Binomial Dist.
  1. Jan 8, 2014 #1
    Hello all,
    I just have a question which covers binomial distribution.
    Sally is a goal shooter. Assume each attempt at scoring a goal is independent, in the long term her scoring rate has been shown as 80% (i.e. 80% success rate).
    Question:
    What's the probability, (correct to 3 decimal places) that her first 4 attempts at scoring a goal are successful, given that exactly 6 of her first 8 attempts are successful?
    I've solved the problem the following way.
    X~ Bi(8,0.8)
    Pr(X=6) = 0.8^6*0.2^2 = 0.0105
    Pr(X=4) = 0.8^4*0.2^4 = 0.0007
    Pr(X=4 | X=6) = Pr(X=4 & X=6) = Pr(X=4) = 0.0007 = 0.067
    ------------------- ---------- --------- <--------divided signs
    Pr(X=6) Pr(X=6) 0.0105
    Note:{'&' means Intersection}, the answer given = 0.214. Is that correct?
    I would like your thoughts.
    Note: The previous two parts of the same question are (where the above is part iii):
    (i) chance of getting 8 out of 8 shoots as goals.
    (ii) change of getting exactly 6 out of 8 shoots as goals.
    ref: MathsQuest(Yr-12)
  3. Jan 8, 2014 #2
    Simon Bridge
    Need the reasoning.
    ##p^n(1-p)^{N-n}## is the probability of n successes out of N trials.
    It is not the probability that those n successes are the first n of them.
    The probability P(X=6) you gave is the probability that any six are successes right?
    If I read you correctly:
    The probability P(X=4) you gave is the probability that any four of the trials are successes.
  4. Jan 10, 2014 #3
    Office_Shredder
    Staff Emeritus
    Pr(X=4 | X=6) is zero, because if X=6 it is never equal to 4.
    Some food for thought: Does this part of the question even require knowing what Sally's probability of scoring each individual goal is?
  5. Jan 10, 2014 #4
    haruspex
    Umm.. backwards?
    ##p^n(1-p)^{N-n}## is the probability of n successes out of N trials, and those being the first n.
    ##^NC_np^n(1-p)^{N-n}## is the probability of n successes out of N trials, those being any n.
  6. Jan 10, 2014 #5
    Simon Bridge
    @haruspex:
    I picked the right issue but got it backwards - thanks.
    <annoyed with self>
    Advise to OP would be to be more careful about defining events.
    Off the wording in post #1,
    It looks like X is the number of trials that are successes
    So X=x would be the event that exactly x trials were successes.
    P(X=x) equation given was for the event that a particular x trials were a success.
    P(X=x|X=y) equation... was for different X again?
    By the first definition of X: P(X=x|X=y)=0 unless x=y - so that's not what is intended!
    How about:
    X is the event that the 1st n out of N trials are successes - the remaining N-n trials being anything.
    Y is the event that any m out of the N trials are successes
    X[itex]\small\cap[/itex]Y would be the event that there are m successes in N trials, in which the 1st n trials are successes.
    ... or something.
  7. Jan 28, 2014 #6
    sorry for not getting back sooner. Thanks for responses,
    To both of the above comments.
    Correct. The intersection is equal to 0.
    If we consider the problem as a tree diagram, there are 6 branchs of X=6 given the first 4 shots are successfull.
    and given;
    Pr(x=6) = 0.2936 (exactly 6 isn't the same as only 6, my bad).
    Therefore:
    (6*0.8^6*.2^2)/0.2936 = 0.214
  8. Jan 28, 2014 #7
    haruspex
    That's the right answer.
    The easiest way is to to turn it into: pick 6 objects from 8 in a line; what's the probability you pick the first 4? A: 4C4*4C2/8C6
Have something to add?
Draft saved Draft deleted
