Block pushed against a wall
  1. Aug 16, 2007 #1
    A block of mass 2 kg is pushed against a rough vertical wall with a force of 40N , co-efficient of static friction being 0.5.Another horizontal force of 15N is applied on the block in the direction parallel to the wall.
    2. Relevant equations
    Will the block move? If yes, in which direction? If no, find the frictional force exerted by the wall on the block
    3. The attempt at a solution
    The first thing which puzzles me about this problem is that in which direction should the parallel force be acting? I think the block will move;but do we take into consideration the gravitational force acting downwards?
  3. Aug 16, 2007 #2
    PhanthomJay
    The problem statement is incomplete as worded. It should state in which direction (up or down) the parallel force is acting. Does it?
  4. Aug 16, 2007 #3
    Doc Al
    Staff: Mentor
    Sideways! (I admit that that's tricky.)
    You need to consider all forces acting parallel to the wall, including gravity.
  5. Aug 16, 2007 #4
    Well the problem doesn't state that but what would be the solution both ways(for up and down)?
  6. Aug 16, 2007 #5
    PhanthomJay
    Oh, sorry, Doc is right, forget my response, as i was envisioning a vertical force parallel to the wall.
  7. Aug 16, 2007 #6
    Ok...could you elaborate a little on how the net motion is sideways?
  8. Aug 16, 2007 #7
    Doc Al
    Staff: Mentor
    First identify all the forces acting on the block parallel to the wall. Without friction, what would be the net force parallel to the wall (magnitude and direction)? Is friction enough to prevent the motion?
Similar Discussions: Block pushed against a wall
Loading...
