What Is the Correct Bolt Diameter for a Rigid Flange Coupling?
In summary, the problem involves a rigid flange coupling with 3 bolts secured by 200mm PCD and subjected to a torque of 10kN/m. The bolt diameter needs to be determined and is calculated by first finding the bolt area using the material shear stress and factor of safety, and then taking into account the number of bolts. The final bolt diameter is 17mm.
ilahac
A rigid flange coupling, secured by 3 bolts on a PCD of 200mm, is subjected to a torque of 10kN/m. Determine the bolt diameter (to the nearest mm)
Bolt material shear stress = 225N/mm^2
Factor of safety = 2
Hi, I'm chris, I'm an aeronautical engineering student and I'm a little puzzled by a step in the above problem. I don't understand why I have to figure out the bolt area then reverse the step in the following calculation. I'm really just looking for some clarity, y'know, someone to say "yeah, that's correct". Any help appreciated, my work is below.
Working stress = 225N/mm^2 ÷ 2 = 112.5N/mm^2
Torque = Force*Radius => Force = Torque÷Radius
= 10*10^3÷0.1
= 10*10^4 kN
Stress=Force÷Area => Area = Force÷Stress
= 10*10^4÷112.5
= 888.8mm^2
Bolt area = 888.8÷3
= 296.2mm^2
Diameter = √(3*296.2 ÷ ᴨ)
= 16.81mm
= 17mm
Looks correct except for the '3' in the bolt diamter - you have already takne into account that there are 3bolts, by dividing 888.8mm^2 by 3.
So I get a bolt radius of 9.7, so a diameter of 20mm
(rounded to nearest mm)
Hi Chris,
Thank you for sharing your work and questions. It seems like you have approached the problem correctly, but there is a slight misunderstanding in the calculation of bolt area. The reason for dividing by 3 is to account for the three bolts, but the resulting area should be multiplied by 3 instead of divided by 3. This is because each bolt will have the same area and will contribute to the total area of the coupling.
So, the correct calculation for bolt area would be:
Bolt area = 888.8 * 3 = 2666.4 mm^2
Then, using the same formula for diameter:
Diameter = √(4 * 2666.4 ÷ ᴨ) = 23.2 mm = 23 mm (rounded to nearest mm)
I hope this helps clarify the calculation and provides the confirmation you were looking for. Keep up the good work!
What is a bolt diameter and why is it important?
A bolt diameter refers to the size of the shank or body of a bolt. It is important because it determines the strength and load-bearing capacity of the bolt, as well as the compatibility with other hardware such as nuts and washers.
How do I measure the diameter of a bolt?
The diameter of a bolt is typically measured using a caliper or ruler. Place the caliper or ruler across the widest point of the shank and read the measurement in inches or millimeters. It is important to measure the diameter accurately to ensure the proper size bolt is used.
What is the standard bolt diameter size?
The standard bolt diameter size varies depending on the type and grade of the bolt. However, the most commonly used bolt diameter sizes range from 1/4 inch to 1 inch. It is important to consult a bolt size chart or a hardware specialist to determine the appropriate size for a specific application.
Is there a difference between bolt diameter and thread size?
Yes, bolt diameter and thread size are two different measurements. Bolt diameter refers to the size of the shank, while thread size refers to the size and spacing of the threads on the bolt. It is important to consider both measurements when selecting a bolt for a specific application.
Can I use a bolt with a slightly different diameter than the recommended size?
It is not recommended to use a bolt with a different diameter than the recommended size. Using a bolt with the wrong diameter can affect the strength and load-bearing capacity of the bolt and may lead to failure or damage. It is important to use the correct size bolt for the intended application.
9K
