Boolean algebra
  • Thread starter snoggerT
show that x'yc+xy'c+xy = yc + xc + xy
- my first attempt at the solution was this:
c(x'y+xy')+xc >>> c(y+x)+xc >>> yc+xc+xy
I can't remember if that is valid or not. I seem to remember that A'B=B, but not sure. Can somebody please help me?
Answers and Replies
Can you explain your notation? Specifically, what is c and ' ? I assume AND is denoted by nothing, and I figure ' is complement but I'm not entirely sure.
- the ' is for a complement. x, y and c are just input variables (1 or 0). The "+" is for OR. so basically the problem ask to show how to reduce the left hand side to get whats on the right hand side using boolean algebra properties.
Ok, well A'B is not the same as B. x'y + xy' is actually the definition of XOR, not OR, so you'll have to try something different. Try to use clever methods of ANDing always true statements or ORing ones that do not change the result (examples, xyc + xyc = xyc, xy=xy(c+c').
alright. I remember now about using xy(c+c'), but I get stuck here...
x'yc+xy'c+xyc+xyc' >>> yc(x+x')+xy'c+xyc' >>> yc + xy'c + xyc'
I'm not real sure where to go from there.
You haven't used the other property I identified. X+X=X. Don't simplify until you have all the terms of the form xy(c+c') (where x, y and c are interchanged somehow)
I don't know...I'm lost here. Can you explain this in a little more detail:
"Try to use clever methods of ANDing always true statements or ORing ones that do not change the result"
I don't think I'm grasping what exactly that means, ands thats probably why I'm not seeing how to work out the problem. More specifically, what would be an "always true statement"?
Well you already used it once: xy=xy(c+c') = xyc + xyc'. Obviously c+c' is always 1, so I have not changed the logical evaluation of that particular part at all and yet I have more pieces of the puzzle to use. That one xy term turned into 2 different terms that you can combine with the other terms. Might I suggest that you combine x'yc + xyc to form (x'+x)yc = yc.
Can you do something similar with the rest using the other technique I suggested? Remember, X+X=X... or more accurately X = X + X. Maybe you find one term would be useful in simplifying two others?
I tried this, but I don't believe it was right.
x'c(y+y)+y'c(x+x)+xy(c+c')
what is the correct way to use x=x+x?
Ok well proving -> is proving hard for you. Perhaps you should try to prove it by starting with the right side and transforming it into the part that's left of the equals sign. Try this: Make each term on the right side of the equals sign a function of all of x, y and c. For example, yc=yc(x+x'). Distribute the terms and see if you can't make some of the distributed terms disappear. Be conscious at all times of what you want! Showing how the right side of the equation transforms into the left is a slightly simpler process.
going from the right side I get this:
yc(x+x')+xc(y+y')+xy(c+c') >>> xyc + x'yc +xyc+xy'c+xyc+xyc'
the three xyc terms should reduce down to just one xyc using this:
xy(c+c)
so I get: x'yc+xy'c+xyc+xyc' >>> x'yc+xy'c+xy(c+c') >>> x'yc+xy'c+xy
would that be correct?
bingo
and so to show from the left to the right, it's just the reverse of what I just did, right? Anyways, thanks for the help.
Yeah pretty much, no problemo
Related Threads on Boolean algebra
  • Last Post
  • Last Post
  • Last Post
  • Last Post
27K
30K
