Black Holes
latentcorpse
1,444
I'm trying the exercises on p35 of the following:
http://arxiv.org/PS_cache/gr-qc/pdf/9707/9707012v1.pdf
I have done parts (i) and (ii) but was wondering if anybody can help me with (iii)?
I had [itex]k \cdot D k^\mu |_{U'=0} = k^\nu D_\nu k^\mu |_{U'=0} = k^V' D_{V'} k^\mu[/itex] since setting [itex]U'=0[/itex] means only the [itex]\nu=V'[/itex] componeent will contribute.
Subbing in we end up with
[itex]\kappa V' ( k^\mu{}_{, V'} + \Gamma^\mu{}_{V' \rho} k^\rho)[/itex]
I can't really make anything useful out of this now though?
Thanks.
Answers and Replies
fzero
290
You might want to compute each component. Did you compute [tex]\Gamma^\mu{}_{V' \rho}[/tex]?
latentcorpse
1,444
Is [itex]\Gamma^\mu{}_{V' \rho} = \frac{1}{2} g^{\mu \lambda \left( g_{V' \lambda , \rho} + g_{\rho \lambda, V'} - g_{V' \rho, \lambda} \right)[/itex]
Ok but [itex]ds^2=-dU'dV'[/itex]
which means that [itex]g_{\mu \nu} = \begin{pmatrix} 0 & -1 \\ -1 & 0 \end{pmatrix}[/itex]
So regardless of what happens, we're always going to be taking the derivative of either -1 or 0 in the three terms in the Christoffel symbol. So am I right in saying that [itex]\Gamma^\mu{}_{V' \rho} =0[/itex]?
That would mean that [itex](k \cdot D k^\mu)|_{U'=0}=k^V' k^\mu{}_{, V'} = \kappa V' k^\mu{}_{,V'}[/itex]
But [itex]k^\mu{}_{,V'} = \kappa \frac{\partial}{\partial V'} + \kappa V' \frac{\partial^2}{\partial^2 V'}[/itex]
It may well have worked if that 2nd derivative term wasn't there....hmmm....
fzero
290
Yes it's a flat metric. However [tex]k^\mu[/tex] refers to the components of the vector field [tex]k[/tex], so we're not dealing with a derivative operator.
latentcorpse
1,444
Excellent!
One other thing though. At the top of p36, he claims that [itex]a^\mu=D_{(\lambda)} u^\mu[/itex]
I don't understand why this defines an acceleration? I though [itex]a^\mu=\frac{d x^\mu(\lambda)}{d \lambda}[/itex]? Is there a way of showing these definitions are equivalent?
Also, how does that formula for the acceleration (2.121) then become equation (2.122)?
fzero
290
Excellent!
is not covariant.
Use (2.120).
latentcorpse
1,444
is not covariant.
Sure. But why do we use [itex]a^\mu=D_{(\tau)}u^\mu = u \cdot D u^\mu[/itex] instead of just a plain old covariant derivative [itex]a^\mu=D u^\mu[/itex]
And on p40 there are a few things I'm not quite grasping. I can follow up to eqn (2.147).
Now in the line below he works out [itex]T_0[/itex] for Rindler by substituting in [itex]T[/itex] from Schwarzschild. How is this allowed? Isn't he mixing and matching results from two different spacetimes? I know Rindler essentially covers the region near r=2M of Schwarzschild but still......
Ok. He then presents an acceptable argument on the enxt few lines as to why if [itex]x \rightarrow \infty[/itex] we expect T to go to zero. Why does this mean the Hawking temp will go to zero? Or is the T in eqn (2.142) actually the Hawking temp?
So it makes sense that the temp should go to zero because RIndler is just Minkowski in different coords so it's a vacuum soln i.e. there is nothing in the spacetime to radiate any hear. I don't understand the last line though....
why does [itex]T_{\text{local}} \rightarrow T_H[/itex] if a black hole is present? Perhaps I should just leave that just now....he does say we shall see that later on!
fzero
290
Well we still want the proper acceleration. [itex]
[/itex] would be correct in special relativity, where we neglect curvature. So it's obvious that we need to move to the corresponding covariant derivative.
He's not mixing and matching results at all. He's simply using (2.146) to find [tex]T_0[/tex] and notes that it agrees with the Schwarzschild result.
The Hawking temperature is the temperature measured at spatial infinity, see the comment below (2.148).
