- #71
T C
- 320
- 8
What kind of nozzles are more suitable for the job? I mean whether a c/d nozzle or a simple divergent nozzle?
Where are you going with this/what is your point? Yes, when speed increases pressure drops and when speed decreases again, pressure goes back up. We all know this. So what?T C said:Give above is an example that at very high speed, there are diffusers available that can convert that high speed into pressure. This is a technology used by Twister BV, a Netherlands based company for dehydrating natural gas and other gaseous products. At first, high pressure gas is released and that has been given a twist so that a vortex is formed. At the centre, the temperature falls low and all the humidity remaining in the input gas is being liquefied. Due to the centrifugal force, the liquid droplets were thrown to external wall and then extracted out. Whatsoever, it is to be noted that after re-compression, the pressure level will be about 75% of the initial input level.
Certainly: if they couldn't, they wouldn't be doing their job! Still not sure why you are pointing this out...T C said:What I want to mean is that there are diffusers available at present that can convert high speed into pressure without much loss.
Oh, ok. Well neither of them said "great loss", but rather compared the loss between different scenarios relative to each other ("greater loss"). Nor is "great loss" quantified anywhere. So I don't think that necessarily contradicts what they said.T C said:
Yes: by definition a diffuser - any diffuser - converts speed into pressure (kinetic energy into potential/pressure energy):T C said:Do you agree that with a properly designed diffuser, high speed can be converted into pressure?
https://en.wikipedia.org/wiki/Diffuser_(thermodynamics)A diffuser is "a device for reducing the velocity and increasing the static pressure of a fluid passing through a system”.
That's theory and nobody can deny that. What I want to show is that it's practically possible too.russ_watters said:Yes: by definition a diffuser - any diffuser - converts speed into pressure (kinetic energy into potential/pressure energy):
T C said:That's theory and nobody can deny that. What I want to show is that it's practically possible too.
If the recovery is 75%, do you consider that efficient or not.boneh3ad said:The question is efficiency.
T C said:If the recovery is 75%, do you consider that efficient or not.
