What Data is Needed to Understand the Formation of Black Hole Jets?
In summary, the purpose of the mock research proposal is to understand the process of gathering data for a not-yet-understood phenomenon in astronomy. The conversation focuses on the formation of jets around black holes and the role of magnetic fields in this process. The possibility of using supercomputer simulations to model jet formation is mentioned, but it is noted that our current understanding of plasmas and magnetic fields is limited. The conversation also explores the potential benefits of studying the magnetic fields of black holes and the difficulty in identifying the source of a jet. The conversation then delves into the theoretical possibility of creating jets on a smaller scale and the role of rotation in jet formation. The final part of the conversation discusses the influence of electric and magnetic fields inside and
LewMcCoy
Dear Internet-
As part of an introductory Astronomy course, it is time to compile a mock research proposal, specifically to give us an idea of what real scientists do. The purpose of it is to focus on a particular not-yet-understood phenomenon of astronomy, and describe the process we would use to gather such data.
I find the jets of black holes to be fascinating, and have come here for some expert advise. As I understand so far, we know what these jets are made of (photons & electrons), but the true mystery still lies in how they are formed. Exactly how are black holes, notorious for their unyielding gravity, able to propel matter at nearly the speed of light?
This is the foundation of my research so far. The question remaining yet is the type of data and observations we plan to gather and make to try and decipher this mystery. This is where I'm a bit confused: what exactly would benefit and clarify our understanding of these jets? Knowing more about the magnetic fields of black holes? Their composition? More about their masses? Temperature? The difficulty lies in connecting the phenomenon with data. Any guidance or advice is greatly appreciated.
Thank you!
Astronomy news on Phys.org
That's not quite the mystery. It's not the black hole that is causing the jets to form, but rather the magnetic field around the black hole. You see jets form around neutron stars, and it turns out we think it's the same process.
The really big mystery is how magnetic fields work for form jets. What you'd like to do is to come up with a model in which you put in the magnetic fields, lots of ionized gas, and then run a supercomputer simulation or calculate things on paper and pencil, and boom, you get a jet. We aren't at that level of understanding.
Part of the problem is that plasmas and magnetic fields are hard. Gravity is pretty easy. Things fall down. With plasmas and magnetic fields all sorts of complex things happen.
Yes. What we'd like to do that we can't is to look at a jet and say "based on my looking at this jet, I can tell that the temperature of the gas is X, the magnetic field strength is Y, etc. etc." We aren't anywhere close to there yet.
For example, one thing that would be useful is to be able to tell that the thing is producing a jet really is a black hole. It would be nice to say black hole jets look like X, and neutron star jets look like Y.
So bottom line, it would be very valuable to know if the process that creates jets from neutron stars/quasars is the same as that/those of black holes.
Question now is, how exactly do we begin study the magnetic fields of these jets from black holes?
And thanks for your help.
Could these kinds of jets be achieved on a small scale, in a fictional context only (I'm writing) as a kind of weapon? Does it take an engine as massive as a hunk of degenerate matter to produce the needed ejecta and magnetic fields?
Jet formation seems to be an outcome of rotating mass. Protostars, pulsars, and black holes all seem to have a common phenomenon, jet formation about an axis of rotation. A rotating mass can cause electron flow, causing a magnetic field, causing charged particles to flow along magnetic field lines. The problem with black holes is that the cause of jet formation has to occur outside the event horizon.
If the cause of jet formation has to occur outside the event horizon, then classical theory can’t explain jet formation around a black hole. Any electric field or magnetic filed generated from a central mass within the event horizon can’t influence events outside the event horizon, and can’t be the cause jet formation. Frame dragging about a black hole could explain jet formation.
I don't see how this is correct. The mass of a black hole obviously has influence beyond the event horizon, so why not in this case?
Imax said:
Any electric field or magnetic filed generated from a central mass within the event horizon can’t influence events outside the event horizon, [...]
This is not true. Electromagnetic fields of sources inside the horizon actually influence anything outside the horizon just as if the black hole wasn't there. This is due to the nature of the field, the interaction is transmitted by virtual photons which are not affected by the black hole's gravitational field. The same explanation is also valid for hypothetical gravitons. See this thread for more information: https://www.physicsforums.com/showthread.php?t=490924 .
In quantum mechanics, light is made up of photons, massless particles with an associated wavefunction. In classical mechanics, light is made up of electromagnetic radiation. The defining property of a back hole is that its escape velocity is greater than the speed of light. Classically, if electromagnetic radiation can’t escape a black hole, then how can electric or magnetic fields reach beyond the event horizon?
