Blanking on simple math.
SherlockOhms
310
Just a quick question. This is fairly terrible that I'm blanking on something as fundamental as this. It's to do with units and dimensions. So, Area, for example, = L * L = L^2. If I have a quantity, R, for example and let's say it's units are L. If I use R in some arbitrary equation and square it does it then become the |R|^2 L or |R|^2 L^2 (where |R| is the scalar component of R)???
The following is what got me confused about this. u(the average velocity) = 14/R2 * umax(The max velocity) * (R(1/4) - R(1/15).
So, the units don't check out in the above equation for velocity, do they?
Answers and Replies
Pythagorean
287
Yes, units suffer the same operation as their values.
arildno
Dearly Missed
10,089
135
Well, if "R" in your problem is already NON-dimensional (say a ratio between two radii), it is wholly unproblematic.
HallsofIvy
43,021
970
Certainly [tex]R^{1/4}- R^{1/15}[/tex] would make no sense if R is a "distance". Perhaps, as arildno suggests, R is really a ratio of distances. Could you give us more information about that formula?
SherlockOhms
310
My apologies, R is a radius, therefore it has units of metres.
SherlockOhms
310
Thanks for clearing that up.
Borek
Mentor
29,100
3,710
Could be it is an approximate formula that doesn't follow strict derivation, in such case units can be off.
SherlockOhms
310
It's only for calculating the average fluid flow in a pipe, nothing overly complicated. We weren't told that it was an approximate solution so I couldn't say if it is or isn't.
pasmith
2,333
937
No. Most likely the formula is valid only if length is measured in metres (and only for a particular fluid), and that the necessary constants of proportionality would have to be put back in if other length units were to be used.
SherlockOhms
310
Could you explain that? The length would be measured in metres and there are no constants of proportionality evident in the equation, so the units still wouldn't check out?
pasmith
2,333
937
For the dimensions to be consistent, you would need
[tex]
u_{avg} = u_{max}\frac{k}{R^2} (R^{1/4} - \alpha R^{1/15}) = u_{max} \frac{k}{R^{7/4}}(1 - \alpha R^{-11/60})
[/tex]
where [itex][k] = L^{7/4}[/itex] and [itex][\alpha] = L^{11/60}[/itex].
It may be that for the fluid in question [itex]k = 14\,\mathrm{m}^{7/4}[/itex] and [itex]\alpha = 1\,\mathrm{m}^{11/60}[/itex].
SherlockOhms
310
[tex]
[/tex]
Gotcha. Thanks for that.
Ray Vickson
Dearly Missed
10,706
1,722
This can get confusing; it all depends on where the units are "attached". If you say "radius = R meters", the quantity R is dimensionless and you can make immediate sense of things like sin(πR) or log(R), etc. However, if you say that "R = 2 meters", for example, then R has dimensions and you need to be a lot more careful.
SherlockOhms
310
That's a great explanation. Thanks. I find that the more you think about it, the more muddled up you can get. So, basically, in your example, R is essentially some arbitrary scalar?
Suggested for: Blanking on simple math.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
