- 10
First let me say hello and give an introduction.
I have limited academic experiecnce in Physics receiving a C-grade GCSE at 16.
I then spent over a decade owning a maintaining a number of motorbikes, cars, and light and medium commercial vehicles and some light plant machinery. Mainly for myself for transport and as a self employed gardener /tree surgeon but also helping friends and relitives with their vehicles.
At the end of 1999 I read the book 'From the fryer to the fuel tank' about fuelling diesel engines with vegetable oil and biodiesel and rapidly got sucked into spending far to much time researching the use of vegetable oil as a fuel.
I set up an information website at www.vegburner.co.uk[/url] and later started working at [url]www.bloomingfutures.com[/URL] where I provided the in house expertise on vegetable oil combustion. I held a directorship at this not-for-profit co-operative before leaving last summer.
Since leaving I have continued my experiments and research into fuelling engines with vegetable oil (aka PPO)
I am interested in anybodies thoughts on this subject.
I was also wondering if I could get some guidance.
One of my current projects involves gathering a number of sensors and hooking them up to my laptop to log pertinent data that will allow me to tune engines to run on PPO. I am at an early stage but am following 'crossbones' somewhat pioneering work (as far as I am aware) using glowplugs as a combustion chamber temperature feedback sensor. (see [url]http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/1071029711/p/3[/url] )
The first vehicle I'm working on is my 1994 Mercedes 310D mechanical in-line injector pump. (as I use it the most)
Sensors I plan to use.
glowplugs
block temp (from coolant drain plug on the engine block)
air inlet temp
fuel temp (I will be heating the fuel)
rpm (either using a magnet and reed switch or photoreflector?)
mph (as above)
injection time (using piezo crystal high pressure clamp)
I'd also like to get some kind of combustion/knock sensor working
My criteria for sensor selection are I am on a very limited budget, the sensing equipment should be reasonably easy to mount (I want to be able to move this from one engine to another) and ideally the equipment would be durable on a road going vehicle used in all weather conditions.
After a bit of research I spent out on what I think is a reasonable interface/software combination to enable me to get some good data - a LabJack Pro UE9 which comes with DAQFactory Express. ( [url]www.labjack.com[/url] )
Any suggestions of suitable equipment or other data points that would be worth collecting would be appreciated.
Sorry for the rambling post...:rolleyes:
Best regards
Darren
glowplugs
air inlet temp
mph (as above)
Best regards
Darren
