Blondel's Theorem: A Math Mystery Explained
In summary, Blondel's Theorem, developed by engineer Andre E. Blondel in the early 1890s, states that to accurately meter energy in an alternating current circuit, the number of stators (electromagnetic coils) used must be one less than the total number of wires in the circuit. However, meter manufacturers have found ways to design special meters that can provide adequate accuracy without strictly following this rule. While these deviations may work in some cases, they can lead to inaccuracies if the voltages in the circuit are not well balanced.
navanath
tell me somthing about blondels theorem
Welcome to PF!
Hi navanath ! Welcome to PF! :smile:
From "[URL …
Welcome to the Underground Overhead Metering School home page. This non-profit school provides professional training for the dedicated electrical linemen and technicians that provide safe and reliable electrical energy throughout the United States. This school would not be possible without the support and dedication of vendors, manufacturers, and planning committee membe
Blondel’s Theorem​
Metering theory for alternating current circuits was in its infancy in the early 1890’s. In 1893 an engineer by the name of Andre E. Blondel set forth the basic rules for metering all alternating current circuits.
Simply stated:
Count the number of wires in any circuit (including the neutral). One less stator than the total number of wires in the circuit is required to correctly meter the energy flowing in the circuit.
For example:
A 2-wire circuit requires a single stator meter.
A 3-wire circuit requires a two-stator meter.
A 4-wire circuit requires a three-stator meter.
In practice, Blondel’s Theorem is not strictly adhered to in all metering applications. Meter manufacturers have found ways to design special meters that allow adequate accuracy without the required number of stators. One such meter is the common (form 2S) house meter. It is a single stator meter that is specifically designed to meter a 3-wire circuit. In addition, some metering circuits may be connected in special configurations, which may also provide adequate levels of accuracy without the required number of stators.
A quite appropriate question to ask is, "Was Blondel wrong"? The answer is, "No"! Any time a metering circuit does not strictly adhere to Blondel’s Theorem, it is subject to inaccuracies when the voltages present in the circuits are not balanced. Once again, to emphasize the previous sentence, when cheating on Blondel’s Theorem, it is the balance of the voltages that are important, not the balance of currents flowing in the circuits! Most voltages in modern alternating current circuits are adequately balanced to permit these deviations from the rules laid forth by Blondel.
What is Blondel's Theorem?
Blondel's Theorem, also known as the "Math Mystery Explained", is a mathematical theorem that was first published by French mathematician Jean-Jacques d'Ortous de Mairan Blondel in 1774. It states that for any positive integer n, if we write down the multiples of n and add up all the digits in each number, the sum will always be divisible by 9.
Why is Blondel's Theorem significant?
Blondel's Theorem is significant because it provides a simple and elegant way to determine if a number is divisible by 9. This can be useful in various fields such as banking, coding, and cryptography.
How is Blondel's Theorem proven?
Blondel's Theorem can be proven using basic algebra. The key is to recognize that the sum of the digits in a number is equivalent to the remainder of that number when divided by 9. By using this property and some algebraic manipulation, the theorem can be easily proven.
What are some applications of Blondel's Theorem?
Blondel's Theorem has various applications in different fields. In banking, it can be used to quickly check if a credit card number is valid. In coding, it can be used to create error-detecting codes. In cryptography, it can be used to create secure encryption algorithms.
Can Blondel's Theorem be extended to other numbers besides 9?
No, Blondel's Theorem only applies to the number 9. However, there are similar theorems that apply to other numbers, such as the divisibility rule for 3 and the divisibility rule for 11.
  • Quantum Interpretations and Foundations
  • Other Physics Topics
  • Art, Music, History, and Linguistics
