Block on Spring with Friction
  • Thread starter Awwnutz
http://img48.imageshack.us/img48/7973/showmepley5.gif [Broken]
A relaxed spring with spring constant k = 50 N/m is stretched a distance di = 63 cm and held there. A block of mass M = 6 kg is attached to the spring. The spring is then released from rest and contracts, dragging the block across a rough horizontal floor until it stops without passing through the relaxed position, at which point the spring is stretched by an amount df = di/10.
What is the coefficient of kinetic friction µk between the block and the floor?
I know i need to use the Work-Energy theorem.
I'm not really sure what i need to do?
The kinetic energy is 0, but i don't know how to find the work done by friction.
Answers and Replies
Hootenanny
Staff Emeritus
Welcome to Physics Forums,
You're spot on with using the work-energy theorem. What does that theorem state and how can we apply it to this problem?
Doc Al
Mentor
45,248
1,598
What's the definition of work?
Thanks,
The work-energy theorem is: change in Kinetic Energy=the work done by friction.
I believe the change in kinetic energy is 0, but its the work done by friction i can't seem to find.
Work is a force over a distance, correct?
So would the work done by friction mean its
(Coefficient of friction-M)(Fnormal)(distance)=Work done by friction?
Doc Al
Mentor
45,248
1,598
Make that the change in total mechanical energy (kinetic energy plus spring potential energy).
Exactly.
So the kinetic energy = 0
Work done by friction = M(58.86N)(.567m)
The potential energy = -Force(x2-x1)???
I'm not too familiar with potential energy yet. Is this the right formula i need to use?
If so what is the force i need? Is it F = -50N/m(x)?
If so what distance will i use, the distance it was initially stretched or the distance it comes to rest at?
Doc Al
Mentor
45,248
1,598
Good.
No. (Look up the formula for the energy stored in a stretched spring. Or derive it yourself.)
Since the force is not constant, you can't just use FΔx.
I used Elastic Potential Energy Formula: (1/2)kx^2
So i set it up like this:
Work by Friction_______Potential Energy Final____Potential Energy Initial__Kinetic
M(58.86N)(0.567m) = (1/2)(50N/m)(.063)^2 - (1/2)(50N/m)(.63)^2 + 0
I solved for M = -.29, but its saying this is the wrong answer and i thought i had it right.
Doc Al
Mentor
45,248
1,598
Good.
The work done by friction is negative, since it opposes the motion.
I see, i had the right answer it just needed to be positive and have a more exact answer. It was 0.294! Thanks alot for your help. I'm beginning to understand this now. I wish i had you as my teacher, i don't seem to learn too much from the one i have right now. Thanks again.
Related Threads on Block on Spring with Friction
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
