Generate Elliptical Distribution from Box-Muller Transform
In summary, the Box-Muller transform can be used to generate a distribution with two different standard deviations, and can also be used to transform a standard normal distribution into a distribution with a specified mean and standard deviation. This can be helpful for generating random variables with specific properties, such as generating an elliptical distribution on the x/y plane. Pseudo code can be used to illustrate this process.
ireland01
Can i use box muller transform to generate a distribution with two different sigma (i.e. sigma_x and sigma_y)?
I want to generate a random gaussian angle (C) relative to z axis on circle plane, then set the angle relative to the x, A and y axis, B, wrt to the original angle.
However, I want the output to be elliptical on x/y plane...
Some pseudo code would help.
If X is normal with zero mean and std dev = 1, then you can transform it into a random variable Z with mean u and std dev sigma as follows:
Z = sigma*X + u
The Box-Muller transform gives you two random variables which are standard normally distributed iirc, so just apply the above transformation to each.
1. What is the Box-Muller Transform?
The Box-Muller Transform is a mathematical method used to convert a set of uniformly distributed random numbers into a set of normally distributed random numbers. It is commonly used in statistics and probability theory.
2. How does the Box-Muller Transform work?
The Box-Muller Transform works by taking a pair of uniformly distributed random numbers and using them to generate a pair of normally distributed random numbers. This is done using trigonometric functions and the properties of the normal distribution.
3. What is an elliptical distribution?
An elliptical distribution is a type of probability distribution that is characterized by its shape, which resembles an ellipse. It is a generalization of the normal distribution and can take on a variety of shapes depending on its parameters.
4. Why is the Box-Muller Transform used to generate an elliptical distribution?
The Box-Muller Transform is used to generate an elliptical distribution because it is a convenient and efficient method for converting uniformly distributed random numbers into normally distributed random numbers. Since the elliptical distribution is a generalization of the normal distribution, the Box-Muller Transform is well-suited for this task.
5. Can the Box-Muller Transform be used to generate other types of distributions?
Yes, the Box-Muller Transform can be used to generate other types of distributions besides elliptical distributions. It can be used to generate any type of distribution that can be expressed as a function of the normal distribution, such as log-normal, chi-squared, and exponential distributions.
  • Nuclear Engineering
