Homework Help: Bijection between AxB and BxA
  1. Dec 27, 2008 #1
    Show that there is a bijective correspondence of AxB with BxA.
    2. Relevant equations
    3. The attempt at a solution
    I am lacking the general understanding of this. Can I create a function g such that,
    g: (a in A, b in B) --> (b in B, a in A).
    If A and B are sets, then are AxB and BxA the same?
  3. Dec 27, 2008 #2
    Dick
    You just did create such a function. If (a,b) is in AxB, then let g((a,b))=(b,a), which is what you said, if not what you meant. (b,a) is in BxA. Now you just have to prove it's a bijection
  4. Dec 27, 2008 #3
    HallsofIvy
    Yes, you can do that. Now you have to prove that is a "bijection": its both "one-to-one" (an injection) and "onto", (a surjection).
    No, absolutely not! But there exist an injection between them so they have the same "cardinality". For example, if A= {x} and B= {y} then A x B= {(a, b)} and B x A= {(b, a)}. Those two sets have the same cardinality (1) but are different sets because they contain different pairs: as an ordered pair, (a, b) is NOT the same as (b, a).
  5. Dec 28, 2008 #4
    But only if WLOG A is not an empty set, because the Zermelo–Fraenkel set theory (the standard set theory) defines in the "axiom of empty set" that there isn't an a in A.
    [tex]\exists X\, \forall y\, \lnot (y \in X)[/tex]
    And do not forget to make your answer save to sets with infinite cardinality.
  6. Dec 28, 2008 #5
    Hurkyl
    Staff Emeritus
    It's not clear exactly what you're saying. But it doesn't seem to be relevant to anything anyone else said.
  7. Dec 28, 2008 #6
    Sorry, my english is not very good, but i will try to explain it.
    You can not prove a bijective correspondence of AxB with BxA for any set A, B by an function that says nothing for empty sets.
    The function says:
    The "axiom of empty set" says:
    It means that there is an set A with no a in A. We call it emtpy set.
    If you look again at the function g you will see that it is not defined for empty sets. Because if WLOG (Without loss of generality) A is the empty set, there is no a in A and so you dont know what (a in A, b in B) --> (b in B, a in A) means, or do you know what (,) -> (,) means?
    So if you prove that g: (a in A, b in B) --> (b in B, a in A) is bijective, than you only know that there is a bijective correspondence of AxB with BxA when neither A nor B is an empty set.
    Sure it is trivial that there is a bijective correspondence of {} and {}, but if you have to answer an basic question it should be an complete anwser without the "trivial"-option.
    If i have to correct such an answer i would mark this point red, so i wanted to show this point before anyone will really mark this answer red.
  8. Dec 28, 2008 #7
    Actually, the function definition [itex]f:A \times B \rightarrow B \times A: (a,\ b) \mapsto (b,\ a)[/itex] is perfectly valid even in the case where at least one of A or B are empty. Why? Because in that case, [itex]A \times B = \emptyset[/itex], so it is http://en.wikipedia.org/wiki/Vacuous_truth" [Broken]).
  9. Dec 29, 2008 #8
    Hurkyl
    Staff Emeritus
    You're use of 'WLOG' here is incorrect; assuming A to be empty is a loss of generality.
  10. Dec 29, 2008 #9
    HallsofIvy
    "Your use of 'WLOG'":devil:
