Binary search tree address book interface
  1. Nov 4, 2006 #1
    I'm developing this using Visual C++ (I blew up my Ubuntu with new dist, so no linux )
    My assignment is to write an address book that is based on a binary search tree. I've written the search tree, and I've written another file that builds the address book. Thing is, I can only access the binary search tree (bst) if I include the root node in each of the functions.
    addPerson(treeNode *&root, string person)
    mind you, I've declared treeNode *root as a protected member.
    The driver that the teacher will use will access files that look more like this:
    addPerson(string person)
    so the other won't work.
    Hers is my code as it stands, with a little test program. I'm only working with the name part right now just to get basic operations to work:
    Code (Text):
    #ifndef binarySearchTree_h
    #define binarySearchTree_h
    #include <string>
    #include <iostream>
    using namespace std;
    //Define the node
    struct treeNode
    //An object of type TreeNode
        string data;
        treeNode *left;
        treeNode *right;
    treeNode(string str)
            //constructor: Make a node containing str.
        data = str;
        left = NULL;
        right = NULL;
    //define the class
    class binarySearchTree
    public:
        binarySearchTree();
            //constructor
        void treeInsert(treeNode *&root, string newItem);
            //Add an item to the binary sort tree
            //to which the parameter 'root' refers.
        void treeDelete(treeNode *&root, string deleteItem);
            //Delete an item from the binary sort tree
        void inOrderPrint(treeNode *&root);
            //Print all the items in the tree to which
            //the tree points
        int countNodes(treeNode *&root); //added int count, removed treeNode *&root
            //count the nodes in the binary tree
            //and return the answer
        bool isEmpty(treeNode *&root) const;
            //returns true if tree is empty
        bool treeContains(treeNode *&root, string data);
            //return true if item is one of the items in the
            //binary sort tree to which root points. Return
            //false if not
    protected:
        treeNode *root;
    #endif
    #include "binarySearchTree.h"
    #include <string>
    #include <iostream>
    binarySearchTree::binarySearchTree() :root(NULL)
    void binarySearchTree::treeInsert(treeNode *&root, string newItem)
        if(root == NULL)
            //the tree is empty.  Set root to point to a new node containing
            //the new item.  This becomes the only  node in the tree.
            root = new treeNode(newItem);
            //left and right subtrees of root are automatically set to NULL by
            //the constructor
            return;
        else if(newItem < root->data)
            treeInsert(root->left, newItem);
        else
            treeInsert(root->right, newItem);
    }//end treeInsert
    void binarySearchTree::treeDelete(treeNode *&root, string deleteItem)
        treeNode *previous, *tmp = root;
        if(root == NULL)
            //the tree is empty
            cout << "The tree is empty, can't delete from an empty tree" << endl;
        else if(root->right == NULL)
            root = root->left;
        else if(root->left == NULL)
            root = root->right;
        else
            tmp = root->left;
            previous = root;
            while(tmp->right !=NULL)
                previous = tmp;
                tmp = tmp->right;
            root->data = tmp->data;
            if(previous == root)
                previous->left = tmp->left;
            else previous->right = tmp->left;
        delete tmp;
    }//end deleteNode
    void binarySearchTree::inOrderPrint(treeNode *&root)
        //the tree points
        if(root !=NULL)
                //otherwise, there is nothing to print
            inOrderPrint(root->left); //prints items in left subtree
            cout << root->data << " ";//print the root item
            cout << endl;
            inOrderPrint(root->right);//print the items in rigth subtree;
    }//end inOrderPrint()
    int binarySearchTree::countNodes(treeNode *&root)
        if(root==NULL)
            return 0;  //the tree is empty
        else
            int count = 1;  //start by counting the root
            count += countNodes(root->left);  //add the number of nodes
                                              //in the left subtree
            count += countNodes(root->right); //add the number of nodes
                                              //in the right subtree
            return count;  //return the total
    }//end countNodes
    bool binarySearchTree::isEmpty(treeNode *&root) const
            //return true if tree is empty
        return (root == NULL);
    bool binarySearchTree::treeContains(treeNode *&root, string data)
            //false if not
            if(root==NULL)
                //tree is empty
                cout << "Can't search an empty tree " << endl;
                    return false;
            if(data==root->data)
                //item has been found
                return true;
            if(data < root->data)
                //item is in left subtree
                return treeContains(root->left, data);
            else
                //item is in right subtree
                return treeContains(root->right, data);
        } //end treeContains()
    #ifndef person_h
    #define person_h
    #include <iostream>
    #include <string>
    class person: public binarySearchTree
        friend ostream& operator<<(ostream&, const person&);
    public:
        void setPersonalInfo(treeNode *&root, string name, string address,
                          string phoneNum);
        //Function to set the details of a video.
        //The private data members are set according to the
        //parameters.
