PsychonautQQ
- 784
- 10
Can someone help me to understand what the boundary operator on a p-chain is doing exactly? Or boundary operators in general? I really need to develop a better intuition on the matter.
PsychonautQQ said:Can someone help me to understand what the boundary operator on a p-chain is doing exactly? Or boundary operators in general? I really need to develop a better intuition on the matter.
Maybe this helps a bit for a better intuition: https://www.physicsforums.com/threads/why-the-terms-exterior-closed-exact.871875/#post-5474443PsychonautQQ said:Can someone help me to understand what the boundary operator on a p-chain is doing exactly? Or boundary operators in general? I really need to develop a better intuition on the matter.
Yes, but since OP was defined on chains, it suggested Homology. Can you go up in Homology?fresh_42 said:You can equally increase the index and still have ##d^2=0##. Chain, cochain, who cares?
I don't know. In case one finds an example, which presumably can be done one way or another on a suitable sequence, it's probably not called boundary operator, chain and homological complex anymore. But the dualism invites to consider both. The cohomology sequences are the more interesting ones anyway. <duck & cover >WWGD said:Yes, but since OP was defined on chains, it suggested Homology. Can you go up in Homology?
To add a bit and to refresh my homology, formally, after Lavinia set the whole thing up: ## \partial ( [a,b]+[b,c]+[c,a] )= \partial [a,b] + \partial [b,c] + \partial [c,a] = (a-b)+(b-c)+(c-a) =(a-a)+(b-b)+(c-c)=0##lavinia said:Maybe an example will help:Geometrically, the triangle has empty boundary. Algebraically this means that the boundary operator applied to the 1-chain ##[a,b] + [b,c] + [c,a]## is 0 in the group of 0-chains. This is clear since each vertex occurs twice, once as the end point of a line segment, and once as the beginning point of a line segment so the vertices cancel in pairs.
Yes although usually the convention is ##∂[a,c] = [c]-[a]## with the opposite sign.WWGD said:To add a bit and to refresh my homology, formally, after Lavinia set the whole thing up: ## \partial ( [a,b]+[b,c]+[c,a] )= (a-b)+(b-c)+(c-a) =(a-a)+(b-b)+(c-c)=0##
I have seen integration viewed as a homological operator while differentiation is a cohomological one. Or do I have them mixed up?fresh_42 said:I don't know. In case one finds an example, which presumably can be done one way or another on a suitable sequence, it's probably not called boundary operator, chain and homological complex anymore. But the dualism invites to consider both. The cohomology sequences are the more interesting ones anyway. <duck & cover >
Can you generalize Stoke's theorem to more abstract theorems like Cech, etc?mathwonk said:I agree with lavinia. The fundamental fact in this topic is the stokes theorem, that says the integral of a differential form over the boundary of a surface is equal to the integral of the (exterior) derivative of the form over the surface itself. To actually compute this integral one must orient the surface and the boundary; then reversing the orientation gives the negative of the integral. Now we observe that differential forms can be added and multiplied by scalars and hence form a vector space. This allows us to make algebraic calculations with them that are quite useful.
The desire to imitate this computational facility in geometry leads us to ask for some similar structure on surfaces and their boundaries. A first enhancement is the observation that we can just as easily integrate, by pulling back via a parametriation, a parametrized surface, whether or not it is an embedding. The second one, is the fact that we might as well consider sums and scalar multiples of surfaces and curves, so we just define "chains" to be such formal linear combinations of parametrized surfaces. Their integrals are easily defined as the corresponding linear combinations of the integrals of the parametrized objects. Now we have made the set of parametrized surfaces, or curves, or..., into a vector space also.
To extend the stokes theorem to these generalized objects we must define the boundary of a linear combination of surfaces. Of course it should be the corresponding linear combination of the boundaries of the component surfaces in the linear expression. Thus the basic definition of a boundary of a p-chain, is as lavinia has illustrated, the case of the boundary of a p dimensional cube, e.g. an interval in case p=1. The next case is that of a square, where one has to accept that the boundary of a square should be the sum of the 4 edges, but that using algebra, we can orient an edge backwards and include a minus sign to correct this. So just look at the definition of the boundary of a square and see that it amounts to the oriented sum of the 4 edges.
