Homework Help: Bounded set proof
  1. Feb 28, 2008 #1
    If A and B are bounded sets, then A U B is a bounded set.
    (Prove this statement)
    2. Relevant equations
    Definition of Union is a given.
    A set A is bounded iff there exists some real value m such that lxl < m for all element x found in A.
    3. The attempt at a solution
    This makes sense to me. If set A is bounded by M and set B is bounded by N, then A U B will be bounded by which value is higher. I have to keep in mind that the definition of a bounded set has the "iff" term.
    My attempt (this is quite odd looking to me, I don't know how to make it more straightfoward)
    Let x exist in A. Then that means there is a value m where m>lxl by definition of a bounded set.
    Let y exist in B. Then that means there is a value n where n>lyl by definition of a bounded set.
    Thus, x and y exist in A U B by definition of union.
    We know lxl and lyl are < whichever value of m or n is the larger of the two.
    Thus, A U B is a bounded set.
    The bolded step seems oddest, but critique on any part of the proof is welcome. Help!
  3. Feb 28, 2008 #2
    You should really start by assuming that x is in A U B. Then say why there is a constant K such that |x| < K.
  4. Feb 28, 2008 #3
    But I'm suppose to prove the implication the other way (if A and B are bounded, then A U B is bounded.), not the other way around. Regardless of whether or not the statement is actually biconditional.
  5. Feb 28, 2008 #4
    You are proving a statement about A U B, so you need to start with an arbitrary element in A U B. You can then invoke the known properties of A and B individually to prove the statement regarding the union.
  6. Feb 28, 2008 #5
    Reworked:
    Let X exist in A U B
    Thus X exists in A or B by definition of union.
    Cases:
    If x exists in A, then lxl < some real value m by the definition of bounded
    If x exists in B, then lxl < some real value n by the definition of bounded.
    If x exists in both A and B, then X is less than both m and n.
    Subcases (in the case that x is in both A and B)
    If m>n , x must be < n to fit the definition of bounded for both sets.
    If n>m, x must be less then m to fit the definition of bounded for both sets.
    Thus, for all possibities, the value x is less than some real value m or n. Thus, AUB is bounded since x exists in AUB.
    THat seems to make more sense, even if it is a tad convuluted. Is that more fitting?
  7. Feb 28, 2008 #6
    That's more like it, but the fact that x lies in the union simply means that |x| < max (m,n) which I would call K.
  8. Feb 28, 2008 #7
    Wouldn't it be min (m,n)?
    Edit: Never mind, I see, the larger bound of A or B will become the bound of AUB by definition of union.
  9. Feb 28, 2008 #8
    - you need to find a single value M s.t. for all x in A u B, we have |x| < M.
    - i don't know why you are saying exists, a more common phrasing is,
    suppose x is in A u B, or, assume x is in A u B, etc
    your idea is right, but to help you out, i'll put parentheses around things that aren't part of the proof.
    Proof. Suppose A and B are bounded. (now we write down what this means). Then there are M and N s.t. for all x in A, |x| < N, and for all x in B, |x| < M. Now suppose x is in A u B. (again, write down what this means). Then x is in A or x is in B.
    (now think for a moment, looking at what you have already done, you know that if x is in A, then |x| < N, and you know that if x is in B, then |x| < M. We need some number K that is bigger than both N and M, so we want the larger of the two, well we can say it in words, let K be the larger of the two, or just K = max{M, N})
    Set K = max{M, N}.
    If x is in A, then |x| < N <= K.
    If x is in B, then |x| < M <= K.
    In any case, |x| < K, so A u B is bounded.
    Edit: Note that it's important to specify a single value K because the definition requires it. There are times when you can't take a maximum and find a single value K(like if you had an infinite union of bounded sets, A U B U C U ..., it's not always possible to find a maximum, depends what the sets are)
  10. Feb 28, 2008 #9
    Re-reworked
    (The problem on my homework already states to suppose that A and B are bounded with that definition, so I wont need to restate that )
    Let X exist in A U B. Also, let K= max (m,n)
    Cases:
    If x is in A, then lxl < m thus lxl< K
    If x is in B, then lxl < n thus lxl< K
    If x is in both A and B, then lxl over both sets is always less than max (m, n) or lxl < K.
    Thus, for all possibities, the value lxl is less than some real value K. Thus, AUB is bounded since x exists in AUB.
    AM i getting closer?
  11. Feb 29, 2008 #10
    HallsofIvy
    Since you are dealing with both x in A and x in B, you don't need to deal with "x in A and B" separately.
Loading...
