Boundary Behaviour: Reflection, Refraction & Diffraction Explained
  • Thread starter Misr
  • Tags
    Boundary
In summary: This is also why you may have noticed diffraction patterns when light passes through a small opening, such as a pinhole camera.In summary, the concepts of reflection, refraction, and diffraction are all related to the wave nature of light. Reflection occurs when light strikes a boundary and is reflected back, while refraction occurs when light passes through a medium with different refractive indices. Diffraction occurs whenever a wave encounters an obstacle or passes through an opening, and its intensity depends on the size of the obstacle or opening in relation to the wavelength of the wave. I hope this helps to clear up any misconceptions and deepen your understanding. Keep asking questions and exploring the fascinating world of physics!
Misr
385
Hellllllllllo World
1-
[url]http://www.physicsclassroom.com/Class/refrn/u14l3a1.gif[/url]
When a light ray falls on the boundary between two media , some of the energy is reflected back to the first medium,some energy refracts and some energy is absorbed.
how is this exlplained?does it has something to do with the natural frequency of the electrons?
A light ray is a combination of different wavelengths ( different frequencies),if some frequencies were the same as the natural frequencies of the elctrons of water,they are absorbed and the other wavelengths are refracted and reflected.
Is that true?I mean does this explains the previous?Actually,I don't think so.
but this begs another question:What does the intensity of refraction and reflection depends upon?we study that it depends upon the difference between speed of light in the two median light falls from air to water ,most of the energy is reflected since the difference in speed between the two media is great.How to explain something like this?
2-I have a big misconception about diffraction:I think that in order for difrraction to occur, the wavelength must be smaller than the dimensions of the slit
if the wavelength is larger than the dimensions of the slit,diffraction cannot occur.
I got this misconception from the equation :
http://library.thinkquest.org/19537/media/equation1.gif
see this page
http://library.thinkquest.org/19537/Physics6.html
and since the value of the sine cannot be larger than one , I concluded the previous MISCONCEPTION
and also According to the equation,we can conclude that diffraction is greatest when the wavelength is equal to the dimensions of the slit
okay,
why do I call this a "misconception"?
see this page
If the boundary is merely an obstacle implanted within the medium, and if the dimensions of the obstacle are smaller than the wavelength of the wave, then there will be very noticeable diffraction of the wave around the object
http://www.physicsclassroom.com/Class/refrn/u14l1a.cfm
in addition to that,all the teachers assured the previous quotation that the dimensions of the obstacle are smaller than the wavelength of the wave, then there will be very noticeable diffraction of the wave around the object.
Thanks in Advance.
Hello there,
Thank you for sharing your thoughts and questions about the concepts of reflection, refraction, and diffraction. I can offer some explanations and clarifications to help deepen your understanding.
Firstly, the phenomenon of reflection and refraction can be explained by the wave nature of light. When a light ray strikes the boundary between two media, some of the light is reflected back because the boundary acts as a barrier, not allowing the light to pass through. The amount of reflection depends on the difference in the refractive indices of the two media. The refractive index is a measure of how much light slows down when it enters a medium. If the difference in refractive indices is large, then most of the light will be reflected. This is why, as you mentioned, when light falls from air to water, most of the energy is reflected because the refractive index of water is significantly different from that of air.
Now, for refraction. As you correctly stated, when light passes from one medium to another, it changes speed and direction. This is because the different wavelengths (colors) of light travel at different speeds in different media. This is also related to the natural frequency of electrons, as you mentioned. When light passes through a medium, it interacts with the electrons in that medium. If the natural frequency of the electrons matches the frequency of the light, then the light is absorbed by the electrons, resulting in a decrease in speed. This is why different colors of light bend at different angles when passing through a prism – they have different frequencies and interact with the electrons in the prism differently.
Now, let's move on to diffraction. Your misconception about diffraction is understandable, but it is important to remember that diffraction can occur for any size of the slit, as long as the wavelength of the light is comparable to the size of the slit. The equation you referenced is known as the "diffraction grating equation" and it is used to calculate the angles at which light will diffract when passing through a grating with evenly spaced slits. As the number of slits increases, the diffraction pattern becomes more pronounced. This is why, as you mentioned, diffraction is greatest when the wavelength is equal to the dimensions of the slit. However, this does not mean that diffraction cannot occur for larger or smaller wavelengths. In fact, diffraction is a fundamental property of waves and it occurs whenever a wave encounters an obstacle or
1. What is reflection?
Reflection is the process by which a wave (such as light or sound) bounces off a surface, changing its direction but not its frequency or wavelength.
2. How does refraction occur?
Refraction is the bending of a wave as it passes through a medium with a different density. This occurs because the speed of the wave changes as it enters the new medium.
3. What is diffraction?
Diffraction is the bending of waves around obstacles or through openings. It occurs when the size of the obstacle or opening is comparable to the wavelength of the wave.
4. Why is understanding boundary behavior important?
Understanding boundary behavior is important because it helps us understand how waves interact with different materials and structures. This knowledge is crucial in fields such as optics, acoustics, and seismology.
5. How does the angle of incidence affect reflection and refraction?
The angle of incidence is the angle at which a wave hits a boundary. When a wave is reflected, the angle of incidence is equal to the angle of reflection. Refraction, on the other hand, occurs when the angle of incidence is different from the angle of refraction, causing the wave to change direction as it enters a new medium.
  • Other Physics Topics
  • Electromagnetism
