Homework Help: Bionomial Expansions help
  1. Feb 5, 2012 #1
    Bionomial Expansions help :)
    A) Three consecutive coefficients in the expansion of (1+x)^n are in the ratio 6:14:21. Find the value of n.
    B) Find the independent term in the [2x + 1 - 1/(2x^2)]^6 (independent term is x^0)
    C) In the expansion of (1 + ax)^n the first term is 1, the second term is 24x, and the third term is 252x^2. Find the values of a and n
    D) In the expansion of (x + a)^3(x - b)^6, the coefficient of x^7 is -9 and there is no x^8 term. Find a and b.
    2. Relevant equations
    3. The attempt at a solution
    A) I realized that the coefficients are n C r, n C (r+1), and n C (r+2), and that they are in ratio of 6:14:21. However I am not sure how to find n after this step.
    B) I tried substituting a variable y { let y = 2x - 1/(2x^2) } to form (y + 1)^6. I could expand it all out and test each term using the general term of binomial expansion, but that would be very tedious. I am wondering if there is a better solution
    C) I simplified C) to (a)(n C 1) = 24 and (a^2)(n C 2) = 252. Now I'm stuck on what to do next
    D) I've simplified it to 5b^2 -6ab + a^2 = -3 and -2b^2 +a = 0. I'm not sure how to proceed from this.
    Any help is appreciated :)
  3. Feb 5, 2012 #2
    Ray Vickson
    Re: Bionomial Expansions help :)
    You have formulas for C(n,r) and C(n,r+1), so you can compute and simplify the ratio C(n,r)/C(n,r+1), and set that equal to 6/14. That is one equation for n and r. Do the same for n and (r+1). Be careful to simplify the ratio as much as you can before proceeding!
    RGV
  4. Feb 5, 2012 #3
    SammyS
    Staff Emeritus
    Let's wait and hope that a Moderator splits this up, before we get too far into helping.
  5. Feb 5, 2012 #4
    berkeman
    Staff: Mentor
    It is several questions at once (please don't do that), but maybe we can handle them at once since the OP did post work on each?
  6. Feb 5, 2012 #5
    SammyS
    Staff Emeritus
    Okee-Dokee.
  7. Feb 5, 2012 #6
    berkeman
    Staff: Mentor
    Sorry Sammy. You are a huge helper. Should this be split up?
  8. Feb 5, 2012 #7
    SammyS
    Staff Emeritus
    nCr is given by:
    [itex]\displaystyle _{n}C_{r}=\frac{n!}{r\,!\,(n-r)!}[/itex]
    So, for instance: [itex]\displaystyle \frac{_{n}C_{r-1}}{_{n}C_{r}}=\frac{\displaystyle \frac{n!}{(r-1)!\,(n-r+1)!}}{\displaystyle \frac{n!}{r\,!\,(n-r)!}}=\frac{r\,!\,(n-r)!}{(r-1)!\,(n-r+1)!}=\frac{r}{n-r+1}=\frac{6}{14}[/itex]
    Similarly: [itex]\displaystyle \frac{_{n}C_{r}}{_{n}C_{r+1}}=\frac{14}{21}[/itex]
    It's pretty easy to solve these for n and r.
  9. Feb 5, 2012 #8
    SammyS
    Staff Emeritus
    No, It'll be OK.
  10. Feb 5, 2012 #9
    berkeman
    Staff: Mentor
    :smile:
