Boiling an egg at high altitude
In summary, higher altitude means lower boiling point temperature, which means slower heat transfer and thus slower cooking of an egg.
Jan Hill
63
an egg boiled for 4 minutes at the top of a mountain does not harden
pressure is lower at the top of a mountain than at sea level. Is the issue here the fact that pressure inside the egg does not build up sufficiently to harden it at the top of the mountain where in fact, it's necessary to use temperatures greater than 100 degrees Celsius to cook it
Not quite.
Whats the highest temperature you can heat water to (in an open container)
What happens to this temperature at altitude?
the highest temp for water in an open container is 100 degrees Celsius and I don't know what happens to this temp at altitude
As an extreme: how hard is it to boil water in outer space? Why?
no density and no pressure in space
apparently, time X temp cooks the egg
lower temp at high altitude requires more time
Thank you for your help!
It sounds like you Googled it. Do you understand it?
Well, I do get the concept of never something for nothing and balancing a loss of temperature with an increase in amount of time needed to cook the egg.
Hey man, it's good of you to ask though.
The highest temperature you can get is boiling point (which is 100C at sea level)
Boiling point decreases with altitude, an easy way to remember this is to imagine the weight of air holding the water in the liquid - at lower pressure it's easier for the water to escape as steam and so the boiling point is lower.
In simple terms - Yes it's possible to boil at egg at altitude, however, it will take longer for the water to boil the egg hence acknowledgment of low pressure and less oxygen.
So, in summary, the critical bit to understand in this whole thing is that, at lower pressure water boils at a lower temperature. So, your water might only reach 90C and won't get any hotter. It's still boiling, but the egg isn't cooking as much.
You guys are close. Cooking is a heat transfer problem. To make heat go from the hot object (boiling water) to the cold object (egg) you need a temperature difference (Th-Tc). Since water's boiling point temp is reduced at altitude, the rate of heat transfer (proportional to Th-Tc) is less. This is complicated by the fact that cold temperature TC is increasing the longer the egg is in the water.. but it will never surpass hot temperature Th.
Not sure why you need to make it more complicated. If the water never reaches 100C, it's pretty straightforward that the egg will take longer to cook.
Or - if you are high enough - egg will never cook. If memory serves me well somewhere below 20 km water boils at about body temperature. At 36.6 deg C egg can start to stink quite fast, but it won't solidify.
It also means you can't make a decent cup of tea at high altitude - something which would cause a problem for the British attempt on Everest!
I was teaching this to somebody once and their reaction was to ask if mountaineers could use pressure cookers to make tea! Which means they at least understood the physics, if not much about mountaineering
What happens to the boiling point of water at high altitude?
At high altitudes, the atmospheric pressure decreases, which in turn lowers the boiling point of water. This means that water will boil at a lower temperature than at sea level.
How does this affect the process of boiling an egg?
Since the boiling point of water is lower at high altitudes, the eggs will take longer to cook. This is because the water will not reach the same temperature as it would at sea level, resulting in a slower cooking process.
Can I still use the same cooking time as I would at sea level?
No, you will need to adjust the cooking time for boiling eggs at high altitudes. As a general rule, it is recommended to add an extra 20% of the original cooking time to ensure that the eggs are cooked properly.
Why do I need to adjust the cooking time?
The lower boiling point of water at high altitudes means that the eggs will not be exposed to the same temperature and cooking time as they would at sea level. Therefore, adjusting the cooking time ensures that the eggs are cooked thoroughly.
Are there any other factors to consider when boiling eggs at high altitude?
Yes, the air at high altitudes is also drier, which can cause the eggs to lose moisture more quickly. To prevent this, it is recommended to add some extra water to the pot while boiling the eggs.
  • Thermodynamics
  • Thermodynamics
  • Mechanical Engineering
  • Thermodynamics
9K
