icanpartseas
- 1
I have to write a C++ binary search code where it generates the first 100 odd numbers and the search is used to the find the # 23 any help? I am ompletely lost
A binary search is a method of searching through a sorted array or list to find a specific element. It works by dividing the array in half and comparing the target element to the middle element. If the target element is equal to the middle element, the search is complete. If the target element is smaller, the search is continued in the lower half of the array. If the target element is larger, the search is continued in the upper half of the array. This process is repeated until the target element is found or the array is exhausted.
A binary search algorithm works by repeatedly dividing the search space in half until the target element is found. It starts by comparing the target element to the middle element of the array. If they are equal, the search is complete. If the target element is smaller, the search continues in the lower half of the array. If the target element is larger, the search continues in the upper half of the array. This process is repeated until the target element is found or the array is exhausted.
A binary search is more efficient than a linear search because it has a time complexity of O(log n), while a linear search has a time complexity of O(n). This means that a binary search takes significantly fewer steps to find the target element, particularly for larger arrays, compared to a linear search which has to examine each element one by one.
The following is the syntax for implementing a binary search in C++:
int binarySearch(int arr[], int target, int low, int high) {
while (low <= high) {
int mid = low + (high - low) / 2;
if (arr[mid] == target) {
return mid;
} else if (arr[mid] < target) {
low = mid + 1;
} else {
high = mid - 1;
return -1;
There are a few ways to optimize a binary search algorithm in C++. One way is to check if the target element is equal to the middle element at the beginning of the search, instead of waiting until the end. This can save unnecessary comparisons. Another way is to use a jump search, which involves skipping elements instead of dividing the array in half. This can be more efficient for larger arrays. Additionally, making sure the array is sorted beforehand can also improve the efficiency of the binary search algorithm.
