Block on incline plane
  • Thread starter metrocard
http://img687.imageshack.us/img687/8417/screenhunter002.jpg [Broken]
I don't know.
I don't even know where to begin...
Answers and Replies
This involves energy right? So kinetic and potential energies have to be considered.
(I just finished learning this, so I might be wrong) :)
Looks like a webwork problem to me... :D
AEM
360
A good starting point is to draw a free body diagram and identify the forces acting.
Then a second good step is to introduce a suitable coordinate system One wit hte x axis parallel to the inclined plane would do. Then choose a suitable y axis.
After you do that, you might want to write down Neton's second law of motion for those coordinate directions.
Start with:
Wnc = [tex]\Delta[/tex]K + [tex]\Delta[/tex]U
for part 1, you are looking for Vf
this gives you...
-(0.21)(37.8)(7.96) = (1/2)(4.5)(Vf2) - (4.5)(9.8)(4.1)
turns out that Vf is 7.23m/s .. tell me if it's right.
for part 2, you are looking for s, the distance
you use the same: Wnc = [tex]\Delta[/tex]K + [tex]\Delta[/tex]U
- (0.21)(4.41)(s) = 0 - (1/2)(4.5)(7.232)
s = 126.99m
http://img693.imageshack.us/img693/9601/screenhunter002d.jpg [Broken]
What do I do now?
I found the Force of Friction by doing Ff=uFn. 21*37.8=7.938
How do I find the speed?
Do I use:
(Vf)^2=(Vi)^2+2ad
But then to find the Vf, I need the distance and acceleration.
How do I find the distance and acceleration?
For the acceleration, I did.
a=g*sin(31) to get 5.047. That's the acceleration if there was no friction, right?
Then I used multiplied that by 4.5 to get the net force. I then subtracted the force of friction from the net force to get: 14.78
I divided the new net force by 4.5 to get 3.28 as the new acceleration.
Is that correct?
AEM
360
What do I do now?
Do I use:
(Vf)^2=(Vi)^2+2ad
Is that correct?
That is certainly a good start. You can use
[tex] V^2_f = V^2_i + 2ad [/tex]
since the acceleration is a constant.
Another way to do it is to note that the Potential energy at the start goes into kinetic energy at the bottom minus the work to overcome friction. The work to overcome friction is the distance traveled times the frictional force. You can solve this energy equation for the velocity at the bottom and easily check your answer from your other method.
You can also use an energy equation to find out how far it travels. The kinetic energy at the bottom will go into work to overcome friction until the block stops.
Related Threads on Block on incline plane
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
19K
  • Last Post
  • Last Post
  • Last Post
