Boiling point/freezing point
In summary, the conversation discusses converting between temperature scales using a new scale based on the freezing and boiling points of benzene. The freezing and boiling points of water in this scale are unknown and need to be calculated using a conversion method.
metalmagik
131
If a temperature scale were based on the freezing point (5.5 C) and boiling point (80.1 C) of benzene and the temperature difference between these points was divided into 50 units (called X), what would be the freezing and boiling points of water in X?
No idea
What does this question even mean? Please help!
It is about converting between different temperature scales. You are told how the new scale is constructed - its zero is at 5.5 deg C, there are 50 X between 5.5 and 80.1 deg C. You have to find out a way of converting between deg C and X, just like you convert between F and C.
I can provide a clarification and a solution to this question. The question is asking about a hypothetical temperature scale based on the freezing and boiling points of benzene, a common organic compound. This scale divides the temperature difference between the two points into 50 units, called X. The freezing point of benzene is 5.5 C and the boiling point is 80.1 C, so the temperature difference is 80.1 - 5.5 = 74.6 C. Dividing this by 50 units (X) gives us 74.6/50 = 1.492 C per unit.
Now, we need to determine the freezing and boiling points of water on this scale. Water's freezing point is 0 C and its boiling point is 100 C on the Celsius scale. To convert these values to the new scale, we need to find out how many units (X) correspond to 1 C on the Celsius scale. This can be done by dividing 1 C by 1.492 C per unit, giving us 0.67 units (X) per 1 C.
To find the freezing point of water on the new scale, we multiply 0 C by 0.67 units (X) per 1 C, giving us 0 units (X). Therefore, on this new scale, the freezing point of water is 0 units (X). Similarly, the boiling point of water on the new scale can be found by multiplying 100 C by 0.67 units (X) per 1 C, giving us 67 units (X). Therefore, the boiling point of water on this new scale is 67 units (X).
In conclusion, on this hypothetical scale based on the freezing and boiling points of benzene, the freezing point of water is 0 units (X) and the boiling point is 67 units (X). I hope this helps clarify the question and provides a solution.
1. What is the difference between boiling point and freezing point?
The boiling point of a substance is the temperature at which it changes from a liquid to a gas, while the freezing point is the temperature at which it changes from a liquid to a solid.
2. Does the boiling point and freezing point of a substance always stay the same?
No, the boiling point and freezing point of a substance can vary depending on factors such as pressure, altitude, and the presence of impurities.
3. How can I determine the boiling point and freezing point of a substance?
The boiling point and freezing point of a substance can be determined through experiments in a controlled environment or by consulting a reference table or database.
4. What is the significance of the boiling point and freezing point in chemistry?
The boiling point and freezing point of a substance are important physical properties that can help identify and characterize a substance, as well as determine its behavior under different conditions.
5. Can the boiling point and freezing point of a substance be used to predict its state of matter?
Yes, the boiling point and freezing point can give an indication of the state of matter a substance will be in at a certain temperature and pressure. For example, if the boiling point is lower than the given temperature, the substance will be a gas at that temperature.
12K
