tgt
- 522
- 2
How to do bold letters and larger font with certain words in Latex?
When I do \Large for example, it makes everything large. But I just want a line to be large.CompuChip said:\textbf (<-- use for a good reason)
\mathbf
\scriptsize \tiny \large \Large \huge \Huge \HUGE (<-- use for a very good reason -- the farther to the right you go, the better the reason should be )
To make text bold in Latex, you can use the \textbf{ } command or the \bfseries declaration before the text you want to make bold.
Yes, you can change the font size in Latex by using the \fontsize{ }{ } command. The first argument specifies the font size and the second argument specifies the line spacing.
Yes, you can use the \textbf{\large } command to make text bold and larger at the same time. This will make the text larger than the normal font size.
To make specific words or phrases stand out in your document, you can use the \emph{ } command. This will italicize the text and make it stand out from the rest of the document.
Yes, you can combine different formatting commands in Latex. For example, you can use the \textbf{\large \emph{ }} command to make text bold, larger, and italicized at the same time.
