• Support PF! Buy your school textbooks, materials and every day products Here!
Block on Incline
  • Thread starter PierceJ
1. Homework Statement
http://i.minus.com/iVbsy2FomprcM.PNG [Broken]
2. Homework Equations
F=ma
3. The Attempt at a Solution
I'm struggling with the normal force and I'm not sure if the component of the force F is the cosine or sine. I see examples where its sine but that doesnt make any sense to me. Isn't the x direction supposed to be cosine?
Fn = mgsinθ
81.2cosθ - Fnμ = 9.23
-Fnμ = -65.897
PhanthomJay
456
F=ma
Fn = mgsinθ
-Fnμ = -65.897
For simplicity of the solution, the x axis is chosen to be the axis parallel to the incline, and the y axis is the axis perpendicular to the incline. In this manner, the applied force F is already in the in the x direction, and when you draw your FBD for the forces (you are missing at least one), a bit of geometry/trig and newton 1 in the chosen y direction will you give you the relationship between the normal force and weight. Since the applied force is already in the x direction and the normal force in the y direction, it is the weight force that needs to be broken up into its x and y components before applying Newton's Laws. And no, the x axis is not always the cos, it depends on what angle you are working with and the trig properties of a right triangle.
Okay.
So the normal force is equal to mgsinθ?
BvU
12,482
2,796
No. If you aren't sure, then you look at a limiting case: let ##\theta## go to zero, and you know that then the normal force is equal to mg. Forces the choice between ##mg\sin\theta## and ##mg\cos\theta## to be the latter because cos(0) = 1.
The normal force is ##\perp## the incline. In your FBD you should easily see that the angle between mg and the normal force is ##\theta## and not ##{\pi\over 2}-\theta##. So cosine to project mg on the perpendicular.
Don't associate x with the one and y with the other. Sometimes it's like this, other times it is the other way.
Related Threads for: Block on Incline
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