Finally we obtain a beautiful duality between the geometric objects and the differential ones. I.e. the deRham theorem, that says (on an oriented compact manifold) the vector space of p-cycles modulo boundaries is isomorphic to the space of "closed" p-forms (derivative = 0, also called cocycles) modulo "exact" forms (those of form dw, also called coboundaries).
I hope this does not have too many errors.
I tend to confuse the two, too, so don't ask me. I only know I have a damn cochain complex which refuses to reveal its secrets, let alone to be integrated. So in case you remember the source, I would be interested to know.WWGD said:I have seen integration viewed as a homological operator while differentiation is a cohomological one. Or do I have them mixed up?
I'll ask my Korean friend-classmate who told me about it. Hope he remembers.fresh_42 said:I tend to confuse the two, too, so don't ask me. I only know I have a damn cochain complex which refuses to reveal its secrets, let alone to be integrated. So in case you remember the source, I would be interested to know.
The confusing thing is that in either case, you can evaluate and get a number in a linear way, so either could be a Cohomological operation. OTOH, when iterating the operation, it seems like you're going down dimension-wise: a triple integral becomes a double integral, going from 3D to 2D. Similar when you differentiate in that, unless you iterate ( as in Sin, Cos) , you end up with a ( 0-D) constant.fresh_42 said:I tend to confuse the two, too, so don't ask me. I only know I have a damn cochain complex which refuses to reveal its secrets, let alone to be integrated. So in case you remember the source, I would be interested to know.
Thanks; I always wonder about DeRham homology, one does not hear about it very often.mathwonk said:maybe i can't help, but integration is the operation that makes a differential form into a cochain, i.e. that is how it spits out a number when it sees a chain. so an integral sign with a diff form under it is a (de Rham) cochain; and thus (exterior) differentiation is analogous to the coboundary operator. But the term "cohomology operation" means something more sophisticated to me, again ask lavinia, but it means to me something like the steenrod squaring operation that is used to define (in milnor's book) certain characteristic classes. so indeed the coboundary operation does act on cohomology classes but i don't call that a cohomology operation.
https://en.wikipedia.org/wiki/Cohomology_operation
by the way WWGD, I think not only stokes but also de rham has a topological version, i.e. cohomology is dual to homology. but this is after dinner conversation not scholarly commentary. look in a good book like dold, lectures in algebraic topology.
WWGD said:Thanks; I always wonder about DeRham homology, one does not hear about it very often.
Me neither, but since for each theory there is a dual, there must be a theory of DeRham homology. I just have no clue on what it is, how it works.lavinia said:I have not heard of De Rham homology. What is it?
Seems like a nice exercise , to dualize a theory, or, in this case , to " anti-dualize" , since cohomology is already a dual to homology. We know the dual, we need the " anti-dual". I assume in the finite-dimensional case, it should not be too hard.WWGD said:Me neither, but since for each theory there is a dual, there must be a theory of DeRham homology. I just have no clue on what it is, how it works.
Why don't you do an " Insights" on this? and , please, edit your previous; seems interesting, but difficult to read.lavinia said:A little elaboration on @mathwonk 's explanations.
A cochain complex is a graded collection of modules ##C^{i}## together with a collection of module homomorphisms ##δ^{p}## that map ##C^{p}## into ##C^{p+1}##
such that ##δ^{p+1}δ^{p} = 0##.
Any cochain complex gives rise to cohomology groups ##H^{p}## of ##p##-cocycles modulo ##{P}-coboundaries. Differential forms on a manifold together with the exterior derivative form a cochain complex of modules over the real(or complex) numbers and therefore determine DeRham cohomology groups in each dimension ##p## are the closed ##p-forms## modulo the exact ##{p}##-forms.
One might ask what the relation of these cohomology groups is to singular cohomology with real coefficients. A priori they could be different. DeRham's Theorem says that they are the same even though singular cohomology is defined entirely differently. As mathwonk explained, if one integrates a ##{p}##-form over a ##{p}##-chain one gets a homomorphism of the group of smooth singular chains into the real numbers. This interprets the ##{p}##-form as a singular cochain. Stokes Theorem says that a closed ##{p}##- form becomes a closed singular ##{p}##-cochain and an exact ##{p}##-form becomes a singular coboundary. So one has a map of cochain complexes, that is: a collection of linear maps ##C^{p}_{DeRham → C^{p}_{singular}## that commute with the coboundary operators on each complex. This gives a collection of homomorphisms of cohomology groups ##H^{p}_{DeRham}→H^{p}_{singular}##. DeRham's Theorem says that these homomorphisms are isomorphisms.
