Is the Brans-Dicke Vacuum Cosmology Theory Still Relevant?
The discussion revolves around the relevance of Brans-Dicke vacuum cosmology theory, particularly in the context of its equations of motion and potential implications for cosmological models. Participants explore theoretical solutions, implications for the universe's expansion, and the relationship between mass scale and cosmological redshift.
  • One participant presents calculations assuming a constant mass density vacuum with an equation of state ##p=-\rho##, leading to a static solution with mass scale ##\phi \sim t##.
  • Another participant clarifies that while Brans-Dicke theory is not "ruled out," the high value of the ##\omega## parameter makes its predictions similar to those of standard General Relativity (GR).
  • Concerns are raised about the implications of a nonzero parameter ##\Omega_\Delta## proposed in a referenced paper, suggesting it would require a reevaluation of the entire framework of metric theories of gravity.
  • A participant expresses surprise at the lack of references to their proposed solution and speculates about the implications for the solar system's metrics and cosmological redshift.
  • Another participant questions the validity of the assumptions made regarding the relationship between mass scale and atomic behavior, urging caution in drawing conclusions.
  • A final post indicates that the discussion may not align with forum guidelines, suggesting a shift from Brans-Dicke vacuum cosmology to personal theory.
Participants express differing views on the implications and validity of Brans-Dicke theory, with some arguing it remains relevant under certain conditions, while others challenge the assumptions and conclusions drawn from the proposed models. The discussion does not reach a consensus.
Limitations include the dependence on specific assumptions about mass density and the behavior of atomic states under varying mass scales, which remain unresolved within the discussion.
jcap
Has anyone heard of papers describing Brans-Dicke vacuum cosmology solutions?
I'd be interested to know if the following calculations make sense.
I assumed a constant mass density vacuum with equation of state ##p=-\rho##.
I then plugged this equation of state into the Brans-Dicke equations of motion for FRW cosmology and confirmed the existence of a static solution with mass scale ##\phi \sim t##.
Maybe, as Eddington speculated in "The Expanding Universe", the atoms are shrinking (as their energy increases with mass scale ##\phi##) rather than space expanding?
People claim that the Brans-Dicke theory has been ruled out by observation but maybe it hasn’t been ruled out if it applies to the whole universe dominated by vacuum energy?
The apparent cosmological redshift, for example, is then explained by the increased energy scale of absorber atoms relative to earlier emitter atoms rather than photon stretching due to space expansion.
I used the following paper which helpfully gives the generalized Brans-Dicke equations of motion for FRW cosmology (Eqns 7,8,9 with equation of state ##p=-\rho## and scalar field mass ##m=0##) :
https://arxiv.org/abs/gr-qc/0604082v4
Space news on Phys.org
Not exactly. What is known is that observation constrains the Brans-Dicke ##\omega## parameter to be very large (IIRC it must be at least ##40,000## the last time I checked the limit; the limit might be even higher now with more accurate observations). With ##\omega## that high BD theory is basically indistinguishable from standard GR.
Again, it's not a matter of being "ruled out", it's that the ##\omega## parameter has to be very high, so the theory's predictions are basically the same as those of standard GR.
The paper doesn't say anything different from the above. It simply hypothesizes (with no basis in actual evidence) that we might at some point to get evidence for a nonzero value of the parameter they call ##\Omega_\Delta##. They then say that if that were to ever happen, we would have to re-evaluate BD theory in the context of cosmology. However, that's a misstatement: what would actually happen is that we would have to re-evaluate the whole framework of metric theories of gravity, because we would not have any single theory that could explain all the data, since a nonzero value of the paper's ##\Omega_\Delta## parameter would be inconsistent with the current evidence that constrains the BD ##\omega## parameter to be very large, so BD theory would not be a consistent explanation of all the evidence we have any more than standard GR would.
Or, to put it the other way around, all of our current evidence is consistent with the expectation that the paper's ##\Omega_\Delta## parameter is zero, so that's what we expect all future evidence to show. The paper gives no good reason to change that expectation; it just hypothesizes future data inconsistent with that expectation and then works out some consequences of that hypothesis.
I must admit that I only used the paper to find out the equations of motion for Brans-Dicke FRW cosmology.
I calculated that if Brans-Dicke theory is applied to the Universe as a whole, assuming its mass density is dominated by vacuum energy, then we get a static Universe with a universal mass scale ##\phi## proportional to cosmic time ##t##. I haven't seen any references to such a simple solution which seems surprising to me. Surely I can't be the first person to think of it?!
Therefore I think that the whole solar system, including its Schwartzschild metric, will simply shrink in a manner inversely proportional to the cosmic time ##t##.
But I presume that one could still use Einstein's theory locally as the Planck length would also shrink at the same rate.
Thus experiments on the solar system would not rule out Brans-Dicke theory for the Universe as a whole. The main experimental consequence would be an apparent cosmological redshift due to the difference in mass scale between absorbing and emitting atoms (the energy of the emitted photon itself does not change with mass scale).
Have you considered the possibility that you made a mistake?
jcap said:
Therefore I think that the whole solar system, including its Schwartzschild metric, will simply shrink in a manner inversely proportional to the cosmic time tt.
The Schwarzschild metric is not the FRW metric, it's a different solution, so even if your "simple solution" above were correct it would not justify the inference you are making here.
I don't see how this inference is justified either.
You're just waving your hands here. You would need to first show how the mass scale affects bound states like atoms--you can't just assume that. You would also have to show how the energy of the emitted photon is independent of the mass scale--you can't just assume that either.
But before you do any of that, you should, as I said above, consider the possibility that you made a mistake.
Then this discussion is not really about B-D vacuum cosmology but about your personal theory, which is off limits for discussion here.
Thread closed.
  • · Replies 20 ·
  • · Replies 134 ·
12K
  • · Replies 25 ·
