Binary long division
I'm trying to divide 1010 by 1001
So far all I have is
_1___________
1001 |1010.000000000
1001
0001
I know that 1001 divides into 0001 0 times, but I don't know how to continue..
Answers and Replies
vela
Staff Emeritus
Education Advisor
15,093
1,672
You do the same thing you do when you long-divide using decimals. Append that 0 to the quotient and then bring down the next digit from the dividend.
So for the next part of the quotient I divide 00010 (by bringing the 0 down) by 1001.
Right?
I like Serena
6,579
176
Let's see.
As you should be aware, this will take you into the decimals (binoms??!).
Code:
1001/1010\1.
     1001
vela
Staff Emeritus
Education Advisor
15,093
1,672
OK, so you had 1001 go into 1010 once, leaving a remainder of 1:
Code:
          1.
1001 | 1010.000000000
       1001
Now you bring down the 0 from the dividend and tack it onto the remainder:
Code:
          1.
       1001 |
       ---- v
          1.0
1001 goes into 10 zero times (just ignore the binary point), so tack on a 0 to the quotient:
Code:
          1.0
       1001
          1.0
Then bring down another 0 and tack it onto the remainder:
Code:
          1.0
       1001  |
       ----  v
          1.00
Repeat. You should be able to see you're going to have to bring down two more 0's before anything new happens:
Code:
          1.000
       1001    |
       ----    v
          1.0000
I like Serena
6,579
176
Hmm, no divide 1010 by 1001...
The result is 1.0....
Edit: as vela said! (Wow!!!)
6,876
The key is that each step of the division will give you either 0 or 1. If the number you are currently dividing is less than the divisor (the number you are dividing by), you write down a 0 digit, and bring down another digit. If the number you are dividing is greater than or equal to the divisor, you write down a 1 digit, and subtract the divisor from the number you were dividing. Continue the process as long as necessary. This is just like normal long division.
I like Serena
6,579
176
@Mark44: Congratulations! :smile:
But don't you feel you lost something, now that it is no longer clear that you are a homework helper?
(Please do not make me a mentor. I'm not ready for that yet! :wink:)
6,876
Thanks! Yeah, I kind of miss the Recognitions panel, with its badges for contributor, HH, and Science Advisor that I had. Oh, well...
I've gotten this
______1.000111____
1001 | 1010.000000000000
-------1001
-------0001.0000
------------1001
------------1110
--------------1001
----------------1110
And it just stays going like this :confused:
6,876
Yes, that's as it should be. If you use long division to divide 10 by 9, you get 1.1111111... The same kind of thing is happening when you divide the same numbers in binary form.
Instead of 1.11111... (base-10), you're getting 1.000111 000111 ... (base-2).
But if I stay going on I get 1.00011111111111111 on the quotient?
vela
Staff Emeritus
Education Advisor
15,093
1,672
Recheck your subtraction of 1110 and 1001.
Ah I see my mistake! Thanks! :smile:
Related Threads on Binary long division
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
