Brake Master Cylinder output
  1. Aug 13, 2015 #1
    Hi,
    I am in the process of restoring the brakes a 1974 Porsche 914 and upon reading up on a Porsche forum found a discussion about changing the original 17mm brake master cylinder with a 19mm one. A number of individuals indicated that doing so would reduce braking pressure and I was unclear as to why that would be.
    It would seem to me that with all brake lines and calipers staying the same that a 19mm master cylinder (assuming same brake pedal travel and force) would push more fluid through the lines and increase pressure.
    Please help me understand if I am incorrect,
    thx
    lugnuts
  3. Aug 13, 2015 #2
    Bystander
    Pressure is NOT a function of volume in this case; it IS a function of the cylinder x-section area, larger area for constant applied pedal force means LOWER pressure.
  4. Aug 15, 2015 #3
    Pressure is force/area. The are of a circle is πr2, so, the area of the 17mm piston is 227 mm2. The area of the 19mm piston would be 284 mm2. Since there are 1 million mm2 per m2, newtons per mm2 would be mega-pascals. If you + the brake booster apply 1000 newtons to the piston the 17mm piston will produce 1000/227=4.41 mpa. The same 1000 newtons applied to the 19mm piston would only produce 1000/284=3.52 mpa.
    A brake system is not a completely static system however, pieces move. Therefore a certain volume of fluid must be moved in order to apply the brakes. The 19mm piston will move more fluid for the same amount of pedal travel, therefore you will not have to push the pedal as far to apply the brakes, you will however, have to push it harder.
Similar Discussions: Brake Master Cylinder output
  1. Braking Distance (Replies: 1)
  2. Car Brakes (Replies: 3)
  3. The brakes of a car (Replies: 2)
  4. Warmed brakes (Replies: 8)
Loading...
