Homework Help: Building a set notation
  1. May 8, 2013 #1
    reenmachine
    The book I'm reading ask me to build a set notation for the following set: ##\{-3/2 , -3/4 , 0 , 3/4 , 3/2 , 9/4 , 3 , 15/4 \}##.
    3. The attempt at a solution
    I attempted to build a set notation and came with the result:
    ##\{ x \in R : \exists y\in Z \ \ y(3/4)= x\}##
    My idea is that the sequence is always +3/4 or -3/4 , therefore any number in Z multiplied by 3/4 will be an element of the set we're trying to notate.
    Thank you for your help!
  3. May 8, 2013 #2
    Dick
    That's true enough, but the set your notation describes has an infinite number of elements. The original set you wrote down has only 8 elements. Your notation should be a little more specific. Or does the set you are trying to construct also have an infinite number of elements and you only showed 8 of them without a '...'?
  4. May 8, 2013 #3
    Fredrik
    Staff Emeritus
    There's also a way to simplify the notation. Fix the issue that Dick mentioned first, and then try to think of a way to simplify the notation.
  5. May 8, 2013 #4
    Dick
    I agree. But I think the set reenmachine wants to describe probably has more than 8 elements. I was just trying to clear that up. It's not all that useful to describe small finite sets using set builder notation. Otherwise why not write {x:x∈{−3/2,−3/4,0,3/4,3/2,9/4,3,15/4}}?
  6. May 8, 2013 #5
    reenmachine
    My apologies for the other thread , thought this one didn't work my computer crashed or something.
    I made a mistake , the set I was supposed to find a notation for was the set ##\{... , -3/2 , -3/4 , 0 , 3/4 , 3/2 , 9/4 , 3 , 15/4 , ...\}##.
    To simplify it , I could try: ##\{ n \in Z : n(3/4)\}## ?
  7. May 8, 2013 #6
    Mark44
    Staff: Mentor
    It would be {3n/4 : n ##\in## Z}
  8. May 8, 2013 #7
    reenmachine
    Is there really a difference? If so , is it the left-right factor or is it ##3n/4## versus the ##n(3/4)##?
  9. May 8, 2013 #8
    Dick
    {n∈Z:n(3/4)} doesn't mean anything. What follows the ':' is supposed to be a true/false statement.
  10. May 8, 2013 #9
    reenmachine
    Ok , in that case , is ##\{ n(3/4) : n \in Z\}## the same as ##\{ 3n/4 : n \in Z\}##?
  11. May 8, 2013 #10
    Dick
    Sure it is. 3n/4=(3/4)n. Isn't it?
  12. May 8, 2013 #11
    Mark44
    Staff: Mentor
    Yes, but written in a slightly different way. I reversed the order of things in what I wrote for the reason that Dick said.
  13. May 8, 2013 #12
    reenmachine
    Thanks guys!
    So basically , ##\{3n/4 : n \in Z\}## is the shortest way to describe the set with a set notation?
  14. May 8, 2013 #13
    Dick
    I would say, yes.
  15. May 8, 2013 #14
    reenmachine
    Thanks guys!
Have something to add?
Draft saved Draft deleted
