Constructing a Driftwood Arbour
  • Thread starter DaveC426913
In summary: I think I'll just stick with cable ties.In summary, DaveC426913 is trying to make an arbour out of driftwood branches he collected from the shore. He is having trouble figuring out a way to bind the sticks together and fears that nails or screws will weaken the wood, some of which is already split. He is considering using black cable ties, but is also concerned about how well they'll blend in. He is also worried about how much pounding the structure will take (from snow loading and riotous kids). If the wood is thick enough, he plans to drill holes in adjacent pieces and epoxy rebar in to make it " pinned" together. He is also considering using something like
DaveC426913
6,168
OK. DaveC426913's Project 437b.211 - Driftwood Arbour.
I plan to make an arbour (i.e. archway) out of driftwood branches I collected from the shore.
Think of it as the love child of http://www.kellys-eye.co.uk/images/products/0.023196001096289851_albion_arbour_l.jpg" . (Note that there is no internal or external bracing in an arbour.)
The trouble I'm having is figuring out how to bind the sticks together. Nails or screws (with pilot holes) I fear will weaken the wood so that it will split. Some is split already. The driftwood lumber is between 1/2" and 2 inches in diameter.
I was thinking of catgut or leather thongs, but will they slip? It needs to be secure enough for a 7'x3'x3' structure to be rigid.
I want a binding material that:
- is strong enough to last outdoors year round
- will hold well enough to ensure the arbour is rigid
- will minimize weakening of the wood
- won't look hideous (metal strapping, cables or bolted metal bands would meet all the other criteria, but would look hideous)
Black cable ties, they are strong will not rot and should blend in.
Yeah, ties would maybe work, but there's a lot of flexibility to them. I'm also not too sure how well they'd blend, but with so many colours available it shouldn't be a problem. I just wonder how much of a pounding this thing will have to take (I'm thinking Ontario snow-loading as well as the normal wind and riotous kids).
If the wood is thick enough, I'd be very inclined to drill holes in adjacent pieces and epoxy rebar in so the pieces are 'pinned' together like a broken leg.
That being said, the leather lacing would work pretty well (better than plastic) if you apply it soaking wet and then let it dry. It'll cinch down just as if you use a come-along on it.
If you want to avoid having too many fasteners showing, you might want to try creating joints that don't need as much of those wherever you can. Mortise and tenon joints might work best for most of the cross pieces to attach to your side supports. Then use other fasteners for either the pieces that are too split to cut into those sorts of joints and use screws in the strongest pieces to hold it all together.
Depending on whether it fits with the look you're going for, you might be able to use something like grapevine to wrap around and disguise some of the fasteners. That would still keep the rustic look of driftwood.
I can't see how they'd blend. If they're visible at all, they should be of ... theme-compatible materials - anything organic. But even metal is more compatible than plastic.
Definitely a concern wit da kiddies.
That is a great idea - like good carpentry. (But it is likely a whole lot of work...) I'll seriously consider it.
Yeah. Do you know any tips about doing this? Is it just wet, apply, let dry?
The hits I got from Googling "leather thong binding" were ... um let's say ... not applicable.
:rofl: You better turn "safe search" on. :rofl:
I don't know if you'd need to dry with heat, or just let the leather naturally dry. I'd think heat would help it shrink tighter.
Links, please. :biggrin:
I'd probably soak the leather in a tub of water for a day or two anyhow. I don't really know an awful lot about it. I do know, however, that at least one native North American culture used to bind wet thongs around the heads of the their victims and leave them out in the sun until their skulls cracked open. That takes a lot of force.
That's an awesome site, Woolie. Love the 'firepiston' article.
One does ones best old chap, there is an art in googling dontcha know
:rofl: :rofl:
What kind of ... establishment ... would one approach to ask questions about tying with rawhide or leather?
One of my friends was (until an injury) an exceptional saddlemaker. He made the holsters, chaps, etc. for several movie productions, including 'Tombstone'. If anyone would know, he probably will. I've misplaced his number, but see him every couple of weeks. I'll ask him.
C'mon over to the Turbo RV! When one of the sisters answers the door, just let her know you're there for the leather workshop. :biggrin: :devil:
:uhh:
:uhh:
o:)
wolram said:
:rofl: You can eat wet leather thongs :eek: :rofl:
You could try sticking a couple pieces of rebar (coated to minimize rusting) in the ground or holes in a concrete pad, bend to join at the top and clamp.
