Are supernovas more likely to produce neutron stars or black holes?
In summary: Thank you for your answer!In summary, the two scenarios for a core-collapse supernova are determined by the mass of the star before it explodes. The single-degenerate model is preferred more, as the double-degenerate model might be inconsistent with observations.
Moon Shine
TL;DR Summary
Is it possible to predict what’s going to be a result of supernova explosion? A black hole or a neutron start?
I read that after explosions supernovas can ”transform” into a neutron start or into a black hole? And now I’m curious of therer any factors which can predict what thing we’re going to get after the supernova’s explosion.
Astronomy news on Phys.org
Yes: it's determined by mass.
Likes Moon Shine
P.S. You have an amazing website! I spent there an hour or so :)
Likes russ_watters
Thanks!
The original post is referring to a core-collapse supernova, which indeed produces a stellar remnant like neutron star, or black hole, depending on the initial mass of the star. However, there is another mechanism of creating supernova, called type Ia. It involves a binary system containing a white dwarf, that accretes the material falling on it from its companion star. The resulting nuclear reactions ingnited in the white dwarf's core will cause its explosion just before the collapse can occur. There is no remnat after this kind of supernovae.
Likes Moon Shine
lomidrevo said:
The original post is referring to a core-collapse supernova, which indeed produces a stellar remnant like neutron star, or black hole, depending on the initial mass of the star. However, there is another mechanism of creating supernova, called type Ia. It involves a binary system containing a white dwarf, that accretes the material falling on it from its companion star. The resulting nuclear reactions ignited in the white dwarf's core will cause its explosion just before the collapse can occur. There is no remnant after this kind of supernovae.
This is a bit oversimplified as we now have fairly conclusive evidence that there are at lest two distinct scenarios that can result in a type 1a supernovae. The example you mention is one which may have been more common early in the universe during periods of starburst formation but from what I have found it seems most type 1a supernovae in the nearby universe are white dwarf white dwarf collisions. Even this isn't absolute as a recent discovery provides a strong example of a super chandrasekhar white dwarf J005311 https://www.nature.com/articles/s41586-019-1216-1. It seems to have managed to reach a state of hydrostatic equilibrium with its combined mass and the ignited carbon fusion in balance. In a few thousand years it will run out of carbon to fuse and likely collapse into a neutron star via a type 1c supernovae.For massive stars mass is the dominant factor but metalicity also appears to be critical in the evolution of massive stars. Extreamly low metalicity population III stars of over a 100 solar masses could undergo what is known as a pair instability supernovae and also don't produce remnants at least.
Yes, I am aware of the two scenarios, but according to my knowledge, the single-degenerate model is preferred more, as the double-degenerate model might be inconsistent with observations. Let me share related paragraphs from Carroll&Ostlie:
That is why I mentioned only one of the scenarios in my previous post. But I am not arguing, the text might be obsolete by now, could you please share a reference supporting your claim?
Interesting!
Actually from what I have been able to find observations favor double degenerate progenetors have put the upper limit of single degenerate progenetors at around 20% of all type 1a Supernovae within the local universe as the vast majority of systems show no evidence of a second star. Moreover there are too many type 1a supernovae coming from evolved galaxies that haven't made new stars in billions of years when there should be a drop off for the single degenerate model.
https://www.nature.com/articles/481149a
https://arxiv.org/abs/1611.01162
https://www.nature.com/articles/nature11447
It is worth nothing that there are convincing examples for each type of type 1a supernovae so it both seem to occur. There is still contention on the exact rates but it seems most observed type 1a appear to be double degenerate.
There is some contention even for nearby ones so this is certainly still an open question https://iopscience.iop.org/article/10.1088/1674-4527/17/8/83/meta (i.e. single degenerate could work if the evolved star rapidly transitions to a white dwarf to be below the detection limit after several hundred years
Likes lomidrevo
1. What is a black hole?
A black hole is a region in space where the gravitational pull is so strong that nothing, including light, can escape from it. It is formed when a massive star dies and its core collapses, creating a singularity with infinite density and zero volume.
2. How is a black hole different from a neutron star?
A neutron star is also formed from the collapse of a massive star, but it is not as dense as a black hole. It is made up of closely packed neutrons, and its gravitational pull is not as strong as a black hole.
3. How do we detect black holes and neutron stars?
Black holes and neutron stars are detected through their effects on surrounding matter and light. For example, we can observe the gravitational lensing of light around a black hole, or detect X-ray emissions from the accretion disk around a neutron star.
4. Can anything escape from a black hole or neutron star?
No, nothing can escape from a black hole once it crosses the event horizon. However, some matter and energy can be ejected from a neutron star through processes such as pulsar winds or gamma-ray bursts.
5. Are black holes and neutron stars dangerous to Earth?
No, black holes and neutron stars are not dangerous to Earth unless they are in close proximity to our planet. The nearest black hole is located thousands of light years away, and the nearest neutron star is over 400 light years away.
  • Astronomy and Astrophysics