Read again what I wrote. In Quantum Field Theory, fundamental interactions are transmitted by so called virtual particles. Virtual photons are not the same photons which light consists of, that are trapped inside a black hole. They do not feel the gravitational field.
That's what I'm trying to say. Classical mechanics has a hard time explaining jet formation around a black hole. Without a comprehensive quantum field theory, explaining black hole jet formation is problematic. In the framework of general raltivity, electric or magnetic fileds generated from a central mass within the event horizon can’t influence events outside the event horizon.
This is probably too late for LewMcCoy’s term paper, but if electric or magnetic fields generated from a central mass within an event horizon can’t influence events outside the event horizon, an option at explaining jet formation around a black hole, within GR, is to consider frame dragging. There are stable orbits about a black hole within the Kerr metric. Stable orbit = mass accumulation = accretion disk. Jet formation about a black hole can be attributed to friction within the accretion disk, but I can’t see this process forming an intense jet stream about an axis of rotation.
http://dalescosmos.blogspot.com/
I believe that electrostatic influence explains the electron beams. Negative charge developed within stars envelops galaxies. Negative charged particles are repelled to galactic rims, therefore positive charged particles converge to an inner region of positive charge. While this region holds shape of an open disk, electrons descend to rotational axis. They ignore the electron-sated black hole and launch by mutual repulsion along rotational axis guided by electron gun quite similar to many of our little ones in TV sets. Electrons maintain that axis by guidance to locus of equidistance to the positive rim of black hole's accretion disk. Intense heat developed with the converging of matter falling toward singularity might result in positron production to account for neutrinos coming out of the mix.
There's something called the membrane paradigm that translates GR's so that mere mortals can figure out what is going on. You can show that a black hole acts like a classical conducting sphere.
So it's not generated from the central mass. :-) :-) :-)
Well... You could have the black hole develop a charge, but it's believed that this isn't what causes the magnetic field of the black hole. Like lots of things with black holes, the important stuff is caused by matter that is just about to fall into the black hole.
Do black hole's emit polar jets, or relativistic polar jets, or is there some factor of its mass or angular momentum of the accretion disc which determines that?
twofish-quant said:
Well... - - but it's believed that this isn't what causes the magnetic field of the black hole.
Wouldn't a rotating accretion disk or bulge, surrounding a black hole and bearing an electric charge produce a magnetic field that would be difficult to to discern from a magnetic field attributed to a black hole?
You can't discern that a black hole is charged from observation, but in the mathematics of them, a charge is allowed if infalling matter carries a charge. This charge is not the same thing as the powerful magnetic field caused by the action of the accretion disk; they are two separate concepts really.
I’m thinking that maybe not everything in the accretion disk that falls inwards towards the black hole singularity adds to black hole mass. Most of it may form a nice jet about an axis of rotation.
The curious thing about astronomical objects is that it's hard for them to keep a charge going for long periods of time. If you have something that is positive charge it will attract negative charges, and then end up neutral.
The basic mechanism that we think powers most astronomical bodies is the dynamo effect, in which you have a conducting fluid that interacts with a magnetic field to sustain a magentic field, and yes the accretion disk does interact with the field in complicated ways.
Black holes are like bubbles in 4D space and time.
Isn't that supposed to be the same mechanism that generates our geomagnetic field? (our core as a dynamo)
For an electrically isolated astronomical object in possession of a greater number of electrons than it does of protons, then we might tend to think of its concentration of electrons about its exterior as though it were a charge. However, that concentration of electrons would have gathered, propelled by exothermic migration, whereas a the process of charging something pertains more readily to results of an endothermic process. Those electrons can find no neutralizing protons to cancel their influence; they can rest only when spaced as far from each other as they can get.
Additions to such concentrations of electrons can occur by exothermic migration whenever an ionizing event displaces the charged portions of a molecule into sufficient mutual departure from each other so that the global outward repulsion for electrons exceeds the remaining mutual attraction of the molecular fractions for each other. Nothing new is suggested here about electrical particles. Simple reverse engineering should depict astronomical objects as bearing stable configurations of proton cores and outer coatings of electrons.
Exactly.
To clarify my question: Others have been referring to a magnetic field coming from a super-massive black hole. I deem the black hole a nonparticipant in the beam forming process and agree that the spinning accretion disk produces magnetism. The electron beams produced as polar jets are fed electro-statically to the rotational axis and held so, collimated in their outward trajectory by the positive polarization at the rim of the disk which serves in the identical fashion of a focusing anode within a common CRT's electron gun. Magnetic effects neither contribute to nor disrupt the electron beams that constitutes the only paths for electron departure from the incidental location of the black hole.
