Bladeless fans launched !
  • Thread starter pixel01
x-posted from Mechanical Engineering forum:
That makes me wonder - could similar principles be used to come up with a bladeless wind turbine? Some environmentalists are concerned that wind turbine blades could pose a hazard to birds. I'm wondering if Dyson's approach couldn't be used to rectify that?
Also, many residential areas might have zoning laws against things like wind turbines, but if they could be made bladeless then perhaps they might be exempted from such restrictions.
So rather than being an "air multiplier", I suppose it would be an "air concentrator".
Is such a concept possible? If so, would such a device prove to have comparable efficiency to standard wind turbines?
FredGarvin
The big issue I would see with that is that the inducer requires a high velocity jet to entrain the extra air. On such a large scale that may not be economically possible and may create a lot of aero noise.
IMP
This is not bladeless, blade is in the bottom. The only truly bladeless designs I know of are magnetohydrodynamic drives for ships and submarines (which only work in sea water) and the ION air purifiers...
I do like the design of this fan though, I would pay up to $29.95 for one.
How long until Chinese-made knockoffs appear?
And what are the limitations on this design? Could you have a giant ceiling fan of this type?
Could you turn it into a CPU-fan or power supply fan for your PC or laptop?
Could this thing be used in a propulsion system, to propel a vehicle and give it lift?
Could it work in water or a similar liquid?
Could it propel a ship, or a submarine, or motorboat? Sometimes you hear about whales or manatees being cut by propeller blades from boats. Could this be a cure for that?
IMP
Chinese knockoffs in 5...4...3...2...1
It looks like it uses a venturi effect to me. High pressure and low volume air drags in surrounding air to become low pressure and high volume.
I don't see why it couldn't be scaled up.
My leaf blower has an optional attachment on the discharge nozzle designed to funnel ambient air into the air stream, and does seem to greatly increase overall air volume.
745
Hey, I think I found something - a wind turbine without big blades:
http://greenlivingideas.com/topics/alternative-energy/wind-energy/generation-wind-turbine-produces-3-times-power [Broken]
It seems to concentrate the flow of wind into a smaller cross-sectional area, and vaguely resembles a jet engine.
russ_watters
Mentor
18,849
5,040
I don't know if that's for real, but the description in the link is pure nonsense:
The fundamental flaw in every wind turbine is that none of them actually speed up the air....
No.
The current systems extract less than 50% of the wind’s energy and are only working about a third of the time!
According to Dragonfly, the nature of the new turbine’s inner wing design increases the air speed to create more power – up to three times the average of a standard wind generator.
50%*3=150% efficient? No.
The chambers act as defusers so by the time the air reaches the third chamber, the smallest, the air inside is moving as fast as the air outside.
Uh, diffusers diffuse. They decrease air velocity, they don't increase it! By definition!
The nacelle of the Dragonfly was inspired by the technology of the SR 71 Blackbird, with a unique nose cone capable of expanding over 600% in size, increasing or decreasing the air speed and flow passing through the unit.
No, that's not what the SR-71 inlet cone was for. The SR-71 inlet cone basically just ensured that the cone shaped shock wave generated by the tip of the cone hit the inside of the inlet. The shock wave gets tighter as the plane accelerates, so the cone moves out.
From the picture, it looks like a jet engine - it looks like they are claiming the first three stages are fans/compressors that pull air in and accelerate it while the turbine is at the back. That can't happen.
According to Dragonfly Industries, two computer dynamic fluid (CDF) tests on the design were completed by an independent software company, SolidWorks, and the results are promising for moving forward with prototypes.
Solidworks is a software company, not an engineering company. They don't do the analysis for you!
Also, a simulation isn't a test.
and proves that more than 59% of the wind’s power can be harvested with the right design.
Uh - above it said that a typical turbine is 50% efficient and that this generated 3x more power....
FredGarvin
That article was written by someone who has no clue but likes being the mouthpiece for a questionable start up company. 3X power? Please...
minger
No. Uh, diffusers diffuse. They decrease air velocity, they don't increase it! By definition!
haha, those are the first things that jumped out at me too.
The fan is in the base - it pushes air through the circumference of the ring where it comes out along the axis through tiny holes.
The idea is a smoother airflow and no whirling blades - so quieter and safer
Yes, I buy one chinese "Shanzhai", more quieter and safer.
Related Threads for: Bladeless fans launched !
  • Posted
  • Posted
  • Posted
  • Posted
10K
  • Posted
14K
  • Posted
14K
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
