1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Binary operation
  1. Oct 30, 2008 #1
    A binary operation is defined by:
    the set of 2 x 2 matrices with real entries under matrix multiplication.
    Find the identity element and the inverse.
    2. Relevant equations
    identity element: a[tex]\o[/tex]e=e[tex]\o[/tex]a=a
    inverse: a[tex]\o[/tex]b=b[tex]\o[/tex]a=e
    3. The attempt at a solution
    I think that the identity element is a 2 x 2 matrix of zeroes with 1's along the diagonal. but how do i find the inverse b?
    Thank you.
  3. Oct 30, 2008 #2
    Staff Emeritus
    In general A will not have an inverse B such that AB = Identity. The brute force method is try multiplying a matrix with elements a,b,c,d with a matrix with elements e,f,g,h such that the resulting matrix is the identity. Find e,f,g,h in terms of a,b,c,d. The hint is that ad-bc is going to have to be non-zero for you to be able to solve this equation (because you have to divide by ad-bc)
  4. Oct 30, 2008 #3
    so if i do this, i get:
    why do i divide by ad-bc?
  5. Oct 30, 2008 #4
    Staff: Mentor
    'cause you're not done yet. You have to find the numbers e, f, g, and h in order to say what the inverse is for a given matrix A.
    Here are a couple of 2 x 2 matrices, one of which has an inverse and the other doesn't.
    A = [1 1; 0 2] (listed by rows)
    B = [1 2; 3 6] (ditto)
  6. Oct 31, 2008 #5
    ok i see what you mean, i found e, f, g, and h:
    Now, what if i had to find the identity element and inverse of a set of 2 x 2 matrices with non-zero determinant (under matrix multiplication).
    Does this mean that no such 'b' exists?
  7. Oct 31, 2008 #6
    Staff Emeritus
    If the determinant is non-zero (i.e. ad-bc =/= 0) then you pick your matrix (e,f,g,h) just as you found in your post. Hence in the set of all matrices with non-zero determinant, the identity matrix is the identity, and inverses exist just as you found. It's only when ad-bc=0 that you can't find an inverse