The isomorphism between Czech cohomology and DeRham cohomology that I have seen does not use integration. Rather, it uses double cochain complex which I am happy to explain if someone wants.
BTW: The wedge product of differential forms determines a product on the DeRham cohomology groups. This product gives more information than the cohomology groups themselves. One might ask whether this product corresponds to another product on singular cohomology groups. The answer is yes. It is called the ""cup product".
I fixed it.WWGD said:Why don't you do an " Insights" on this? and , please, edit your previous; seems interesting, but difficult to read.
Any cochain complex gives rise to cohomology groups ##H^{p}## of ##p##-cocycles modulo ##p##-coboundaries. Differential forms on a manifold together with the exterior derivative form a cochain complex of modules over the real(or complex) numbers and therefore determine cohomology groups in each dimension ##p##. ##H^{p}_{DeRham}## is the group of closed ##p##-forms modulo the exact ##p##-forms.
One might ask what the relation of these cohomology groups is to singular cohomology with real coefficients. A priori they could be different. DeRham's Theorem says that they are the same even though singular cohomology is defined entirely differently. As @mathwonk explained, if one integrates a ##p##-form over a ##p##-chain one gets a homomorphism of the group of smooth singular chains into the real numbers. This interprets the ##p##-form as a smooth singular cochain. Stokes Theorem says that a closed ##p##- form becomes a closed singular ##p##-cocycle and an exact ##p##-form becomes a singular coboundary. So one has a map of cochain complexes, that is: a collection of linear maps ##C^{p}_{DeRham} → C^{p}_{smooth- singular}## that commute with the coboundary operators. This gives a collection of homomorphisms of cohomology groups ##H^{p}_{DeRham}→H^{p}_{smooth- singular}##. DeRham's Theorem says that these homomorphisms are isomorphisms.
The isomorphism between Czech cohomology and DeRham cohomology that I have seen does not use integration. Rather, it uses a double cochain complex which I am happy to explain if someone wants.
- The map from DeRham cohomology is to smooth singular cohomology i.e. where the simplices are required to be smooth. In general singular theory, simplices need only be continuous. One then proves that smooth singular and continuous singular are isomorphic.
One of the advantages of cohomology over homology is this cup product. It gives more information than cohomology alone.
rightWWGD said:I vaguely remember using cup products to distinguish between spaces in ways cohomology alone could not, i.e., the spaces had identical
cohomology groups but their cup product structures were non-isomorphic ( or whatever category applies).
A boundary operator on p-chains is a mathematical tool used in algebraic topology to describe the boundary of a p-dimensional space. It maps p-chains (p-dimensional objects) to (p-1)-chains (p-1-dimensional objects) and helps to understand the shape and connectivity of a space.
The boundary operator on p-chains works by finding the boundary of a p-chain, which is a linear combination of p-dimensional simplices (geometric objects) with coefficients from a field. It then applies the boundary operator to each simplex to determine its boundary, which is then added together to form the boundary of the p-chain.
The boundary operator on p-chains is significant in topology because it allows for the calculation of the homology of a space. Homology is a mathematical tool that describes the shape and connectivity of a space, and the boundary operator is key in defining the boundaries of p-dimensional simplices, which are used to construct the homology groups.
The boundary operator on p-chains and the boundary operator on (p-1)-chains are closely related, as they both describe the boundary of a p-dimensional space. The boundary operator on p-chains maps p-chains to (p-1)-chains, while the boundary operator on (p-1)-chains maps (p-1)-chains to (p-2)-chains. Together, they form a chain complex that helps to understand the topology of a space.
Yes, the boundary operator on p-chains can be applied to non-geometric objects, such as abstract simplicial complexes or simplicial sets. In these cases, the boundary operator is defined in a similar way, but the geometric interpretation may not be as clear. This allows for the use of the boundary operator in a variety of mathematical contexts beyond topology.
