Binomial series expansion
  • Thread starter sooyong94
For ##n>0##, the expansion of ##(1+mx)^{-n}## in ascending powers of ##x## is ##1+8x+48x^{2}+...##
(a) Find the constants ##m## and ##n##
(b) Show that the coefficient of ##x^{400}## is in the form of ##a(4)^{k}##, where ##a## and ##k## are real constants.
Binomial expansion
I have expanded the series using binomial theorem, and compared each coefficient. Then I solved them using simultaneous equation. That works out to be ##m=-4, n=2##.
(b) I know the binomial coefficient is ##\frac{n(n-1)(n-2)...(n-r+1)}{r!}##, though I'm stuck on that... :(
Answers and Replies
Simon Bridge
17,857
1,655
if ##n=2##, then how can there be an ##x^{400}## term? Why does the provided expansion not terminate?
if m=-4, as well, then wouldn't that mean that the second term in the expansion is -8x instead of the +8x given?
Oops... It should be ##(1+mx)^{-n}##... Sorry about that. :P
Simon Bridge
17,857
1,655
OK - so you have the expansion, in principle, of form:
$$(1+mx)^{-n}=\sum_{i=1}^N a_ix^i$$ ... the coefficient of ##x^{400}## is ##a_{400}## .... and you know that ##a_i## depends on n,m and r from the binomial expansion formula.
You have a formula for the binomial coefficient - but ##a_{400}## has an extra term due to the value of m.
The trick is to match up the values you have with the formulas ... i.e. while n=2 in the equation above, the "n" in the formula for the binomial coefficient is different ... it may help to rewrite the formula taking this into account.
If ##a_{400}## corresponds to the r'th binomial coefficient then what is r?
I don't get it... :/
I know the coefficient of ##x^{400}## would look something like this:
##\frac{-2(-3)(-4)....(-400-2+1)}{400!}##
Though it doesn't look like what the question needs... :S
Simon Bridge
17,857
1,655
You forgot about the value of m ;)
Anyway - you have to show that the series is the same as what they gave you.
Find the value of a and k.
Just to get you thinking the right way: is the product a positive or negative number?
Maybe it is -2x3x4x...x401 or +2x3x4x...x401
.... can you represent it in some kind of shorthand?
Say using factorial notation?
Where's the value of m? :confused:
That actually looks like (401!) ? :confused:
Simon Bridge
17,857
1,655
You said that m=-4 remember?
Notice that the question does not ask for the binomial coefficient.
The coefficient of x^400 includes the binomial coefficient but is not equal to it... just like the coefficient of x^2 is not equal to it's binomial coefficient. Compare.
That's right! So to ratio comes to 401!/400! doesn't it? ... what is that equal to?
Still don't get it on the binomial coefficient though...
I know that 401!/400!=(401x400!)/(400!)=401
Simon Bridge
17,857
1,655
That's all there is to it! Well done ;)
How did you work out that it should be positive rather than negative?
You need the part where "m=4" fits in to make the connection.
Remember, you need to show that ##a_{400}=b(4)^k## where #a_n## is the coefficient of ##x^n## in the polynomial, with b and k both positive real numbers.
Remember, you need to show that ##a_{400}=b(4)^k## where ##a_n## is the coefficient of ##x^n## in the polynomial, with b and k both positive real numbers.
I don't know about that though... :/
But how do I use that m=4? :confused:
Simon Bridge
17,857
1,655
Well consider: what is the coefficient of x and what is the coefficient of x^2?
How does that m=-4 contribute to those coefficients?
How does the binomial coefficient contribute?
You calculated it - you should know!
Write ut the coefficient of x and x^2 in terms of n and m again - instead of actual numbers.
Coefficient of x would look something like this: -nm
Coefficient of x^2 would look something like this: ##\frac{(-n)(-n-1))}{2!} m^{2}##
haruspex
Insights Author
2020 Award
36,231
6,842
Yes. m is just a multiplier on x, so you can start with the expansion for m=1 and just replace x with (mx) in the expansion.
So that means... the coefficient of ##x^{400}## is
##\frac{(-2)(-3)(-4)...(-400-2+1)}{400!} (-4)^{400}## ?
haruspex
Insights Author
2020 Award
36,231
6,842
Yes, but you can get rid of all of those awkward minus signs. Each extra factor like (-400-2+1) inverts the sign, but so does the extra -4 term, so they all cancel.
Erm... why? How does it invert the minus sign? :confused:
I know there are 400 terms, so the signs cancel each other, because 400 is an even number?
haruspex
Insights Author
2020 Award
36,231
6,842
All the terms in the expansion are positive. (−2)(−3)(−4)...(−n−2+1) has n terms, so has the same sign as (-4)n.
How does all terms in the expansion are positive? :confused:
haruspex
Insights Author
2020 Award
36,231
6,842
The first term (1) is positive. To get the second term you multiply by (-2)(-4) = 8. To get the next you multiply be (-3)(-4) = 12. At every step you multiply by two factors, both negative, so the minus signs cancel.
Simon Bridge
17,857
1,655
It may be easier to think of it like this ...
the product of N negative numbers is positive if N is even and negative if N is odd right?
i.e. if ##y=(-x_1)(-x_2)(-x_3)\cdots(-x_{N-1})(-x_N): x_i>0##
then y > 0 if N is even and y < 0 if N is odd.
Can you see why this is the case?
...similarly ##(-4)^N=4^N## if N is even and ##-4^N## if N is odd.
Simon Bridge
17,857
1,655
Back to this:
Good - so what would the coefficient of x^3 look like?
How about x^4?
Follow the pattern to find the expression for the coefficient of x^400 - put in the values of n and m you found and remember posts 4 and 5.
I get it now... :D
Because when you multiply N negative number, and if N is an even number (in this case 400), the signs of each number cancel. :P
Back to this:
How about x^4?
So... that would look something like this...
haruspex
Insights Author
2020 Award
36,231
6,842
Yes, but you should simplify the signs, as you've been shown.
Related Threads on Binomial series expansion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