Drill holes in the pieces and just stack them on the rebar supports.
You could assemble it then plug it into the pad holes.
Waterproof exterior construction adhesive (or epoxy) would help lock the pieces in place.
Or perhaps two parallel pieces of rebar could give more depth and be self locking.
You (or kids) might break individual pieces but you wouldn't have the whole thing come down.
I'd use copper wire, cause it strong enough and also looks great when it weathers.
Yes, I would agree with hypatia, or try copper bands or possibly pipe. Very nice patina after it ages. Copper has gotten pretty expensive around here recently though...
Wet leather doesn't shrink much when dried. It's rawhide that does that. Unfortunately it will loosen back up when it's rewet by fog, rain and melting snow.
The pieces you're using sound too small to create enough overall structural integrity unless each and every join is perfectly rigid and secure. Therefore I think the driftwood over some more solid framework is the only way to go.
Depending on the pieces of drift wood, perhaps one could interweave the wood, and perhaps use fishing line. However, the nylon will embrittle with exposure to sunlight. Perhaps copper wire (from hardware store), as hypatia suggests, is the way to go.
Cool idea. It reminds me of arbors of deer antlers, which I have seen, IIRC Colorado or Wyoming.
And I'll notch the wood.
A growing part of me is thinking that I'm going to go to all this effort and then some kid will come and apply a boot to it...
Jackson Hole, Wyoming.
Just down the street from Ripley's believe it or not.
Didn't quite feel like looking to see how they did it, after visiting the Cowboy Bar acrost the street with my friends, apres ski. :wink:
I dreamt a solution to my troubles the other day.
In my dream, all I did was make the surfaces of the structure (i.e. the walls) 3-dimensional. i.e. rather than make the walls only one rectangle of branches, I should make them two rectangles, 6 inches apart - so each wall is a "box" rather than a "sheet", see?
(see attached, just because I like illustrating ideas...)
It would work. All I have to do is decide if I want my arbour to look like Stonehenge.
Have you considered something along the lines of Spectra?
Here's an expensive Spectra/Kevlar blend: http://knradventuregear.com/webbing_cord/maximspectracord.htm
I think you can get 2mm cord (rated for a couple hundred pounds or thereabouts) for about $0.30 a foot.
Or you can use string. Many brands of fishing line and kite string are made from Spectra.
I've never heard of Spectra, but I could look into it.
Note though, that it does not address my problem (I think). I presume you're pointing me at it because it's so strong? Strength of the binding material is not a problem, strength of the joint is the problem. The advantage of rawhide is that, regardelss of how tight *I* can wrap the joint, the process of drying will dramatically increase that, creating a much stronger joint. Spectra OTOH, does not stretch at all, meaning it will not supply much strength to the joint.
1. What exactly is a driftwood arbour?
A driftwood arbour is a decorative structure made of pieces of driftwood that are arranged and secured together to form a frame. It can be used as a garden feature, a wedding arch, or a cozy seating area.
2. How do you construct a driftwood arbour?
The first step is to collect driftwood pieces of various shapes and sizes. Next, lay out the pieces on the ground to plan the design of the arbour. Then, use a drill and screws to attach the pieces together, making sure to leave gaps for the desired shape and size of the arbour. Lastly, secure the arbour into the ground using metal stakes or concrete.
3. What tools and materials are needed for constructing a driftwood arbour?
The tools needed include a drill, screws, a hammer, and a saw. The materials needed include driftwood pieces, metal stakes or concrete for securing the arbour, and any desired decorations such as string lights or flowers.
4. How long does it take to construct a driftwood arbour?
The time it takes to construct a driftwood arbour depends on the size and complexity of the design, as well as the availability of materials and tools. On average, it can take anywhere from a few hours to a full day.
5. How do you maintain a driftwood arbour?
To maintain a driftwood arbour, regularly check for any loose screws or pieces and tighten or replace them as needed. It is also important to periodically clean the arbour by removing any debris or dirt from the wood. If the arbour is placed outdoors, it is recommended to seal the wood with a clear varnish or paint to protect it from weathering.
