B Black Holes And Warp Bubbles.
  • Thread starter bob012345
bob012345
33
Summary
A question regarding Alcubierre Warp Bubbles and black hole event horizons. Would a warp bubble moving faster than c have a different effective event horizon?
Last night PBS showed two shows on Black Holes. In the shows the host travelled on a supposed warp drive spaceship. A question occurred to me. Suppose for the argument that the Alcubierre drive were possible. Then suppose you were in a ship contained in a warp bubble moving through space at say 10c. Now consider that warp bubble with respect to the event horizon of a black hole. We know anything moving at c (radiation) or below must not cross the event horizon. But what of our warp bubble moving at 10c? Would it have a smaller effective event horizon? Thanks.
25,257
6,389
The interpretation of a warp bubble as "moving faster than c" assumes that the rest of the spacetime is flat. Obviously that is not true if the bubble is inside a black hole.
Since the EFE is nonlinear, I don't think a simple superposition of the two solutions, which is basically what your reasoning amounts to, is valid. One would have to simulate the combined solution numerically (unless a closed form expression for it could be found, which I think is highly unlikely) to see what the actual causal structure was. I would expect it to be different from the case of an ordinary test object inside a black hole, but I'm not sure the difference would be as simple as you describe.
25,257
6,389
It's also worth noting that the term "event horizon" means the boundary of the region of the spacetime that cannot send light signals to infinity. If a warp bubble is present, that region could change. That wouldn't change the "effective" event horizon; it would change the event horizon, period; the event horizon would no longer just be spherical, it would have a very weirdly-shaped portion inside the spacetime "world tube" occupied by the bubble.
bob012345
33
Thanks. But I didn't offer any reasoning or make any assumptions. I merely asked the question.
25,257
6,389
The question you asked does implicitly make assumptions: for example, that "warp bubble moving at 10c" is even a meaningful description if the bubble is inside a black hole. It might not be. The only way to know would be to solve the EFE for this case; AFAIK nobody has done that. I don't think heuristic reasoning will do.
bob012345
33
Thanks. What you said is basically what I meant. The event horizon might be different when it interacts with the warp bubble. Perhaps the warp bubble doesn't end up inside the new event horizon even if a "classical" intersection would have suggested it might.
bob012345
33
Thanks. I meant if it was approaching the black hole from far away at 10c. The whole question was about what happened when they interact. But you answered my question by saying the answer isn't obvious and requires detailed calculations.
Thanks again.
25,257
6,389
But that is a different question. The event horizon, which is what you asked about in your OP, doesn't affect objects going into the hole. It only restricts objects going out of the hole.
The detailed "trajectory" of a warp bubble for any set of initial conditions would be expected to be different from that of an ordinary object. But that in itself doesn't have anything to do with the event horizon. (And of course it would need detailed calculations for any set of initial conditions.)
Want to reply to this thread?
"Black Holes And Warp Bubbles." You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