        //Postcondition:  personName = name;
        //      personAddress = address;
        //      personPhoneNum = phoneNum;
        //      numInBook = setNumInBook;
        void printName(treeNode *&root) const;
        //Function to print the names located in the address book;
        void printInfo() const;
        //Function to print the name and addresses in the address book;
        bool checkName(string name);
        //Function to check if the name is already in the address book;
        string getName();
        //Function to return a name from the address book;
        person(string name = "" , string address = "",
                  string phoneNum = "");
        //constructor
        //The private data members are set according to the incoming parameters;
        //If no values are specified the default values are assigned.
        void addPerson(treeNode *&root, string name); //, string address, string phoneNum);
        //Function to add a name and info to the address book;
        void deletePerson(treeNode *&root, string name);
        //Function to delete a name from the address book;
        void findPerson(treeNode *&root, string name);
        //Function to find a name located in the address book;
        void modifyPerson(string name, string address, string phoneNum);
        //Function to modify an entry in the address book;
        //overload relational operators:
        bool operator==(const person&) const;
        bool operator!=(const person&) const;
        bool operator<(const person&) const;
        bool operator<=(const person&) const;
        bool operator>(const person&) const;
        bool operator>=(const person&) const;
    private:
        string personName;          //variable to store the name;
        string personAddress;       //variable to store the address;
        string personPhoneNum;      //variable to store the phone number;
    #endif
    #include <iostream>
    #include <string>
    #include "person.h"
    /**Function to set the details of an entry.  Private members are
       set according to the parameters.
    void person::setPersonalInfo(treeNode *&root, string name, string address,
                                 string phoneNum)
        personName = name;
    /**Function to print the names located in the address book; */
    void person::printName(treeNode *&root) const
        binarySearchTree tmp;
        tmp.inOrderPrint(root);
    /**Function to print the name and addresses in the address book;*/
    void person::printInfo() const
        cout<<"Name: "<< personName<<endl;
        cout<<"Address: "<< personAddress <<endl;
        cout<<"Phone Number: "<< personPhoneNum<<endl;
    /** Function to check if the name is already in the address book;  */
    bool person::checkName(string name)
        return(personName == name);
    /** Function to return a name from the address book;  */
    string person::getName()
        return personName;
    /** constructor
                numInBook = setNumInBook;  */
    person::person(string name, string address,
                         string phoneNum)
        setPersonalInfo(root, name, address, phoneNum);
    /**Function to add a name and info to the address book; */
    void person::addPerson(treeNode *&root, string name)
        tmp.treeInsert(root, name);
    /**Function to delete a name from the address book; */
    void person::deletePerson(treeNode *&root, string name)
        tmp.treeDelete(root, name);
    /**Function to find a name located in the address book;  */
    void person::findPerson(treeNode *&root, string name)
        if(!tmp.treeContains(root, name))
            cout<<name<<" not found"<<endl;
        else
            cout << name << " found" <<endl;
    /**Function to modify an entry in the address book;  */
    void person::modifyPerson(string name, string address, string phoneNum)
        //to be added later
    /** overload the relational operators */
    bool person::operator==(const person& right) const
        return (personName == right.personName);
    bool person::operator!=(const person& right) const
        return (personName != right.personName);
    bool person::operator<(const person& right) const
        return (personName < right.personName);
    bool person::operator<=(const person& right) const
        return (personName <= right.personName);
    bool person::operator>(const person& right) const
        return (personName > right.personName);
    bool person::operator>=(const person& right) const
        return (personName >= right.personName);
    ostream& operator<<(ostream& os, const person &person)
        os<<endl;
        os<<"Name: "<< person.personName <<endl;
        os<<"Address: "<< person.personAddress << endl;
        os<<"_____________________________________"<<endl;
        return os;
    #include "person.h"
    #include <iostream>
    int main()
        person myList;
        binarySearchTree list;
        treeNode *root;  //pointer to the root noode in the tree
        root = NULL;  //start with an empty tree
        string someName;
        int choice;
        int num = 0;
        cout << "What would you like to do? "<< endl;
        cout << "1=insert" << endl;
        cout << "2=count the nodes" << endl;
        cout << "3=print the nodes" << endl;
        cout << "4=delete a node" << endl;
        cout << "5=find a name" << endl;
        cout << "9=exit "<< endl;
        cout << endl;
        cin >> choice;
        cin.ignore(100, '\n');
        while(choice !=9)
            switch (choice)
            case 1: cout << "Enter a name for the list: " ;
                    getline(cin, someName);
                    myList.addPerson(root, someName);
                    break;
            case 2: cout << "The number of nodes in the tree are: ";
                    num =  list.countNodes(root);
                    cout << num ;
                    break;
            case 3: cout << "Here is the list: " << endl;
                    myList.printName(root);
                    break;
            case 4: cout << "What item to delete? ";
                    myList.deletePerson(root, someName);
                    cout << someName << "is deleted." << endl;
                    break;
            case 5: cout << "What name are you searching for? ";
                    myList.findPerson(root, someName);
                    break;
            default: cout << "Invalid selection" << endl;
            } //end switch
        cout << endl;
        cout << endl;
        cin >> choice;
        cout << endl;
        }//end while
        cout << endl;
        return 0;