[itex]T_{\text{local}} \rightarrow T_H[/itex] is explained by the comment below (2.142) about the asymptotic behavior of the timelike Killing vector field.
latentcorpse
1,444
So I agree that the derivative wrt lambda is the special relativity result. So in GR we need something that takes into account spacetime curvature, such as the covariant derivative. Why then, is the acceleration not simply [itex]D u^\mu[/itex]? Why do we need to dot procuvt that with u to get [itex]u \cdot D u^\mu[/itex]?
Hmmm.....what's [itex]T_{\text{local}}[/itex] in all of this? And why does this relationship tells us that the BH must be radiating?
fzero
290
We need an expression that reduces to the physical result in flat space. Besides [itex]D u^\mu[/itex] makes no sense, since you've dropped the index on the derivative without explaining why. You could write [itex]v \cdot D u^\mu[/itex] for some vector [tex]v[/tex] but then you must explain why you chose that [tex]v[/tex]. [tex]v=u[/tex] is the obvious choice.
[itex]T_{\text{local}}[/itex] is defined by (2.142) in terms of the temperature [tex]T_0[/tex] measured at spatial infinity and the timelike Killing vector field. [tex]T_0[/tex] is determined by considering the Euclideanized metric and demanding that it is complete, which is what was done in the discussion leading to (2.136) for the Schwarzschild BH.
Radiation follows from coupling the BH to a quantum system at equilibrium via (2.139). At the lowest approximation, you will conclude that there is a black-body spectrum of radiation due to the finite temperature.
sgd37
213
you do realize that the acceleration is just the equation of motion i.e the geodesic which is equivalent to [tex] \nabla_{u} u^{\mu} = u^{\nu} \nabla_{\nu} u^{\mu} [/tex]
latentcorpse
1,444
Thanks for that.
Ok. I definitely know/recognise this but can't remember how to show it.
We're talking about a massive particle so we know it must be travelling on a timelike geodesic. That's us established it is on a geodesic.
But for geodesics with tangent vector X, we know [itex]\nabla_X X=0[/itex] i.e. [itex]X^\nu \nabla_\nu X^\mu=0[/itex]
In this case the tangent vector is u instead of X so surely we should have [itex]u^\nu \nabla_\nu u^\mu=0[/itex]
But you're telling me that [itex]a^\mu=u^\nu \nabla_\nu u^\mu[/itex] which would mean it isn't accelerating (which i guess is true for a geodesic)
Is this correct? Or have I missed the reason why [itex]a^\mu = u \cdot D u^\mu[/itex] altogether?
Thanks.
sgd37
213
well if it's a free particle then its acceleration will be zero. Anyway 0's or not that is how proper acceleration is defined
latentcorpse
1,444
Hi there, could you take a look at the diagram on p45 please?
Am I right in saying that compared with teh diagram on p44 (for Minkowski), there is now this additional left hand side region because we no longer have the [itex]r \geq 0[/itex] i.e. [itex] \tilde{V} \geq \tilde{U}[/itex] constraint that Minkowski had?
Also, he indicates that the right hand rhombus represents the Rindler spacetime - how does he know this?
He then shows an orbit of [itex]\frac{\partial}{\partial T}[/itex] and also the line [itex]X=0[/itex]. According to eqn (2.117), surely these are using Rindler coordinates so why aren't they a curve in the right hand Rindler rhombus?
Finally, he draws an orbit of [itex]\partial}{\partial t}[/itex] (where he now claims [itex]t[/itex] is the Rindler time coordinate and puts that in the Rindler rhombus. However, this curve will no longer be a timelike geodesic, will it? (Here I am using the definition on p273 Wald that a timelike geodesic will begin at past temporal infinity, [itex]i^-[/itex] and end at future temporal infinity, [itex]i^+[/itex]).
Thanks.
fzero
290
Yes.
From (2.113) the Rindler variables only cover [tex]U'<0, V'>0[/tex].
[tex]T,X[/tex] are Minkowski coordinates, [tex]x,t[/tex] are the Rindler coordinates.
Thanks.
Geodesics have zero proper acceleration. It was shown that the orbits of the timelike Killing vector field have a proper acceleration proportional to [tex]x^{-1}[/tex].
latentcorpse
1,444
Hw do you know that the right rhombus corresponds to the region [itex]U'<0,V'>0[/itex]?
How do we know what X=0 looks like and what the orbit of [itex]\frac{\partial}{\partial T}[/itex] should look like?
Thanks!
latentcorpse
1,444
Thanks!
fzero
290
Thanks!
