- #36
- 14,159
- 6,645
Would it be science if 100 physicists jumped into the black hole to compare their results?MTd2 said:Because the result would not be reproducible since you cannot even compare results. It wouldn't be science.
Demystifier said:Would it be science if 100 physicists jumped into the black hole to compare their results?
I think WE, not THEM, are doing philosophy, because we can't see what happens inside the horizon, while they can see what happens outside of the horizon. :tongue:Nano-Passion said:It isn't real physics if they cannot escape the event horizon to verify their results with us, then its just philosophy. :tongue2:
Finbar said:Lenny's back!
Singularities, Firewalls, and Complementarity
Susskind
( on 16 Aug 2012)
Almheiri, Marolf, Polchinski, and Sully, recently claimed that once a black has radiated more than half its initial entropy (the Page time), the horizon is replaced by a "firewall" at which infalling observers burn up, in apparent violation of the equivalence principle and the postulates of black complementarity. In this paper I review the arguments for firewalls, and give a slightly different interpretation of them. According to this interpretation the horizon has standard properties, but the singularity is non-standard. The growing entanglement of the black with Hawking radiation causes the singularity to migrate toward the horizon, and eventually intersect it at the page time. The resulting collision of the singularity with the horizon leads to the firewall. Complementarity applies to the horizon and not to the singular firewall.
Almheiri, Marolf, Polchinski, and Sully conjecture that firewalls form much earlier then the Page time; namely at the scrambling time. I argue that there is no reason to believe this generalization, and good reason to think it is wrong.
For most of this paper I will assume that the firewall argument is correct. In the last section before the conclusion I will describe reasons for having reservations.
Demystifier said:I think WE, not THEM, are doing philosophy, because we can't see what happens inside the horizon, while they can see what happens outside of the horizon. :tongue:
Yes he can, really.Nano-Passion said:Can an observer in the horizon really see what is going on outside the horizon?
Just had a thought about that. An infalling observer to outsiders appears to slow down and "freeze" at the horizon. But compared to the Hawking radiation at the horizon, this may seem like a burning fire. Or am I missing something?audioloop said:Black Holes: Complementarity or Firewalls?
http://arxiv.org/pdf/1207.3123.pdf
... Perhaps the most conservative resolution is that the infalling observer burns up at the horizon. ...
friend said:Just had a thought about that. An infalling observer to outsiders appears to slow down and "freeze" at the horizon. But compared to the Hawking radiation at the horizon, this may seem like a burning fire. Or am I missing something?
Demystifier said:Yes he can, really.
Nano-Passion said:I'm not quite convinced. Isn't there a lot that we don't know about how black holes exactly work?
Would you get a 360° view if you are in the horizon, just as you do now?
PAllen said:If you are asking classically, there are no doubts. If you are asking in the context of quantum gravity, nobody knows for sure.
As for 360 view, when you stand on the Earth do you have 360 view of the heavens? What can be said (classically) is that until you reach the singularity, null paths reach you from all spatial directions, and an angular region of these include light from outside the horizon.
The horizon is strictly a one way phenomenon: outgoing light doesn't escape it (or reach it, if emitted from inside the horizon). There is no obstacle at all to incoming light passing it and overtaking timelike trajectories of infaller's who have not reached a singularity.
Nano-Passion said:The Earth isn't a good analogy for this, imagine yourself looking around your room instead, that is a 360 degree view that I am talking about. Let's just start with a circle on the z plane, what would the observer inside the black hole see? Let us say that the observer just reached the horizon and is on the edge per say. Why would the observer be able to see all around him? Light from the other side of the horizon would not reach him.
friend said:As I understand it, the time dimension inside a black hole is alway pointed directly to the singularity. So objects that fall inside a BH can only travel with some component of their velocity pointing towards the center. In other words, you can non travel in any direction with a component pointing outwards, you must always have some component inward. I think this means that no object can travel tangentially to the center. So you will ever see objects coming from the side, only from the rear.
friend said:Just had a thought about that. An infalling observer to outsiders appears to and "" at the . But compared to the radiation at the , this may seem like a burning fire. Or am I missing something?
MTd2 said:This is what I thought. To for the time compression in relation to the infinity, the hawking radiation should go to infinite, that is, it would burn fast. So, isn't it an argument supporting fast scramble interpretation?
PAllen said:It doesn't seem to have been pointed out that you can say that this new physics at the horizon does not apply to our universe until heat death. All existing black holes (stellar or galactic) are 'new' in the sense of the firewall papers until CMB radiation has fallen far closer to absolute zero; only then do the BH's even start losing mass to Hawking radiation. Then they must lose some significant amount of mass before proposed firewalls occur. This would be orders of magnitude times the age where all stars have burned out.
PAllen said:Note, this observation is related to 'old' being the Page time. This is what is most strongly argued in the Polchinski et.al. paper. However, they argue that very likely the criterion is the scrambling time. The above observation does not apply if this is true.
sshai45 said:So does this mean that any black hole existing now would have a firewall? I find this intriguing, since it seems to be suggesting that general relativity starts to fail even sooner than one may think, in that it starts to fail right at the event horizon, well before the singularity.
Continuing what is apparently en vogue for this topic, Bousso has 'completely rewritten' his paper, from "Observer Complementarity Upholds the Equivalence Principle" to now "Complementarity Is Not Enough", apparently now considering his earlier argument 'naive'.lfighter said:Actually I prefer Bousso's statement that the cloning paradox and entanglement paradox don't exist at all(http://arxiv.org/abs/1207.5192). No observer can see both of the qubits, so it does not contradict no cloning principle. This is the 'observer complementarity'.
jacophile said:Care to elaborate?
My question is about entanglement so yep, I'm sure the answer is too...
PAllen said:We should note in this thread the latest two papers by a pair of (string) theorists who have been consistently arguing against BH firewalls:
http://arxiv.org/abs/1310.6334
http://arxiv.org/abs/1310.6335
Not sure why this line of papers (these are latest in a series going back to shortly after the AMPS paper) has gotten little attention. These arguments seem broadly consistent with the recent Maldacena/Susskind questioning of firewalls.
atyy said:Andreas Karch's What’s Inside a Black Hole’s Horizon (which I came across via Lubos Motl's blog post) includes favourable comments on the first in the series of papers by Papadodimas and Raju which PAllen linked to.
Marolf and Polchinski presented arguments, now reported in Physical Review Letters [1], suggesting that there is no well-defined quantum mechanical calculation that could predict the outcome of the in-falling observer’s measurement.
