Block Jump from Ramp: Find Speed v
In summary, the problem involves a block starting at rest and sliding down a frictionless track, encountering a small rough area before leaving the track and striking the ground. The acceleration of gravity is 9.8 m/s^2 and the given variables include the mass of the block, starting and horizontal heights, length of the rough area, and coefficient of friction. Using the conservation of energy theorem, the final velocity of the block can be calculated by setting the initial potential energy equal to the final kinetic energy minus the work done by friction. After plugging in the given values and solving for the final velocity, the correct answer is found to be 5.95617 m/s. However, a mistake may have been made in the thought process
racecar12
A block starts at rest and slides down a frictionless track except for a small rough area on a horizontal section of the track
It leaves the track horizontally, flies through the air, and subsequently strikes the ground. The acceleration of gravity is 9.8 m/s2 .
What is the speed v of the block when it leaves the track?
Givens:
mass of block =0.401kg
Starting height of block = 4.1m
Horizontal height of block when it encounters the friction = 1.9m
Length of the rough area on the horizontal section of track = 1.3m
Coefficient of friction = 0.3
Einitial=Efinal
Kinitial +Uinitial = Kfinal +Ufinal
Ffriction=μN
N=W=mg
Δy=h=4.1-1.9=2.2
I set Kinitial and Ufinal to zero, yielding:
mgh=0.5mv2d - Ffrictiond
vfinal= [ [itex]gh+μNd/0.5(1.3)[/itex] ]1/2
v=5.96m/s
Just wondering if I went about this correctly,
Thanks
hi racecar12! :smile:
i'm confused :confused:
can you check that, and write it out again, please​
Thanks for looking at this post.
Here was my though process as I approached this problem...
We'll just use the conservation of energy theorm for this problem.
Einitial=Efinal
Kinitial+Uinitial=Kfinal+Ufinal
Since the massive object has no initial kinetic energy at the start of the system, call it when the object is at its initial height, it has potential energy equal to mgh. m is the mass of the object, g is the acceleration due to gravity, and h is equal to the distance the object travels. In this case, I have to set h equal to a change in the initial height if the object to its height when it encounters the frictional surface. Δy=h. The left side of the equation now reads: Uinitial=mgh. Or just, mgh
mgh=some final kinetic energy - the work done by friction
We have an equation that relates kinetic energy with velocity...it is 0.5mv2=Kfinal...v2 is also the final velocity, which for this system, is right at the point when object leaves the surface. The object will travel in the air for some unknown distance at some other velocity, but for purposes of this problem, we won't worry about them, because those things are not what this problem is asking for. Now, I'm not sure about multiplying, by length d, but I believe we have to.
I also know that the work done by the frictional force equals μNd. That's because work equals force x distance. We have μ and d given to us. d in this case is the distance the object travels along the rough surface only. N is unknown, but we do know that in this case N =W, which happens to = mg in this case. I may not have told you that the rough surface is flat. The minus sign comes in because the frictional force opposes the motion of the object.
Now our equation looks like this
mgh = 0.5mv2d - 1.532622
Now let's isolate v. My m will cancel when I move everything over to the other side.
(gh + 1.532622)/(0.5)(d) =v2
PlUg it all in and take the square root...v = 5.96 m/s
And sorry that the + is underlined..I'm not sure why it does that when I type it in.
ah, that's what was puzzling me
no, you don't multiply by d (i've no idea twhere you got that idea from)
KE = 1/2 mv2, that's all!
try again :smile:
Yes, you are correct that kinetic energy equals 0.5mv2. However, removing d from the equation takes me much farther from the answer, which I know to be 5.95617m/s. if I proceed with the way that I have thought, I get v to equal 5.96046. Close, but no cigar.
I am making a mistake somewhere in my thought process, but I don't know where it is. Perhaps I'm making multiple mistakes, but I don't know where or what they are. Thanks
Can't tell where your error is unless you post the full details of your calculation.
Seriously?
Einitial=Efinal
You don't need the "d" term and try adding the 1.5 term instead of subtracting since there's thermal energy at the bottom of the ramp.
Hey, thanks for your constructive contribution to my inquiry. I attempted the solution in the way you suggested. I get v to equal 6.3228, which is unfortunately not the correct answer.
I'm wondering if I may have to consider the total length the object travels...like adding Δy to the length of the rough surface.
Really? The equation i get is mgh = 0.5mv2 + umgd
Solve for v and you should get about 5.956173268m/s.
Oh man, you are correct. I made an algebra mistake while moving everything over to solve for v. Good catch. And thanks a bunch!
Seriously?
It had been pointed out to you that mv2d was wrong. You replied that you tried taking out the d and it made matters worse, but you didn't post the calculation. There's also the matter of where 1.532622 came from. I don't see an explanation of that.
(just got up :zzz:)
racecar12 said:
Seriously?
yes, seriously
that is why we usually insist on you showing your full calculations
please do so next time, and save yourself some time! :smile:
1. What is the purpose of the "Block Jump from Ramp: Find Speed v" experiment?
The purpose of this experiment is to determine the speed of a block as it jumps off a ramp and lands on the ground. This can help us understand the relationship between height, distance, and speed in a projectile motion.
2. How is the speed of the block calculated in this experiment?
The speed of the block can be calculated using the formula: v = √(2gh), where v is the speed, g is the acceleration due to gravity, and h is the height of the ramp. This formula assumes no air resistance and that all of the initial potential energy is converted into kinetic energy.
3. What equipment is needed for the "Block Jump from Ramp: Find Speed v" experiment?
The equipment needed for this experiment includes a ramp, a block, a measuring tape or ruler, a timer, and a level surface for the block to land on. Optional equipment includes a motion sensor or video camera for more accurate timing.
4. What factors can affect the speed of the block in this experiment?
The speed of the block can be affected by the height of the ramp, the surface of the ramp, the mass of the block, and any external forces like air resistance. The angle of the ramp and the surface the block lands on can also affect the speed.
5. How can the results of the "Block Jump from Ramp: Find Speed v" experiment be used in real life?
The principles learned from this experiment can be applied in various real-life situations such as calculating the speed of a projectile, understanding the motion of objects in freefall, and designing structures to withstand impacts. This experiment also helps in developing critical thinking and problem-solving skills.
13K
