Buffer Capacity
  1. Apr 4, 2006 #1
    What is the smallest amount of solid NaOH that will exceed the buffer capacity 500mL of a buffer that is 0.4M in acetic acid and 0.15M in NaOAc?
    a)5.69 b)5.16 c) 4.74 d) 4.31 e)3.00 grams
    Since this is a strong base, we only need to deal with the 0.4M of acetic acid.
    so 0.4M *.5L = 0.2moles of NaOH
    that's 8 grams. What am I doing wrong here?
  3. Apr 4, 2006 #2
    siddharth
    I think you should read up on what a buffer is.
    http://en.wikipedia.org/wiki/Buffer_solution" [Broken]
    So, can you see why what you did is wrong?
  4. Apr 4, 2006 #3
    oops... i think i got the answer... thanks
  5. Apr 5, 2006 #4
    Borek
    Staff: Mentor
    Seems there are different definitions of buffer capacity in use. I was taught buffer capacity is defined as the ratio of the amount of strong base or strong acid added to the change in pH - thus you can't say when it will run out - as it is value that you can calculate for a point (as first derivative, dn/dpH, where n - moles).
  6. Apr 8, 2006 #5
    Borek
    Staff: Mentor
  7. Apr 5, 2007 #6
    Does anyone know what the answer to that question is? I tried to figure it out but I'm getting enough of a pH change for any of the amount of solid.
  8. Apr 8, 2007 #7
    Borek
    Staff: Mentor
    First of all - what pH change do you expect?
