Buffer action and titration
  1. Sep 6, 2015 #1
    Titan97
    If H2A2+ is being titrated with NaOH, a buffer forms.
    The processes taking place are equilibrium between H2A2+ and HA+ ions, autoprotolysis of water and reaction of OH- ions with H2A2+ ions. As NaOH is added, the concentration of acid tends to decrease but because of the equilibrium
    ##H_2A^{2+} <=> HA^+ + H^+##, the decrease in concentration of acid is negligible.
    Adding NaOH increases the amount of conjugate base which in turn increases the concentration of acid. Does this process never end? Whatever NaOH you add, the reacted Acid will form back.
  3. Sep 6, 2015 #2
    Borek
    Staff: Mentor
    Be very, very careful about your wording.
    There is a total concentration of all forms produced during the acid dissociation - so called "analytical concentration". We often speak about this kind of concentration even in solutions that don't - technically - contain an acid (like Na3PO4).
    Then, there are equilibrium concentration of all forms, of those some (H3A, H2A+, HA2-) are acids (produce H+ during dissociation).
    Finally, there is concentration of dissociated H+, which defines how acidic the solution is.
    So, which of those you mean here:
    (And no, as stated, this is not true, when you add NaOH to the solution concentrations of all acidic forms - H+, H3A, H2A+, HA2- - decrease).
  4. Sep 6, 2015 #3
    Titan97
    The last sentence answers my query. I was actually solving a problem : https://www.physicsforums.com/threads/titration-of-amino-acid-with-strong-base.831012/
    There, my teacher told me that the concentration of acid at any point remains the same. Maybe you have seen it.
    If I take sodium acetate and titrate it slowly with NaOH, NaOH reacts with acetic acid formed by hydrolysis of sodium acetate. This decreases concentration of acid.
    But according to Le Chatelier principle, as acid decreases, more acetate ions get hydrolysed to form acid. So the concentration of acid remains unchanged while concentration of salt will change.
  5. Sep 6, 2015 #4
    Borek
    Staff: Mentor
    Not exactly. Le Chatelier's principle tells you what general direction of the shift to expect, but not what the exact change will be. When you add base, acids get neutralized and pH goes always up. It is pretty easy to show that for each acid and conjugate base pair ratio of concentrations is
    [itex]\frac {[HA]}{[A^-]} = 10^{pK_a-pH}[/itex]
    so if the pH changes concentration of the acid (HA in this case) doesn't stay constant.
    But it is all the time not clear to me what you (and your teacher) mean by "acid" in this context. Total concentration? Equilibrium concentration? As long as the volume of titrant added is negligible, total concentration of the acid doesn't change, but equilibrium concentrations do change.
  6. Sep 6, 2015 #5
    Titan97
    I mean total concentration of acid and not equilibrium concentration.
  7. Sep 6, 2015 #6
    Borek
    Staff: Mentor
    So the total doesn't change, but the concentration of HA goes down.
Loading...
