Bullet hitting a suspended mass
  • Thread starter captainjack2000
  • Tags
    Bullet Mass
In summary, a mass of 0.5kg suspended from a fixed pivot is struck by a bullet of 10g with a speed of 150m/s. After impact, the mass increases to 0.51kg and its kinetic energy is converted into gravitational energy, causing it to gain a height of 4.32mm. By using the length of the string and the height gained, the angle at which the mass swings back can be calculated to be approximately 15.4385 degrees.
captainjack2000
99
A mass of M=0.5kg is suspended from a fixed pivot by a thin rope of length l=120cm. The mass is struck by a bullet of mass m=10g with a speed of v=150m/s which embeds itself into the lead mass. What angle does the combined mass swing back to?
Well initiall the energy of the system would be
E=kinetic energy of suspended mass + kinetic energy of bullet
=0+0.5 * 0.01kg *150m/s
=112.5J
When the bullet hits the suspended mass would gain mass = M+m =0.51kg
Final kinetic energy = 0.5 *0.51 *v^2
Conservation of energy: 112.5 =0.5 * 0.51 *v^2
giving v=21.004m/s
Centripetal force=mv^2/r = 0.51 * 21.004^2 /0.12 = 1874.964 N
Not sure how to turn this force into an angle?
From the way the question refers to the combined mass I am assuming that the bullet and the mass stick together after impact. In this case it is not possible to use conservation of kinetic energy before and after impact as some of the kinetic energy must be lost to heat or to deforming the objects in order for them to stick together.
You should use conservsation of momentum. Immediately before impact the momentum is 150*0.01 kgms^-1. Immediately after impact it is the same but the mass has increased. From this you can work out the speed and hence the kinetic energy of the combined mass immediately after impact. Now you can assume that all the kinetic energy is converted into gravitational energy and work out the height the mass must raise for all its KE to be lost. Now draw a diagram of the mass on the string at an angle and you will see you can work out two side lengths of a right angled triangle (one of them is the length of the string given in the question). From this you can work out the angle.
I follow that really well. Thanks.
I get that the mass gains a height of h=4.32mm
When trying to draw the right angle triangle I get a bit confused. If the length of the hypotenuse is the length of the string. The angle at the top of the triangle is theta, the angle through which the mass moves. The length of the second side (bordering the angle) would be 0.12m-4.32mm ??
This then allows me to use
cos(theta)=(0.12m-4.32mm)/0.12
theta=15.4385degrees
is that right?
Yes, well exactly the right idea anyway. It looks like you might have got your units a bit confused (or I might be misunderstanding you) 120cm is 1.2m not 0.12m :-)
1. How does the weight of the suspended mass affect the impact of the bullet?
The weight of the suspended mass has a significant impact on the bullet's trajectory and velocity upon impact. Generally, a heavier suspended mass will cause the bullet to lose more energy and result in a slower and less destructive impact.
2. What factors determine the amount of damage caused by a bullet hitting a suspended mass?
The amount of damage caused by a bullet hitting a suspended mass depends on several factors, including the velocity and mass of the bullet, the material and weight of the suspended mass, and the distance between the bullet and the suspended mass at the point of impact.
3. Can the angle at which the bullet hits the suspended mass affect the outcome?
Yes, the angle at which the bullet hits the suspended mass can have a significant impact on the outcome. A bullet hitting the suspended mass at a perpendicular angle will have a more direct and forceful impact, while a bullet hitting at an angle will have a glancing impact and cause less damage.
4. How does the distance between the suspended mass and the surface it is suspended from affect the impact of the bullet?
The distance between the suspended mass and the surface it is suspended from can affect the bullet's impact in a few ways. A shorter distance will result in a more direct impact, while a longer distance may cause the bullet to lose some of its energy before reaching the suspended mass, resulting in a less destructive impact.
5. What is the best material for a suspended mass to minimize the impact of a bullet?
The best material for a suspended mass to minimize the impact of a bullet will depend on the specific situation and desired outcome. Generally, materials that are dense and able to absorb energy, such as sand or water, can help minimize the impact of a bullet on a suspended mass.