For both of these, you use the coordinate transformations (2.162) and (2.116). The [tex]\tilde{V}[/tex] coordinate runs at [tex]\pi/4[/tex] from the vertical axis of the Penrose diagram, while [tex]\tilde{U}[/tex] runs at [tex]-\pi/4[/tex].
latentcorpse
1,444
I don't really follow what you're saying here. By analogy with the diagram on p44 I can see that [itex]\tilde{V}[/itex] is at [itex]\frac{\pi}{2}[/itex] on future null infinity and that [itex]\tilde{U}[/itex] is at [itex]\frac{\pi}{2}[/itex] on past null infinity. Where does the [itex]\frac{\pi}{4}[/itex] come from?
Also, will the boundary lines on the LHS of the diagram also be past/future null infinities? Or are these only defined on the RHS?
fzero
290
[itex]\frac{\pi}{4}=45^\circ[/itex] is the angle the [itex]\tilde{U},\tilde{V}[/itex] axes make with the vertical axis of the diagram.
Yes, just look at the radial null geodesics on the LHS.
latentcorpse
1,444
But the two diagonal lines in the middle of the diagram correspond to the [itex]\tilde{U}[/itex] and [itex]\tilde{V}[/itex] axes, right? We also know that these corrdinates both range from [itex]- \frac{\pi}{2}[/itex] to [itex]\frac{\pi}{2}[/itex]. Surely, since the dotted vertical line intersects these diagonal lines in half, we would expect [itex]\tilde{U}=\tilde{V}=0[/itex] at the centre of the diagram?
fzero
290
I have been talking about the diagonal lines.
I've never said anything to the contrary.
latentcorpse
1,444
So I'm now ok with why the right rhombus is the Rindler spacetime.
But what were you saying about [itex]\frac{\pi}{4}[/itex] then? I didn't follow that stuff?
And also, I still don't get how to see that X=0 is that vertical line down the middle...
Thanks.
fzero
290
What angle do the diagonal lines make with the vertical line down the middle?
Thanks.
Can you express [tex]X[/tex] in terms of [tex]\tilde{U},\tilde{V}[/tex]?
latentcorpse
1,444
So I think I have it:
[itex]U'=\tan{ \tilde{U}} , V'=\tan{ \tilde{V}}[/itex]
and [itex]T-X=U' , \quad T+X = V'[/itex]
so [itex]X=\frac{1}{2} ( \tan{ \tilde{V} } - \tan{ \tilde{U} } )[/itex]
so [itex] X=0 \Rightarrow \tan{ \tilde{V}} = \tan{ \tilde{U}} \Rightarrow \tilde{V}=\tidle{U}[/itex] and that it is true down that dotted vertical line.
Did I get it right?
So the final things to establish is why that orbit of [itex]\frac{\partial}{\partial T}[/itex] goes from [itex]i^-[/itex] to [itex]i^+[/itex]. I guess, by defn, of curves that begin and end at these points, it is sufficient to show that [itex]\xi=\frac{\partial}{\partial T}[/itex] is a timelike curve.
Well [itex]g_{\mu \nu} \xi^\mu \xi^\nu = g_{TT}[/itex] since [itex]\xi^\mu = (1,0)[/itex] in coordinates [itex](T,X)[/itex]
Now if I had managed to get an answer of [itex]g_{ \tilde{U} \tilde{V}}[/itex] then that would have been awesome because [itex]g_{ \tilde{U} \tilde{V}}=-1[/itex] which would have meant timelike......
fzero
290
[tex]g_{TT}=-1[/tex] as well.
latentcorpse
1,444
fzero
290
[tex]T,X[/tex] are Minkowski coordinates. See for example (2.117).
latentcorpse
1,444
Ok. But it is timelike geodesics that go from past temporal infinity to future temporal infinity. Is it possible to show that [itex]\frac{\partial}{\partial T}[/itex] is a geodesic and not just some random timelike curve?
And on p47, there is a diagram. He says above it that all parts of the star not initially at r=0 reach the singularity simultaneously - how does this work? surely the bits closer to the centre should hit it first?
Thanks.
fzero
290
The geodesic equation is [tex]V\cdot D V^\mu =0[/tex]. It looks easy enough to verify that.
Evidently the proper distances traveled are all the same. It's probably a nice exercise to work out starting from the action (2.1).
  • #31
latentcorpse
1,444
[itex]V \\cdot D V^\mu = V^\nu D_\nu V^\mu = V^\nu ( V^\mu{}_{, \nu} + \Gamma^\mu{}_{\rho \nu} V^\rho )[/itex]
But [itex]V^\mu{}_{, \nu}=0[/itex] obviously
and since we are considering the Rindler metric (essentially Minkowski spacetime but in funny coordinates), the spacetime is flat adnd so the Christoffel symbols will vanish.
