Boltzmann bosons factor two
In summary: Same with ##E_n + E_{n'}## and ##E_{n'} + E_n##. You can't just add these things together and count these combinations separately. Since you are counting the same thing twice, you have to divide by 2.So in summary, the conversation discusses Hamilton's operator and its eigenvectors and eigenvalues, as well as the definition of a new Hamilton's operator. It then introduces a symmetry property for the acceptable eigenvectors, and discusses two different ways of writing the set of pairs of eigenvalues and eigenvectors. The conversation then moves on to discussing the application of Boltz
jostpuur
2,116
Introduction and warm up
Suppose [itex]H_0[/itex] is some Hamilton's operator that has eigenvectors [itex]|\psi_n\rangle[/itex] for [itex]n\in\mathbb{N}[/itex] with some eigenvalues [itex]E_n[/itex] so that
[tex]
H_0|\psi_n\rangle = E_n|\psi_n\rangle,\quad \forall n\in\mathbb{N}.
[/tex]
Suppose we define a new Hamilton's operator by setting [itex]H=H_0\otimes \textrm{id}+\textrm{id}\otimes H_0[/itex]. Now one possible set of eigenvectors is given by a product [itex]|\psi_n\rangle\otimes |\psi_{n'}\rangle[/itex] for all [itex](n,n')\in\mathbb{N}^2[/itex], and these have eigenvalues [itex]E_n+E_{n'}[/itex].
Suppose we insist that only those vectors [itex]|\psi\rangle[/itex], which satisfy the symmetry property
[tex]
(\langle x|\otimes\langle y|)|\psi\rangle = (\langle y|\otimes \langle x|)|\psi\rangle
[/tex]
are allowed. If the original [itex]H_0[/itex] was interpreted as acting on a state of some particle, now [itex]H[/itex] will be acting an a pair of bosonic particles.
Now the acceptable eigenvectors will be (up to a factor) [itex]|\psi_n\rangle\otimes |\psi_{n'}\rangle + |\psi_{n'}\rangle\otimes |\psi_n\rangle[/itex].
Suppose we would like to write down a formula for the set of pairs [itex](E,|\psi\rangle)[/itex] which would contain all the eigenvalues and eigenvectors. There is two obvious ways to write down the set. The simplest formula for the set of pairs is
[tex]
\Big\{\big(E_n+E_{n'}, |\psi_n\rangle\otimes |\psi_{n'}\rangle + |\psi_{n'}\rangle\otimes |\psi_n\rangle\big)\;\Big|\; n,n'\in\mathbb{N}\Big\}
[/tex]
However, this formula contains some pairs in redundant way, and we might also write down the set of pairs as
[tex]
\Big\{\big(E_n+E_{n'}, |\psi_n\rangle\otimes |\psi_{n'}\rangle + |\psi_{n'}\rangle\otimes |\psi_n\rangle\big)\;\Big|\; n,n'\in\mathbb{N},\; n\leq n'\Big\}
[/tex]
These two formulas define the same set, because the elements of these two sets are the same. As long as we are only interested in the set itself, there is no trouble in sight.
The problems start here
Suppose we would like to apply Boltzmann's distribution to this pair of bosons under the assumption that they interact with warm surroundings of some temperature [itex]T[/itex]. There are two obvious options available.
The first option is that we begin by allowing the domain of the index pair [itex](n,n')[/itex] to be the full set [itex]\mathbb{N}^2[/itex]. There does not seem to be anything wrong with this choice alone. Once this decision has been made, it seems reasonable to define, perhaps axiomatically, the probability distribution to be proportional to the function
[tex]
(n,n')\mapsto e^{-\frac{E_n+E_{n'}}{T}},\quad\forall n,n'\in\mathbb{N}
[/tex]
Suppose we regret the choice of domain, and would like to shrink it with the additional costraint [itex]n\leq n'[/itex]. In the shrunk domain the new probability distribution, which would be equivalent to the just axiomatically defined one, would be proportional to
[tex]
(n,n')\mapsto \left\{\begin{array}{ll}
e^{-\frac{2E_n}{T}},\quad & n=n' \\
2e^{-\frac{E_n+E_{n'}}{T}},\quad & n<n' \\
\end{array}\right.
[/tex]
The second option is that we begin by allowing the domain of the index pair [itex](n,n')[/itex] to be the set [itex]\{(n,n')\;|\;n,n'\in\mathbb{N},\; n\leq n'\}[/itex]. There does not yet seem to be anything wrong with this choice either. Once this decision has been made, it seems reasonable to define, perhaps axiomatically, the probability distribution to be proportional to the function
[tex]
(n,n')\mapsto e^{-\frac{E_n+E_{n'}}{T}},\quad\forall n,n'\in\mathbb{N},\; n\leq n'
[/tex]
Suppose we regret the choice of domain, and would like to extend it to the full set [itex]\mathbb{N}^2[/itex]. In the extended domain the new probability distribution, which would be equivalent to the just axiomatically defined one, would be proportional to
[tex]
\frac{1}{2}e^{-\frac{E_n+E_{n'}}{T}},\quad & n\neq n' \\
\end{array}\right.
