Homework Help: Block in a Curved Ball
  1. Oct 11, 2007 #1
    A 0.30-kg block slides along a small track with elevated ends and a flat central part. The flat part has a length L = 1.55 m. The curved portions of the track are frictionless, but for the flat part the coefficient of kinetic friction is 0.106. The block is released from rest from a height h = 82 cm on the left curved portion of the track. Calculate the maximum height reached by the block on the right curved portion of the track.
    img: http://i242.photobucket.com/albums/ff106/jtdla/prob09.gif [Broken]
    The only thing I have figured out is the Potential Energy at the top, then the KE at the bottom.
    .3*9.8*.82=1/2*.3*x^2, that will yield a velocity. Outside of that, would I just treat the other part like a FBD
  3. Oct 11, 2007 #2
    learningphysics
    Work done by friction = final energy - initial energy
    final energy = Work done by friction + initial energy
  4. Oct 11, 2007 #3
    Would I just calculate friction and then multiply it by the length of the bowl?
    N=mg
    muN=frictional force
    muN*length of bowl
  5. Oct 11, 2007 #4
    learningphysics
    yes. remember that the frictional work is negative... so work by friction is -muN*length of bowl.
  6. Oct 11, 2007 #5
    by initial energy, do you mean potential energy
  7. Oct 11, 2007 #6
    learningphysics
    yes. both initial and final energies are just potential energy...
  8. Oct 11, 2007 #7
    Won't this just calculate a velocity.
    I got 3.58 m/s
    1/2*.3*x^2=-.31164*1.5+.3*9.8*.82
  9. Oct 11, 2007 #8
    learningphysics
    No. write out the equation.
  10. Oct 11, 2007 #9
    Oh!
    So would it be the potential energy of both sides of the bowl, except on one side i would have an unknown height
    mgh (left)-work of friction=mgh(right)
  11. Oct 11, 2007 #10
    learningphysics
    yeah. what answer did you get?
  12. Oct 11, 2007 #11
  13. Oct 11, 2007 #12
    A skier (m=59.00 kg) starts sliding down from the top of a ski jump with negligible friction and takes off horizontally. If h = 7.70 m and D = 12.90 m, find H.
    Could I solve this problem in a similar manner?
    At the point where the skier is about to go off the ramp, is that both a PE and a KE.
  14. Oct 11, 2007 #13
    learningphysics
    I don't understand the question... what are h, D and H? can you describe or post the picture?
  15. Oct 11, 2007 #14
    img:http://i242.photobucket.com/albums/ff106/jtdla/prob21a.gif [Broken]
  16. Oct 11, 2007 #15
    learningphysics
    Use kinematics to get the velocity at h when it goes off the ramp... then use energy conservation to get the height H.
  17. Nov 27, 2011 #16
    My question is similar:
    A 0.40-kg block slides along a small track with elevated ends and a flat central part. The flat part has a length L = 1.41 m. The curved portions of the track are frictionless, but for the flat part the coefficient of kinetic friction is 0.145. The block is released from rest from a height h = 52 cm on the left curved portion of the track. Calculate the maximum height reached by the block on the right curved portion of the track.
    I did:
    Energy initial + work done by friction = Energy final
    mgh + F*x = mgh
    (mgh+F*x)
    ----------- = h
    (mg)
    [((0.4)(9.8)(0.52))+((0.145*-9.8)*(0.52))]
    ----------------------------------------- = h = 0.008875m
    ((0.4)(9.8))
    But the real answer is: 0.31555m
    Can anyone point out my mistake?
    Thank you for the assistance!
  18. Nov 27, 2011 #17
    I found my mistake... I used 9.8 as my force of friction. After 3 hours of doing this problems different ways... I finally found it! Thanks!
