Book Pendulum Oscillation
  • Thread starter jellyman
jellyman
1. In the figure below, a book is suspended at one corner so that it can swing like a pendulum parallel to its plane. The edge lengths along the book face are 28 cm and 19 cm. If the angle through which it swings is only a few degrees, what is the period of the motion?
2. I=(ML^2)/12
I=(ML^2)/3
T=2∏√I/M*G*dcom
3. I got dcom by using the distance formula and it's .1692 m
Then I tried to using both inertia equations and using length, width. Then I plugged in all the numbers. (multiple attempts)
All wrong answers (.788s, .394s, 1.062s)
Appreciate your help! :)
Answers and Replies
Simon Bridge
17,874
1,657
You don't have the right moments of inertia.
jellyman
Oh.
Then that leaves me with I= M(a2 + b2)/12.
That gave me a period of .476 second which has been marked wrong.
Simon Bridge
17,874
1,657
Yep - that's the wrong moment of inertia as well.
That is for an oblong rotating about it's center.
You book is not rotating about it's center - otherwise it could not act as a pendulum.
Look up: parallel axis theorem.
jellyman
I|| = [itex]\frac{1}{12}[/itex]Mdcom2 + Mdcom2
This doesn't make sense though because it leaves me with an M on the top in the equation for T.
EDIT: I asked somewhere else and they used T = 2π√[L/g] and got .83 seconds. This doesn't sound quite right. It's too easy this way!
Simon Bridge
17,874
1,657
$$I_{CM}=\frac{M}{12}(a^2+b^2)$$
##r## is the distance from the corner to the center of the book; by pythagoras: $$r^2=\frac{a^2}{4}+\frac{b^2}{4}$$... therefore, by the parallel axis theorem: $$I=I_{CM}+Mr^2=\cdots$$... you finish up.
Simon Bridge
17,874
1,657
That would be pretty normal ... he's modeled the book as a simple pendulum.
For a simple pendulum ##I=ML^2## ... completing the calculations above will tell you how taking the mass distribution into account affects the period.
http://en.wikipedia.org/wiki/Pendulum_(mathematics)#Compound_pendulum
Suggested for: Book Pendulum Oscillation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