It stacks up that electrons are certainly available to the black hole, but preciously few of them are taken in. The black hole would have swallowed enough electrons so that its gravitational pull upon an electron would become equaled by its electrostatic repulsion for the same particle. Fancy a close-in electron straggling either way along the rotational axis, indifferent even to the infamous event horizon.
You could look at a black hole in GR like a closed 4-D space-time manifold. That could easily explain why light, or electromagnetic radiation, can’t escape.
Mass can bend light (i.e. microlensing) and space-time. Maybe space-time around a black hole singularity is so badly bent that it forms a closed manifold. That could easily explain why anything occurring within the event horizon can’t influence anything outside the event horizon. But, big problem. If space-time around a black hole singularity forms a closed 4-D space-time manifold, then anything occurring outside the event horizon can’t influence anything within the event horizon.
Maybe black holes rarely feed.
Except that this doesn't work. Black holes do have strong magnetic fields. What happens is that if you have an electrically charges pellet, it "appears" to freeze as it falls into the black hole. If you start moving that pellet, then you get a magnetic field.
Google for "membrane paradigm thorne" for the details.
What is it that doesn't work? Although I doubt that many charged pellets would be falling into a black hole, it would nevertheless be beside any point I was making.
Some more recent artistic depicts seem to emphasize more of a polarity to jet depiction (and formation)?
  • #31
If by "polarity" you mean magnetic, there sure is plenty right there exactly where the black hole would put it if it could. A heck of a big rotating accretion disk with an awful big positive charge accounts for it. The resulting field is in the same place and of the same shape as the one fancied for the black hole. The only charged particles available to the black hole are negative. But whatever, the few that enter a black hole from the "north" would present magnetic field that is canceled out very nicely by equivalent electron count coming from the "south".
If by, "polarity" you mean electrical polarity, only the positive and negative electrical polarities have been mentioned here. There is plenty of that. A rotating, growing, gigantic disk of mostly protons functions to align electrons into a fine string on either side of the black hole to present just the architecture required for one horrendous electron gun.
The kernel of this solution is to see that a charged particle contained by a sphere or disk will greedily seek out the greater attraction from beyond the center (until it gets to the center). Tendencies to incorrectly factor in range as a determining factor might account for erroneous supposition to the contrary: Increased scope of particle count mounts up faster with distance than the associated particle field attenuation within such enclosures. On the other hand, experience with electricity leads to valid expectations.
  • #32
I'm sorry. This is gibberish. If you are interested in knowing why this is gibberish, we can continue the discussion further. If not, then I'll leave this as a warning for anyone else that is joining the thread, and I'll spend my time in more interesting threads.
  • #33
I am most interested in learning why you consider it gibberish. It does sorrow me that you express your reply as though you might not accept any clarification I might find to improve on my failure to communicate.
  • #34
It is very hard for an astrophysical fluid to maintain a charge. If you have a positively charged fluid, it vary quickly attracts negative charges, and so the charge goes to zero.
Astrophysical fluids don't separate into protons and electrons, because the coloumb force is just too large.
I'm trying to figure out if there is anything here to communicate.
What are you trying to do?
If you are trying to explain to someone about current models of how black holes and accretion disks work, then you've just got it wrong.
If you have your own model for black hole jets, and there is nothing that I can realistically say to convince you that you are wrong, then I really don't see anything to communicate here.
  • #35
What you say applies to microscopic neutralization of electrical charge. It represents an exothermic process that results then in a deenergizing phenomenon, hence a return to a stable condition.
To the extent that an astronomical body is an isolated parcel of matter, then a plurality of electrical particles of one polarity over the other should present a stable situation whereby the body would possesses an electrical charge distributed upon its outer surface. (There would simply be no available particles of the opposite to accomplish an overall neutralizing effect.)
Granting a fluid spherical body so possessed of a negative charge, introduction of an additional electron within it should find a repulsive force that would move it outward toward the outer surface. If an ionizing event were to separate an electron from a hydrogen atom by great enough distance, the force of attraction toward the resulting positive ion could become less than the global force of repulsion upon that electron. In such case, the electron would rise toward the surface and the proton would descend toward the global center. Those migrations would qualify as exothermic events thus representing what we might call a macroscopic discharge for the ion. As a result, a positive central core would develop and the negative shell of electrons would be augmented accordingly.
Please specify where I might be technically incorrect or where I should improve my attempt to explain macroscopic discharge as an alternative achievement of stable formations.
  • Astronomy and Astrophysics
