Homework Help: Bubble in pipeline
  1. Sep 29, 2013 #1
    A horizontal pipeline with a flowing liquid contains a small bubble of gas. How do the dimensions of this bubble change when it reaches a narrower point of the pipeline? Can you find some applications of this phenomena? What problems could it cause? Assume that the flow is laminar.
    2. The attempt at a solution
    It isothermal process: T = constant, vp = constants.
    In the tapered section:
    Liquid stream will have a higher rate, but a lower pressure.
    Owing to the lower pressure of the bubble increases.
    This is everything what I know.
    If x = radius of the bubble at the start, can I somehow express the radiusof the bubble in the tapered section?
    Hmmm... Bubbles may be undesirable in heating. Then the heat not gets everywhere. Maybe some bubble may serve as an insulator. I don't know more... Do you know something?
    Thanks very much and sorry for my bad English :-)
Draft saved Draft deleted
