Homework Help: Binary multiplication help
  1. Mar 12, 2013 #1
    How do you multiply 111x111. Every exemple i ve found on internet is 101x100, 110x101 and it doesnt answer to my question :|.
    Code (Text):
             111x
             111=
             111+
            111+
           111
    Every exemple ive found is like :))
      110+
      101
    Which is obviously easy...
    The problem i have is the summing of 111+111+111, when i get 1+1+1=??? I cant understand how this works in binary :|.
  3. Mar 12, 2013 #2
    SteamKing
    Staff Emeritus
    If you have 9+9+9 in decimal, how does that work?
  4. Mar 12, 2013 #3
    i keep the first digit and i add it with the next digits.
    But if i have to sum 1+1+1 in the sum coulm This is (1+1+1+1)=(10+1+1)=100, what i do here, i keep the last digit and i add 10 to the next sum, this is what i dont understand.
  5. Mar 12, 2013 #4
    SteamKing
    Staff Emeritus
    It's probably easier to see what to do if you add two binary numbers at a time.
    If you have (binary) 111 + 111, then, starting from the rightmost column,
    1+1 = 10, write down 0, carry 1 back to the next column to the left
    1+1+1 = 11, write down 1,carry 1 back to the next column to the left
    1+1+1 = 11, the sum becomes
    11 1 0 is the final result
    check, 7+7 = 14 (decimal)
  6. Mar 12, 2013 #5
    Mark44
    Staff: Mentor
    To back up a bit from what SteamKing said, there are four addition facts that come into play.
    1. 0 + 0 = 0
    2. 0 + 1 = 1
    3. 1 + 0 = 1
    4. 1 + 1 = 10
    The only one of these that deserves discussion is the last: 1 + 1 = 0, and you carry 1 to the next higher place.
Have something to add?
Draft saved Draft deleted