This means it will satisfy the geodesic equation.
Is that ok?
How would I go about doing this? What are the steps involved?
And the top diagram on page 50 shows the future event horizon, [itex]\mathscr{H}^+[/itex]. Why is that line the boundary of the closure of the causal past of future null infinity? I don't really get why it is that line, and that line alone, that is the boundary? Is it because any other such lines that could be boundaries e.g. [itex]\mathscr{I}^+[/itex] or [itex]\mathscr{I}^-[/itex] are contained in [itex]J^- ( \mathscr{I}^+ )[/itex] and therefore by the definition [itex]\mathscr{H}^+ = \bar{J}^- ( \mathscr{I}^+ ) - J^- ( \mathscr{I}^- )[/itex] they get taken away again and can therefore not be part of the horizon? I think that's right....but why can't the dotted vertical line be part of the horizon still?
Cheers.
  • #32
fzero
290
Is that ok?
Yes.
I spoke a little bit quickly. The analysis in the notes never treats points in the interior of the star, because the metric there depends strongly on the distribution of dust, which he doesn't try to specify. So if his statement is true, it relies on something that he hasn't really mentioned.
In any case, the type of analysis (were the full metric known) would be something similar to what he does in section 2.3.
Cheers.
Yes, everything to the right of [tex] {\cal H}^+[/tex] is in [itex]J^- ( \mathfrak{I}^+ )[/itex]. The point is that all of the points on [tex] {\cal H}^+[/tex] are spacelike separated from [tex]\mathfrak{I}^+[/tex]. You could verify this by calculation and you can also compare to the diagram on page 18 that shows the light-cones explicitly.
  • #33
latentcorpse
1,444
So even though we can't do it here I'd like to make sure I understand the method. We would use the metric and what make assumptions about travelling on radial timelike (since they are massive free particles) geodesics. Then we would get an expression for [itex]\frac{dt}{d \tau}[/itex] and work out [itex]t[/itex] and try to show that [itex]t[/itex] doesn't depend on [itex]r[/itex]?
This spacelike seperation is easy to see from the diagram at least. How would one prove it by calculation though?
  • #34
fzero
290
I think that you'd want to compute [tex]\int d\tau[/tex] for a path starting at [tex]r=R[/tex] and ending at [tex]r=0[/tex]. If Townsend's statement is true, this proper distance would be independent of [tex]R[/tex].
The proper distance between two points in the plane is
[tex]s^2 = - 4 \left( 1-\frac{2M}{r}\right) \Delta\tilde{U} \Delta\tilde{V} .[/tex]
To the right of [tex]{\cal H}^+[/tex], points are timelike separated from [tex]\mathfrak{I}^+[/tex], [tex]{\cal H}^+[/tex] they are null, and to the left of [tex]{\cal H}^+[/tex], points are spacelike.
  • #35
latentcorpse
1,444
Where did you get this from?
And also, I don't understand how the proof of Penrose's Theorem (given on page 51/52) actually proves anything to do with the theorem!
And on p52, he says that null geodesics may enter [itex]\cal{H}^+[/itex] but never leave it. Does this mean that for the time reversal, null geodesics may leave [itex]\cal{H}^-[/itex] but never enter it? I guess that makes sense since null geodesics go from [itex]\mathfrak{I}^-[/itex] to [itex]\mathfrak{I}^=[/itex] so in order for them to enter [itex]\cal{H}^-[/itex] they would have to follow a path at an angle greater than 45 degrees i.e. they'd be going faster than light which is forbidden. However, how could there ever be a situation where they could leave [itex]\cal{H}^-[/itex]? We know that all null geodesics start on [itex]\mathfrak{I}^-[/itex] and end on [itex]\mathfrak{I}^+[/itex]. So I guess if they started at the point that [itex]\mathfrak{I}^- , \cal{H}^-[/itex] share then they could travel up [itex]\cal{H}^-[/itex], leaving it at some point and then heading back to [itex]\mathfrak{I}^+[/itex] at 45 degrees. Did I get this right?
Finally, on p53, he says that the singularity at r=0 which occurs in spherically symmetric collapse is hidden in the sense that no signal can reach it from [itex]\mathfrak{I}^+[/itex]. Surely, he means [itex]\mathfrak{I}^-[/itex], no? Although, I'm guessing not because the Kruskal diagram below quite clearly shows that a signal from [itex]\mathfrak{I}^-[/itex] can reach the r=0 singularity. Why are we so concerned with [itex]\mathfrak{I}^+[/itex] here?
Suggested for: Black Holes
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
