Building a solenoid
  • Thread starter Ziggey
Main Question or Discussion Point
Hello so I just want to make sure I Am doing this correctly.
also I know there is a magnetic field force formula. That is F= qv (dot) B
How would I go about using that formula with the magnetic field I created from the solenoid in the picture?
Thanks for any help!
Zig
Answers and Replies
Matterwave
326
It's really hard to read the text in the picture. Can you summarize by posting it?
Ok I'm using the equation B= unI
n=N/L
u=k(4*pie*10^-7)
k=200
Once I plug in the numbers I get n= 18/.504=35.7142, u= 2.513*10^-4.
So if I have 10 amps then my final number should be .0897 B. Did I do that correct?
PhysicoRaj
35
For the values you have assumed, the calculations seem correct. About the magnetic field force formula, you are referring to Lorentz force formula:##F=q (\vec{v}\times\vec{B})##
Ok well what I don't understand about that equation is the velocity part. I have been trying to do some reading on it, but I don't understand it. Is the velocity for the speed of the electron or something else?
Ok I will try and get it then show my work to make sure I'm doing it correctly. Thank you for the help!! Zig
Related Threads on Building a solenoid
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
