300,000 km per second
H is 71 km per second per megaparsec (a unit of distance)
So c/H would be some number of megaparsecs that you can calculate.
I invite you to find that number of megaparsecs. Google will convert it to other units like meters or miles or lightyears, if you want.
Whatever that distance is, distances bigger than it are increasing >c
and distances smaller than it are increasing slower than c.
Very important distance. It has a special name: Hubble radius.
Maybe you knew all that. If you didn't, and have never calculated the Hubble radius, why not try?
Confucius is alleged to have said: "Tell me and I will forget. Show me and I might remember. Involve me and I will understand." John Dewey the American philosopher said "learn by doing" or words to that effect :biggrin: I was just reading the Wikipedia on "experiential learning". Did you ever read anything about that?
Thanks marcus and george, for all the information :).I am not able to open the cosmos calculator because some kind of plug-in is not installed , i installed it but i am still not able to open it.I use a very old PC , the modem goes into a 'coma' sometimes, i don't know what exactly is wrong.It is asking me to install it again and again.(forget it)
Is the Hubble radius equal to this ?? 1.30218021 x 10^23km
i did it in a hurry ,i might be wrong.
marcus said:
Now the critical distance c/H is reaching out very fast because (as you can see by experimenting with the calculator) the denominator H is decreasing rapidly. After a while if the photon keeps trying, it will be within the magic circle. So even though it has to fight the expansion of distances, the photon will eventually get to us.
Is the Hubble radius expanding faster than the Universal radius? if yes,
will it catch up?
Shashanka,
I wanted to check your answer and happened to use the google calculator.
when I type 300000/71 into the google search window I get 4225.
(sometimes I have to hit "return" or type an equal sign to make it calculate. Do you use the google calculator?
That answer means the Hubble radius is 4225 megaparsecs. Say I want that in lightyears, then I type in (without the quotes)
"4225 megaparsecs in iight years"
It says "1.378e10 iight years"
That is the same as 13.8 billion light years. It is a proper distance, not to be confused with light travel time.
On the way I saw that your answer was correct. Because when I had not finished yet and had just typed in "4225 megaparsec" it told me that this was "1.3037e26 meters". Essentially what you said.
The google calculator tends to jump to the conclusion that I want the answer in standard SI units, unless I specify otherwise by saying "in light years" or something.
Thanks for trying to use Cosmos Calculator! This is the first time I've heard of this "install a plug-in" problem. Not to worry. You obviously know how to use a regular calculator and you know how to convert units.
Besides, if you want to try a cosmology calculator there are others. The one most people seem to use is Ned Wright's. Google "wright calculator". There is an excellent chance you will not encounter the same problem.
http://www.astro.ucla.edu/~wright/CosmoCalc.html
The main thing wrong, pedagogically, is that Wright's has more options and more technical jargon. What Morgan correctly calls "distance then" (back when the light was emitted) Wright calls "angular size distance". This is also correct---two different verbal descriptions of the same mathematical object. The closer something was, back then, the larger angle it will make in the sky (for a given size object)----so distance that you gauge by how big angle in the sky a given size object makes is the SAME as distance back then.
Wright's calculator is very good and is part of his very good cosmo tutorial and FAQ. He is a UCLA prof and worldclass cosmo expert. But I like how Morgan calculator is simplified to be good for beginners.
will it catch up?
I am not sure what you mean by "Universal radius". Standard cosmo model has no edge or boundary, and they haven't figured out yet whether it is infinite volume or finite volume.
Maybe you mean what some cosmologists call the "particle horizon". This is the farthest away a particle could be NOW that we could be receiving light from. (The absolute visibility limit ssuming perfect transparency.)
As I recall it is between 45 and 46 billion light years.
If right at the start of expansion, our matter (which eventually became us) could have fired off a magic photon in some direction. That photon would now be 45 or 46 billion light years from us.
(combined effect of its own ability to travel at c, plus the expansion of distance. Magic to allow it to pass thru all the fire and crud of the early U without being scattered.)
The "particle horizon" is also called the "radius of the observable" part of the universe.
Be careful to distinguish between the actual universe and the part that is so far observable to us.
My attitude is I will not use a term like "Universal radius" until the experts have estimated whether she is finite or infinite, and can say a bit more definite about the very early.
MAYBE it will turn out that space is a hypersphere---the 3D analog of the 2D surface of a balloon----but with nothing inside or outside the balloon. Maybe. then it would be finite 3D volume, and it would have a finite circumference. That circumference divided by 2π would technically be called "radius of curvature".
Then the experts would estimate that circumference and that "radius of curvature" for us.
(This has already been done but it is still very hypothetical---they got a lower bound on the circumference of about 600 billion lightyears proper distance NOW assuming the whole thing is finite. which is an assumption.) And then we could say that the circumference (and the r.o.c.) are both growing currently at rate of 1/140 percent per million years.
Then we would have a handle on your question. Something mathematically well defined.
And we would say WHOA! if you are running a race between that and the Hubble radius, in simple km/second terms, the Hubble radius is expanding much much slower! The expansion of the Hubble radius has slowed way way down since earlier times. It is actually due to level out to asymptote. You know how the function f(x) = 1 + 1/x levels out to 1 without ever quite getting there?
