Binomial coefficient
Calculate
[tex]{-3 \choose 0}[/tex], [tex]{-3 \choose 1}[/tex], [tex]{-3 \choose 2}[/tex]
In case of integer ##n## and ##k##
[tex]{ n \choose k}=\frac{n!}{k!(n-k)!}=\frac{n(n-1)(n-2)...(n-k+1)}{k!} [/tex]
I am not sure how to calculate this. Any idea?[/B]
Answers and Replies
haruspex
Insights Author
5,602
I've never worked with such things, but I believe binomial coefficients can be extended to noninteger and negative arguments by using the gamma function instead of factorials. Google it.
Yes but gamma function diverge for integer negative values. So ##\Gamma(-3)=(-4)!=\infty##
haruspex
Insights Author
5,602
Can you avoid that by some cancellation? You will have negative arguments in gamma functions both in the numerator and the denominator.
hilbert2
Insights Author
445
The limit ##\lim_{x\to n}\frac{\Gamma(x+1)} {\Gamma(k+1)\Gamma(x-k+1)}## can exist even if ##n## is negative. Try it with Wolfram Alpha.
Not sure. For example ##{-3 \choose 0}=\frac{(-3)!}{0!(-3-0)!}=1##. This is OK. But in case ##{-3 \choose 1}=\frac{(-3)!}{(-4)!}=\frac{\Gamma(-2)}{\Gamma(-3)}=\frac{-3\Gamma(-3)}{\Gamma(-3)}=-3##
I think this is OK. Tnx :)
Ray Vickson
Dearly Missed
10,706
1,728
Calculate
The standard _definition_ of ##{n \choose k}## for non-negative integer ##k## and general real ##n## is given by the second formula you wrote in Post #1 (i.e., the formula that does not involve ##n!## or ##(n-k)!##). Sometimes that formula can be expressed in terms of Gamma functions, and sometimes not.
Using that definition we obtain
[tex] {-m \choose k} = (-1)^k {m+k-1 \choose k} [/tex]
for integers ##m,k \geq 0##.
Related Threads on Binomial coefficient
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