[/tex]
The question: Now we have two different Boltzmann's distributions, which both look reasonable, but since they are different, they cannot be both right. So is one of these right, and the other one wrong? Which way around would be the correct answer?
You have to use the proper partition function. In the first case, the partition function will have factor 1/2 to account for the over-counting of indistinguishable cases.
While using the domain [itex]\mathbb{N}^2[/itex], in the first case the partition function will be
[tex]
Z(T) = \sum_{n,n'=0}^{\infty} e^{-\frac{E_n+E_{n'}}{T}}
[/tex]
and the probability distribution will be
[tex]
p(n,n') = \frac{1}{Z(T)}e^{-\frac{E_n+E_{n'}}{T}},\quad n,n'\in\mathbb{N}
[/tex]
Did you mean to claim that the partition function should be something different, with some factor [itex]\frac{1}{2}[/itex] somewhere? I don't believe that that would be right, because bringing such factors in would imply that
[tex]
\sum_{n,n'=0}^{\infty}p(n,n')=1
[/tex]
would no longer hold.
Equivalently, while using the domain [itex]\{(n,n')\;|\;n,n'\in\mathbb{N},n\leq n'\}[/itex], in the first case the partition function will be
[tex]
Z(T) = \sum_{n=0}^{\infty} e^{-\frac{2E_n}{T}} + 2\underset{n<n'}{\sum_{n,n'=0}^{\infty}} e^{-\frac{E_n+E_{n'}}{T}}
[/tex]
In the second case, which will not be equivalent to the first one, while using the domain [itex]\{(n,n')\;|\;n,n'\in\mathbb{N},n\leq n'\}[/itex], the partition function will be
[tex]
Z(T) = \underset{n\leq n'}{\sum_{n,n'=0}^{\infty}} e^{-\frac{E_n+E_{n'}}{T}}
[/tex]
Did you mean that this second option looks more right than the first one? The second option has some kind of over-counting removed, and it looks nice, but how do you know that the over-counting was wrong in the first place?
[tex]
[/tex]
The sum in the partition should run over all states. If you can't distinguish between ##(n,n')## and ##(n',n)##, then these two cases correspond to the same state, hence the sum you have there is not correct: you are over-counting.
See, e.g., http://theory.physics.manchester.ac.uk/~judith/stat_therm/node84.html
Likes Jilang
I explained two different ways to define the Boltzmann's distribution, and put forward a question that which one of them is right. Your answer is the same as that the first option was wrong, and the second option was right.
1. What are Boltzmann bosons?
Boltzmann bosons are a type of elementary particle that follows the laws of quantum mechanics. They are named after the physicist Ludwig Boltzmann and are characterized by their integer spin, meaning they have a whole number value for their intrinsic angular momentum. Examples of Boltzmann bosons include photons and helium-4 atoms.
2. How are Boltzmann bosons different from other particles?
Boltzmann bosons differ from other particles, such as fermions, in their behavior under certain conditions. Unlike fermions, which follow the Pauli exclusion principle and cannot occupy the same quantum state, Boltzmann bosons do not have this restriction and can occupy the same state. This allows for the formation of a Bose-Einstein condensate, a state of matter where a large number of bosons occupy the same quantum state.
3. What is the Boltzmann factor for bosons?
The Boltzmann factor for bosons is a mathematical expression used to describe the probability of a boson occupying a particular quantum state at a given temperature. It is represented by the term e-E/kT, where E is the energy of the state, k is the Boltzmann constant, and T is the temperature in Kelvin.
4. How does the Boltzmann factor for bosons relate to the Bose-Einstein distribution?
The Boltzmann factor for bosons is a key component in the Bose-Einstein distribution, which is a statistical distribution used to describe the number of bosons in different energy levels in a Bose-Einstein condensate. The distribution takes into account the energy levels of the bosons, the temperature, and the number of particles present in the system.
5. What are the practical applications of understanding the Boltzmann factor for bosons?
Understanding the Boltzmann factor for bosons has many practical applications in fields such as physics, chemistry, and engineering. It is used to study the behavior of particles in systems at different temperatures, such as in the formation of Bose-Einstein condensates. It also plays a role in the development of technologies such as lasers and superconductors, which rely on the properties of bosons to function.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
