Binomial Distrinution - is my answer reasonable?
  • Thread starter KataKoniK
  • Tags
    Binomial
In summary, the simplest error detection scheme used in data communication is parity-checking. This involves appending a 0 or 1 to the end of each character sent to make the number of 1's even. If the number of 1's in a received character is odd, it indicates an error. In order to determine the probability of an undetected error, we need to consider the probability of 2, 4, 6, or 8 errors occurring in a 7-bit transmission. This can be calculated using the binomial distribution formula, where the probability of a single error in a 7-bit character is 0.001. The total probability of an undetected error is then 1 minus the sum
KataKoniK
1,347
Q: The simplest error detection scheme used in data communication is parity-checking. Messages sent consists of characters, each character consisting of a number of bits, 0 or 1. In parity checking, a 0 or a 1 is appended to the end to make the number of 1's even. The receiver checks the number of 1's in every character received and if the result is odd, it signals an error. Suppose that each bit is receveid correctly with probability of 0.999 independently of other bits. What is the probability that a 7bit character is received in error and not dected by the parity check?
The equation I used is this one
http://mathworld.wolfram.com/BinomialDistribution.html
My answer:
p(no error in 7-bits) = (7 choose 0) * (.001)^0 (1 - .001)^7 = .99302
p(single error in 7-bits) = (7 choose 1) * (.001)^1 (1 - .001)^6 = .00696
p(undetected error in 7-bit transmission) = 1 - p(no error in 7-bits) - p(single error in 7-bits)
= 1 - .99302 - .00696
= .00002
Correct? Resonable?
Thanks in advance.
no, that isn't what it's getting at. there can be two errors, or 4 and that woul'dnt be boticed. the q asks what is the chance of an even number of errors
Hmm,
Can you give me a hint on what I need to do?
Do 7 choose 2? and so forth? up to 7 choose 7? Then do 1 - the sum of all those values?
yes that is what you ned to do
Thank you matt. Also, one last question, we don't need this p(no error in 7-bits) = (7 choose 0) * (.001)^0 (1 - .001)^7 = .99302 right?
wait on. why are youi working out the probablity of 1,3,5 or errors? they would be detected sicne they cange the parity. you need to know the probabilty of 2,4 or 6 errors, that is all. does the 7bit char include the error correciting bit? ie are 8 bits received?
Thanks for the heads up. So, from what you are saying, I just need to determine
p(single error in 7-bits) = (7 choose 2) = answer
p(single error in 7-bits) = (7 choose 4) = answer
p(single error in 7-bits) = (7 choose 6) = answer
Then the ans after getting all those values would be
p(undetected error in 7-bit transmission) = 1 - (those 3 values added together)?
I am a little bit confused here.
I don't think the 7bit char includes the error correcting bit, so 8 bits are not going to be received, if that's what you mean.
no no no!
you receive 8 bits. no error is detected if an even number of errors occured. what is the probability of an even number of errors? basic binomial distribution question.
if p is prob of error on any given bit, P(two errors in 8) is (8choose2)p^2q^6 where q=1-p.
P(4errors) is (8choose4)p^4q^4
P(6errors) is (8choose6)p^6q^2
P(8errors) is (8choose8)p^8=p^8
Hmm, I am bit more confused now, sorry. So we hvae to threat the question as 8 bits? Even though it says 7? Or was that just an example?
Remember that the pairity bit is also sent across the line, and is subject to the same error possibilities.
So, if I am correct, I must do the following?
p(2 errors in 7-bits) = (8 choose 2) binomial eqn cont. = answer
p(4 errors in 7-bits) = (8 choose 4) binomial eqn cont. = answer
p(6 errors in 7-bits) = (8 choose 6) binomial eqn cont. = answer
p(8 errors in 7-bits) = (8 choose 8) binomial eqn cont. = answer
Then 1 - (those four values added together)?
Maybe it would be clearer if you distinguished between transmitted bits (8) and data bits (7) explicitly. Things might make a bit more sense to you then.
That said, adding up those numbers should give you the correct probability of an undetected error.
Thank you. I understand the reason behind checking for 8-bits, since as you mentioned, "pairity bit is also sent across the line, and is subject to the same error possibilities". We start counting from 0 in this case, so 0-7, which equals 8 bits?
Hmm, understood.
let's do a simple example - 1 bit. so with parity check there are two bits sent.
they must by either 00 or 11. if one error happens we get 10 or 01, which we detect though we don't know what the error is. but if two errors occur we receive 11 or 00 resp. so we don't detect an error.
is it now clear why you need to work out the chances of 2,4,6, or 8 errors?
do you understand how binomial random variables work?
Thanks matt grime for the detailed explanation. Everything is clear now :)
1. What is a binomial distribution?
A binomial distribution is a probability distribution that describes the likelihood of a certain number of successes in a fixed number of independent trials, with each trial having only two possible outcomes (usually referred to as "success" or "failure").
2. How is a binomial distribution calculated?
The probability of a binomial distribution is calculated using the formula P(x) = nCx * p^x * q^(n-x), where n is the number of trials, x is the number of successes, p is the probability of success, and q is the probability of failure (q = 1 - p).
3. What is the difference between binomial and normal distributions?
The main difference between binomial and normal distributions is that binomial distributions are discrete, meaning they have a finite number of possible outcomes, while normal distributions are continuous, meaning they can have infinite possible outcomes. Additionally, binomial distributions are used to model the probability of a certain number of successes in a fixed number of trials, while normal distributions are used to model continuous data with a symmetrical bell-shaped curve.
4. Is my answer reasonable?
To determine if your answer is reasonable for a binomial distribution, you can compare it to the expected value or mean of the distribution, which is calculated as n * p. If your answer is close to the expected value, then it is likely reasonable. Additionally, you can also use a graph or table to visualize the distribution and see if your answer falls within the expected range of values.
5. What are some real-world applications of binomial distribution?
Binomial distribution is commonly used in various fields, such as statistics, finance, and biology. Some real-world applications include predicting the success rate of a marketing campaign, estimating the probability of a stock price increase, and modeling the likelihood of a certain number of mutations in a DNA sequence.
  • Sticky
  • Math Proof Training and Practice
