Planetary Orbits Around Black Holes
In summary, when a star dies and becomes a black hole, its gravity does not change and the planets continue to revolve around it. The black hole only has strong gravity in the space where the star used to be. This can be seen in a diagram comparing the gravitational pull of a planet and a spaceship in both the star and black hole scenarios.
varsha
56
i know that if a star having planets dies, and becomes a black hole the planets continue to revolve around the black hole. how is it possible when the black hole sucks everything??:confused:
Astronomy news on Phys.org
Hi varsha and welcome to these Forums!
So did the star (sucks everything) before it became a BH, its called gravity, that is why the planets have to orbit around it.
Garth
Simply put, a black hole sucks in no more than anything else does.
A black hole's gravity is entirely dependent on its mass, same as an ordinary star, including this BH-formerly-know-as-a-star. Presuming that, when the star collapsed, it did not lose any mass, then its gravity has not changed. The planets, gravity-wise, see no change. Neither would a spaceship in orbit.
What is surely confusing you is this: the newly formed black hole can and does have hugely strong gravity (as you've read) - but only in the space where the star used to be.
I refer you to the attached diagram for clarification.
Planet's gravity well on the right, BH on the left. Note that, since both objects are the same mass, they both have the same curvature (gravitational pull).
Now, note how much pull the spaceship s1 experiences in the left diagram and in the right diagram - it's the same in both. Note how much pull spaceship s2 experiences: same.
But look at spaceship s3 - it only exists in the BH diagram because in the star diagram it would be below the surface of the star. It can get very close to the BH, since it's much smaller, and there, it can experience an extremely strong gravitational pull.
What is a black hole and how does it affect planetary orbits?
A black hole is a region of space with such strong gravitational pull that nothing, including light, can escape from it. Its immense mass and gravitational force can significantly affect the orbits of planets, causing them to move in a curved path around the black hole.
Can planets orbit around a black hole?
Yes, planets can orbit around a black hole, just like they orbit around stars. However, their orbits may be highly elliptical and unstable due to the extreme gravitational force of the black hole.
How does the mass of a black hole affect the orbits of planets?
The mass of a black hole directly correlates with its gravitational force. The more massive the black hole, the stronger its gravitational pull, which can significantly alter the orbits of planets and other celestial bodies in its vicinity.
Do all black holes have the same effect on planetary orbits?
No, the effect of a black hole on planetary orbits depends on its mass, spin, and the distance between the planet and the black hole. A smaller black hole with a lower mass may have a weaker gravitational pull, resulting in a less significant impact on planetary orbits.
Is it possible for a planet to orbit a black hole and a star simultaneously?
Yes, it is possible for a planet to orbit both a black hole and a star at the same time. This type of orbit is known as a circumbinary orbit, where the planet orbits around both the black hole and the star in a complex pattern determined by the gravitational forces of both objects.
  • Astronomy and Astrophysics
