Homework Help: Bullet, Collision, Block
  1. Jan 31, 2009 #1
    A wooden block of mass M resting on a frictionless horizontal surface is attached to a rigid rod of length l and of negligible mass. The rod is pivoted at the other end. A bullet of mass m traveling parallel to the horizontal surface and perpendicular to the rod with speed v hits the block and becomes embedded in it.
    What fraction of the original kinetic energy is list in the collision?
    2. Relevant equations
    KE = 1/2 m v^2
    L = cross(r,p)
    3. The attempt at a solution
    The only way I can think of doing this problem is using linear momentum conservation.
    Say if pi = m*v, pf = (m+M)v'
    v' = v * m / (M+m)
    final / initial Kinetic Energy = m / (M+m)
    Unfortunately, the answer is M/(M+m).
    I believe that I should be using conservation of angular momentum. According to part a of this problem (not stated) the angular momentum of the bullet+block = mvl.
    If I were to use cons. of angular momentum, I don't really know to formulate it.
    Initial Li = 0
    Final Lf = mvl
    Does anyone have any hints?
  3. Jan 31, 2009 #2
    fraction lost = (init - final)/init
    =1 - m/(m+M)
    =M/(m+M)
    Read the question!
    The rod is an irrelevance, since it's massless.
    If it wasn't, you would indeed conserve angular momentum
    to solve it.