Except for the fact that "radius of universe" is so far not mathematically well defined, I would say that it is expanding more rapidly than Hubble radius. Talking in km/second terms.
Shashanka's question inspired me to look into just how fast the Hubble radius is increasing at present.
Remember it is c/H where H is the Hubble rate. We don't know H precisely, there is an errorbar, but we know it pretty close. For definiteness let's take the present value to be 71.
Using Morgan's calculator I see that H is losing two points per billion years. That is, a billion years in future it will be about 69 km/sec per megaparsec (if it is 71 now.)
But billion years is too big a time step, the rate of change is not constant. So it would be more accurate to say that H is losing 0.002 per million years.
That is, if it is 71 now, in a million years it will be 70.998.
Hubble radius now: 300000/71 = 4225.35 megaparsecs
Hubble radius in a million years: 300000/70.998 = 4225.47 megaparsec
I think you can see that the radius is growing by 0.12 parsecs per year.
If you put ".12 parsecs in light years" into google window it will say something like .4 light year. It actually says 0.39, but this is just approximate. So the radius grows 0.4 lightyear in one year.
This means the Hubble radius is growing at a rate of 0.4c. Forty percent of the speed of light.
Say the galaxy that emitted you is receding 1.1c. So you are receding from us at net rate of 0.1c. Then the radius is getting closer to you at rate 0.3c. Even though you are being swept back some, for now, you are eventually going to be all right.
So if you are a photon which is heading towards us, trying to get to us, and you are outside the radius so you are being swept back, just hang in there. If you are not being swept back too fast, the radius will expand and take you in. Then you will be in territory that is not receding >c from us. Like maybe you will be in territory receding at 0.9, then since your own forward progress is 1.0 you will be gaining ground at the rate 0.1 c. Your actual distance from us will be decreasing at that rate. And it only gets better after that.
this is just one way to put into words what the math model says (the model that is implemented in calculators like Morgan and Wright's). There can be several verbal ways to describe the same math picture. No one unique correct way to tell the story verbally.
Likes Vijay Raghavan
Imax said:
I have a hard time understanding this. How can anything go faster than the speed of light? Something like:
http://www.wired.com/wiredscience/2011/09/neutrinos-faster-than-light
Nothing is moving IN space faster than c. Things are moving relative to each other faster than c because the space in between them is expanding. THAT expansion is nowhere occurring faster than c but over vast enough distances the cummulative effect is to move things apart faster than c. This does not violate the speed limit so nobody gets any traffic tickets.
When largscale (extragalactic) distances expand uniformly, nobody gets anywhere. So it is not like ordinary motion.
If you think of it as ordinary motion you will get confused. It is changing geometry.
Google "wright balloon model" Seriously. Watch a few minutes of the animation. Notice that NONE OF THE GALAXIES ARE MOVING. Each galaxy stays at the same latitude longitude location on the 2D surface. (In that 2D model all existence is on a 2D surface,there is no inside or outside of the balloon.)
The wriggly things that actually move are light photons. They always move at the same speed. Watch carefully. You will see the distance between two galaxies growing faster than the photons move, if you choose two galaxies which are far enough apart.
Reasoning in words will not help you if you do not visualize properly. Watch the animation to help get the right mental pictures into your head and you will understand.
The core idea of Gen Rel is that geometry is dynamical. Dynamical means able to change, not static. Don't think of expanding geometry as motion. Think of it simply as increasing distances. In Gen Rel it is the METRIC which expands. The metric, or distance function, is what represents the geometry.
Hubble has found quasars which are found to be over 27billion ly away. It just indicated expanding universe.
I agree let it be what ever it wants to be, unless it is a she, in which case she can't be what ever she wants to be.
:tongue:
1. Can we directly observe the Big Bang?
No, we cannot directly observe the Big Bang. The event occurred approximately 13.8 billion years ago, and we do not have the technology or capability to observe something that far away in space and time.
2. How do we know the Big Bang happened?
We know that the Big Bang happened based on various pieces of evidence, including the cosmic microwave background radiation, the abundance of light elements in the universe, and the expansion of the universe. These observations support the theory of the Big Bang.
3. Can the Big Bang be disproved?
While the Big Bang theory is the most widely accepted explanation for the origin of the universe, it is still a scientific theory and subject to revision or rejection if new evidence is discovered. However, there is currently no evidence that disproves the Big Bang.
4. What are some alternative theories to the Big Bang?
Some alternative theories to the Big Bang include the Steady State theory, the Oscillating Universe theory, and the Multiverse theory. However, these theories have not been supported by the same level of evidence as the Big Bang theory.
5. Are there any flaws in the Big Bang theory?
Like any scientific theory, the Big Bang theory has its limitations and unanswered questions. For example, it does not fully explain the origin of dark matter and dark energy, and the singularity that is said to have existed at the beginning of the universe is still not well understood. However, these limitations do not necessarily disprove the Big Bang theory.
  • Cosmology
  • Cosmology
